Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old March 14th, 2012, 09:20 AM   #1
THE BIG SITT
THE BIG SITT's Avatar
I'm an IDIOT
Well I was working on the carbs and went out for a test ride when I was done. The bike still wasn't right, but it had been so long since I went out for a ride that I kept riding. Well I was going to fast through a turn in my neighborhood and wiped out. All in all, I'm fine, just a little rashed and bruised. But the bike seems screwed. The portion where the rearset bolts onto the bike itself seems bent. And I have no idea what the hell to do. Any advice would be great! Or donations for the incredible repair bill would be awesome… lol
Here's a pic of the damage:
THE BIG SITT is offline   Reply With Quote
Old March 14th, 2012, 09:37 AM   #2
pjed
pjed's Avatar
Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900
Sux to hear that...glad you're ok though. I've heard that the frame is the weakpoint in these bikes and will get damaged before the rearsets. Would think there's a way to bend it back. Maybe take it to a metal shop see what they say.
pjed is offline   Reply With Quote
Old March 14th, 2012, 10:13 AM   #3
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
Sorry to hear about your down, good that you didn't get really hurt or anything. I really don't have any advice about your bent frame part, but I can say mine bent there too yesterday.
My Mods | My Bike's Ninjette Thread
saxnbass is offline   Reply With Quote
Old March 14th, 2012, 10:30 AM   #4
Most people don't realize it, but those mounts bend in practically every drop. This became obvious in one of the threads about an aftermarket exhaust not fitting right.
I'd put some bolts in there and put some force on the bolts until you get them back where you want them. Tweaking the mounts isn't the same as tweaking the frame.
Old March 14th, 2012, 12:53 PM   #5
THE BIG SITT
Well I tried putting a bolt in there and using some vice grips to bend the mounts back. They seemed to bend a little but now the bolts are just bending. Any advice? Maybe use heat?
Old March 14th, 2012, 01:21 PM   #6
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Sorry to hear. Hope everything works out
Old March 14th, 2012, 02:10 PM   #7
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Don't use heat. Remove the swingarm and use an adjustable wrench clamped on to straighten, then wirebrush off loose paint and rust. Spray and clean with brake cleaner, then paint.
Old March 14th, 2012, 11:06 PM   #8
ProdigyRacingLA
ProdigyRacingLA's Avatar
Motorcycle(s): 2008 Ninja 250r Red
Sorry bout the down, glad your ok man.
*goes outside to compare picture*
Damn, I went down on the same side. Lowside around 20 mph. Damaged a lot of stuff.
Anyhow, did the gear shifter mechanism also break off I'd just the metal corner piece?
I would contact a dealer get an estimate or evaluation. Then decide wether to pay them to work on it. Or find parts online and diy. Second option is better but the first option is to get professional opinnion on what's wrong. The evaluation/ pricing w/ parts list needed is Free!
ProdigyRacingLA is offline   Reply With Quote
Old March 15th, 2012, 04:38 AM   #9
When I bent an upper fairing stay, I put the bolt back in and adjusted the wrench to fit over it (head to tip) and then straightened the stay. Easy-peasey.
Old March 20th, 2012, 11:15 AM   #10
THE BIG SITT
Two things:
1. The whole area isn't bent. It's more of just the threads/mounts/whatever. Would it be safe to get some heavy duty bolts and just go at it?
2. Noob question alert: If i were to remove the swingarm, how would I keep the bike upright?
Old March 23rd, 2012, 07:07 AM   #11
THE BIG SITT
Old March 23rd, 2012, 10:59 AM   #12
burningscooter
clutch
burningscooter's Avatar
Motorcycle(s): L1 GSXR600
Originally Posted by THE BIG SITT View Post
Two things:
If you have pegs that are aftermarket (non folding) you can use jack stands and palce them on top. Im sure you already thought of this though.
burningscooter is offline   Reply With Quote
Old March 24th, 2012, 07:05 AM   #13
THE BIG SITT
I did, but with one of the rearsets removed, I don't see that working
Old April 3rd, 2012, 03:51 PM   #14
Matz
is stunning! ;)
Matz's Avatar
Motorcycle(s): CBR600 FS2, XT350
Just where a roller skate on your left foot and be done with the rear set!
Sorry you crashed, what were you working on the carbs for?
It ain't a 250, one of the zeros is missing!
My Facebook and Youtube
Matz is offline   Reply With Quote
Old April 3rd, 2012, 04:11 PM   #15
THE BIG SITT
Because I had added a full exhaust over the winter to replace my SO. I eventually was able to get the mount bent back, so I rode to the dealer to let them have a go with the carbs, because I simply give up lol...
Old April 3rd, 2012, 04:22 PM   #16
Matz
is stunning! ;)
Matz's Avatar
Well at least your alright. I ordered my new exhaust yesterday it's made by a company in Britain called Pipeworx and it looks absolutely beautiful. It's just a slip-on although I was wanting a full system but nearly everything I could find was American and so didn't have anywhere to stick my Ninja's Fuel Injection oxygen sensor. Apparently your supposed to use bungs but it's seems a bit much just to make my bike LOUDER!
Old April 3rd, 2012, 04:47 PM   #17
jasle
Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L
My son has crashed twice. both times about 80mph low sides. bent the frame the same way both times. once I used the 12: adjustable wrench...other time I used a grade 8 bolt, put a pipe over it and bent it back. The threaded inserts are only held in the frame with 4 tack welds.
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles
jasle is offline   Reply With Quote
Old April 3rd, 2012, 05:43 PM   #18
THE BIG SITT
Thats interesting and slightly alarming at the same time. No wonder its such a cheap bike lol
Old April 4th, 2012, 08:11 PM   #19
leed
leed's Avatar
Motorcycle(s): Time will tell
It's better that way. This way when the bike falls on the rearsets, it bends/shears the spot welds instead of tweaking the frame!
Old June 3rd, 2012, 08:00 PM   #20
Only, it doesn't seem to be working out quite like that.
need help but i know im going to sound like an idiot txnili 1986 - 2007 Ninja 250R Tech Talk 16 February 14th, 2015 09:51 PM
I'm an idiot... nickjpass Off-Topic 5 July 27th, 2014 09:26 PM
Help! I'm an idiot! The Red Scourge 2008 - 2012 Ninja 250R Tech Talk 4 March 31st, 2014 05:41 AM
I'm an Idiot :( Ben M !%@*#$%!)@#&!%@ I crashed! 19 December 1st, 2012 08:35 PM
So... I'm an idiot. ryanG19 General Motorcycling Discussion 23 February 6th, 2012 07:02 AM
