December 20th, 2010, 05:55 PM | #1 |
Join Date: Dec 2010 Motorcycle(s): 2004 Ninja 250 Posts: 14
License Plate Bulb Type?
I just bought a 2004 Ninja 250 this week. Does anyone know what type of bulb the license plate light takes? I thought the bulb was burned out but then found out the original owner removed the bulb. He let the registration expire so probably removed the bulb so his plates couldn't be seen at night.
December 20th, 2010, 09:34 PM | #2 |
Not sure if the license plate bulbs are the same on the current-gen and pre-gen, but here's a link to the new-gen info...
http://www.ninjette.org/forums/showthread.php?t=45510
December 21st, 2010, 08:02 AM | #3 | |
Thanks for your response
December 21st, 2010, 11:26 AM | #4 |
Join Date: Mar 2010 Motorcycle(s): Several Posts: A lot.
Look for an R5W. That's what was marked on the one I removed from my 2006 to replace it with LED. The base is BA15S. Many bulbs use that base, the main difference is the R bulbs have a fairly small glass bulb compared to, say, the 1156.
January 4th, 2011, 08:00 PM | #5 |
I searched for a week for a R5W. None of the auto parts stores carry it so I tried a car-size BA15S one. It turned out to be too large and it burn a hole in the light hood. I finally bought one for about $2.50 from a dealer.
January 5th, 2011, 07:36 AM | #6 |
It sounds like you got one of the high-power bulbs. Here's a handy bulb reference site: http://www.donsbulbs.com/cgi-bin/r/b...ba15s~ece.html
I converted mine to LED. It is brighter, uses less power, and will never burn out. Ebay is a good source for LED bulbs. |
January 23rd, 2011, 12:22 PM | #7 |
Join Date: Sep 2010 Motorcycle(s): 05 Ninjette Posts: 131
Hey Frank I pm'ed you about the bulb. It looks like you got one so you can disregard it.
For anyone else: I have a spare bulb/wire (the bulb and setup) from the old fender I'll give to anyone for the cost of shipping. |
February 1st, 2011, 03:08 PM | #8 |
Long Time Rider
Just had to replace my License Plate Bulb to pass inspection today. I have read other post as that what bulb is compatible or a suitable replacement to the stock bulb. Here is what I found;
The stock bulb is a Stanley R5W bulb designed for 12 volts / 5 watts max, avg. life of the bulb is approx 500 hours The more suitable replacement bulb is the Sylvania 67LL Mini Bulb. This bulb is designed for 13.5 volts / 8 watts max. Operating at 12.8 volts, wattage is 7.3 watts. Light output is 41 lumens and has an avg. life of approx 9,000 hrs. The bulbs are the exact same size, but the 67LL (Long Life) bulb is better and a slight bit brighter and can be found at any auto parts store. The 67LL bulb is used on autos as a license plate bulb. This bulb will fit the 2001 -2007 Ninja 250 as well as the 2008-2011 Ninja 250. Some have replaced the stock bulb with a 1156 bulb. This bulb will fit because the base is the same size, but may be a tight fit inside the housing. This bulb is much brighter (26.9 watts / 402 lumens) However this bulb may produce a little more heat, as it pulls 2.10 amps compared to the .57 amps of the 67LL, and has an avg. life of approx 1200 hours. |
May 22nd, 2011, 09:40 AM | #9 | |
May 22nd, 2011, 10:14 AM | #10 | |
Long Time Rider
May 22nd, 2011, 05:13 PM | #11 | |
License plate bulb | dtyndall | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 14th, 2016 10:47 AM |
What is the rear bulb type? | tmf1423 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 3rd, 2014 09:44 AM |
Does dead taillight bulb affect the license plate bulb? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 3rd, 2013 06:05 AM |
License Plate Lighting | jhunter | 2008 - 2012 Ninja 250R Farkles | 17 | August 20th, 2012 08:39 PM |
License plate | beqwarrior | 2008 - 2012 Ninja 250R Tech Talk | 20 | June 17th, 2011 05:11 PM |
