Old June 13th, 2011, 04:16 PM   #1
forevertwowheels
forevertwowheels's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R 2011 Honda CBR600RR
Quick Airbox removal question
If i take the carbs out will i be able to get the airbox out without taking the undertail off and without breaking it?
and is there any thing i should take note of before taking the airbox out?
thanks
Projekt D Fender Eliminater / DMP Integrated Taillight / Proton Flushmounts / Area P 18" CF High Mount Race System / Kleen Air System Removed / Airbox Removed / K&N R-0990 / DynoJet Jet Kit
forevertwowheels is offline   Reply With Quote
Old June 13th, 2011, 04:24 PM   #2
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Notate:
1) There is no such thing as a 'quick airbox removal'...
2)Unless you really like laying on your garage floor, leave the carbs be. This could spell disaster. IIRC, my 2008 was not fun removing the airbox. Find the DIY on here or KawiForums.com (sorry Alex), and plan accordingly. Thorough work now will pay dividends later...
I imagine you're doing this to install pods?
Last futzed with by DmbShn41; June 13th, 2011 at 04:25 PM. Reason: speeling
Old June 13th, 2011, 04:29 PM   #3
tjkamper
tjkamper's Avatar
Quick answer. NO!
Old June 13th, 2011, 04:32 PM   #4
forevertwowheels
Originally Posted by DmbShn41 View Post
Notate:
1) whoops i worded that wrong "quick question on lenghty airbox removal" fixed
2)i have the DIY from this site printed up and memorized lol
and yes this is for installing pods
Old June 13th, 2011, 04:37 PM   #5
lol... you go in with a plan in mind, end up frustrated and then start pulling stuff off until you take enough stuff off to get that damned airbox out. once you get it out, you're done.
assembly is the reverse of removal.
Old June 13th, 2011, 04:38 PM   #6
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Your best to leave the carbs be. It's a whole other DIY removing the carbs. I seem to remember Vex did this, or maybe Duck, but it doesn't save much time, and is just a bunch more stuff to mess with. Look at it this way, with the entire backend disassembled, you can put in that lovely, easy access fuse box, wire in some LEDs, or whatever your heart desires...good luck. Have your pods already?
Old June 13th, 2011, 09:00 PM   #7
forevertwowheels
yes i have my pods already.
what have you guys (people who have removed the airbox) done with these parts? (circled in red)
it looks like you remove them but how? there is a screw underneath on the carb side but nothing i have would reach good enough to loosen it.
Old June 14th, 2011, 04:03 AM   #8
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Just a note, the DIY tells you to take out the all the screws so you can slipt the airbox into two peices to remove. I found that it was easier to take the back tail off along with the tire. With those removed, the air box will slide out the back fairly easy.
The runners (in the pic above) are held on by an alen screw. You want to have them on the carbs as pictured and put the POD filter on the end on of that. The pod filter can't get a good grip on the carbs so the runners are used to hold the pod filter. Take your time with this! Your taking a lot of stuff off. It needs to go back where it came from. lol
scotty is offline   Reply With Quote
Old June 14th, 2011, 05:31 AM   #9
Lvr
Ditto on that removal method. that's actually how the manual says to do it; remove the rear wheel and pull the whole thing out through the back.
As far as the runners, although you do want to reuse them, you'll probably want to take them off the carbs, affix them to your new filter, and then mount them again. they're held on at either end by a simple clamp that's tightened with a screw. just loosen the screw for each runner where it connects to the carb and pop it off.
And while you're cursing your way through it, just remember: it's totally worth it good luck!
Lvr is offline   Reply With Quote
Old June 14th, 2011, 11:09 AM   #10
I don't get it... aren't you going to be taking the carbs out to rejet, anyway? the rubber thingys are held on to the carbs via simple clamps which will be very obvious once you get the carbs out.
Old June 14th, 2011, 11:21 AM   #11
airbox removal is quickest with a big saw and hammer.
Old June 14th, 2011, 04:31 PM   #12
forevertwowheels
alex.s =>
kkim => yeah i forgot ill be removing the carbs now anyways so i can deal with them when the carbs are off.
i took the airbox out last night, it went pretty smooth until i had to seperate the two halves, the metal grate between them was making it hard to take them apart. and removing the rear wheel would have make things easier but i managed to get it out.
thanks all for your help so far, lets see if i can get the pods on and start rejetting tonight.
Post airbox removal questions htsang07 2008 - 2012 Ninja 250R Tech Talk 16 May 23rd, 2013 06:33 AM
Airbox removal and jetting + other questions kamikaze 2008 - 2012 Ninja 250R Tech Talk 3 February 18th, 2012 08:04 PM
Airbox removal + Kleen air removal? MikeBudd 2008 - 2012 Ninja 250R Tech Talk 6 February 16th, 2012 04:57 PM
Quick question, spark plug removal Ragnar1x 1986 - 2007 Ninja 250R Tech Talk 4 April 21st, 2011 08:11 PM
Quick Question About Snorkel Removal LegB4Wicket 2008 - 2012 Ninja 250R Tech Talk 8 December 11th, 2010 10:49 AM
