Old November 5th, 2020, 01:44 PM   #1
GeoffB
Motorcycle(s): Kawasaki ninja 250 (new rider! Don't judge! Lol)
Hello from Soco StL MO
I bought a 2001 Ninja 250 and it had many problems. I have fixed about 90% of them and it was ALMOST ready to ride when the internal gear shifter and the outter shift lever stripped out. I replaced both parts. Put it all back together and I'm struggling with this final thing:
At what torque spec does the 27mm nut need to be tightened? (Clutch plate housing)
I can't get the clutch to engage. Do the four 8 mm bolts (with springs and washers) have to be at a certain torque spec? If so, what spec?
When that little knob is pulled by the clutch cable, nothing seems to happen. Are those 4 bolts too tight? Too loose?
Thanks in advance!
GeoffB is offline   Reply With Quote
Old November 5th, 2020, 02:03 PM   #2
GeoffB! Glad to have you aboard...
Old November 5th, 2020, 04:43 PM   #3
Ceeloo Yello
Motorcycle(s): 250
Welcome.
Old November 5th, 2020, 06:30 PM   #4
Hi Geoff, welcome to Ninjette!!!
Check out photos in this thread:
https://www.ninjette.org/forums/showthread.php?t=259395
There is little rod in centre that is pulled outwards by clutch release-lever on engine-case. When installing engine-case, you must rotate release-lever so it engages rod in order for it to operate clutch.
Also pressure-plate has dimple mark that must line up with outer clutch housing.
Last futzed with by DannoXYZ; November 5th, 2020 at 10:42 PM.
Old November 9th, 2020, 04:30 PM   #5
GeoffB
Oh WOW!! I knew it had to be something simple!! Thanks so much!!
Old November 21st, 2020, 05:25 PM   #6
Hello and welcome!
Old December 15th, 2020, 12:59 PM   #7
Welcome!
[webbikeworld.com] - Super Soco TSx Is the Cool Beginner Electric Motorcycle Ninjette Newsbot Motorcycling News 0 March 16th, 2020 06:11 AM
[webbikeworld.com] - Here?s a Look at the New Electric Super Soco CUx Special Edition Ninjette Newsbot Motorcycling News 0 May 17th, 2019 05:26 AM
[visordown.com] - Super Soco, the first electric bike maker to sell 100+ units in a y Ninjette Newsbot Motorcycling News 0 January 18th, 2019 11:03 AM
2010 Ninja 250 race ready (STL) Aodrn Motorcycle-related 9 July 18th, 2014 12:21 PM
Hello from STL bcakd5 New Members 12 September 19th, 2011 07:18 PM
