November 5th, 2020, 01:44 PM | #1 |
Join Date: Nov 2020 Motorcycle(s): Kawasaki ninja 250 (new rider! Don't judge! Lol) Posts: 2
Hello from Soco StL MO
I bought a 2001 Ninja 250 and it had many problems. I have fixed about 90% of them and it was ALMOST ready to ride when the internal gear shifter and the outter shift lever stripped out. I replaced both parts. Put it all back together and I'm struggling with this final thing:
At what torque spec does the 27mm nut need to be tightened? (Clutch plate housing) I can't get the clutch to engage. Do the four 8 mm bolts (with springs and washers) have to be at a certain torque spec? If so, what spec? When that little knob is pulled by the clutch cable, nothing seems to happen. Are those 4 bolts too tight? Too loose? Thanks in advance! |
November 5th, 2020, 02:03 PM | #2 |
GeoffB! Glad to have you aboard...
November 5th, 2020, 04:43 PM | #3 |
Welcome.
"It ended up being the loose nut behind the wheel" |
November 5th, 2020, 06:30 PM | #4 |
Hi Geoff, welcome to Ninjette!!!
Check out photos in this thread: https://www.ninjette.org/forums/showthread.php?t=259395 There is little rod in centre that is pulled outwards by clutch release-lever on engine-case. When installing engine-case, you must rotate release-lever so it engages rod in order for it to operate clutch. Also pressure-plate has dimple mark that must line up with outer clutch housing. Last futzed with by DannoXYZ; November 5th, 2020 at 10:42 PM. |
November 9th, 2020, 04:30 PM | #5 |
Oh WOW!! I knew it had to be something simple!! Thanks so much!!
November 21st, 2020, 05:25 PM | #6 |
Hello and welcome!
December 15th, 2020, 12:59 PM | #7 |
Welcome!
[webbikeworld.com] - Super Soco TSx Is the Cool Beginner Electric Motorcycle | Ninjette Newsbot | Motorcycling News | 0 | March 16th, 2020 06:11 AM |
[webbikeworld.com] - Here?s a Look at the New Electric Super Soco CUx Special Edition | Ninjette Newsbot | Motorcycling News | 0 | May 17th, 2019 05:26 AM |
[visordown.com] - Super Soco, the first electric bike maker to sell 100+ units in a y | Ninjette Newsbot | Motorcycling News | 0 | January 18th, 2019 11:03 AM |
2010 Ninja 250 race ready (STL) | Aodrn | Motorcycle-related | 9 | July 18th, 2014 12:21 PM |
Hello from STL | bcakd5 | New Members | 12 | September 19th, 2011 07:18 PM |
