June 25th, 2010, 09:12 PM | #1 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
Sportisimoto BRT Ignitions GB
I talked to BRT to get you guys a present. I need 5 people minimum $150.00 Shipped on the non programmable units. PM for Programmable pricing. GB Ends in one week.
Sportisimoto USA is born. |
June 26th, 2010, 12:28 AM | #2 |
self wrencher
sweet pricing.
btw matt, are you interested in becoming distrib for Shinto? I think paul is looking for a US distrib. Not sure if there is a conflict of interest b/t sportisi and shinto though... |
June 26th, 2010, 12:30 AM | #3 |
The Sportisi Master
I have talked to paul. And I have been mulling over the numbers to see whats doable.
June 26th, 2010, 12:39 AM | #4 |
self wrencher
He mentioned that you talked about it then all "silence"...
June 26th, 2010, 11:47 AM | #5 |
The Sportisi Master
1 member down 4 more guys
June 26th, 2010, 11:47 AM | #6 |
Join Date: Jun 2010 Motorcycle(s): 2009 Ninja 250R (street) / 2009 Ninja 250R (track) Posts: 55
I'm in for a Programmable! Thanks, Matt! Great price!
June 27th, 2010, 08:31 AM | #7 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
Count me in for a non-programmable.
June 27th, 2010, 06:48 PM | #8 |
Join Date: Dec 2009 Motorcycle(s): Ninja 250R Posts: 432
I'm definitely looking for more acceleration (power through all gears) or throttle response, not really looking for top end. Will this improve acceleration, how does this works? How much power are we looking with this BRT ignition?
How much is the programmable, pm me? |
June 27th, 2010, 09:41 PM | #9 |
The Sportisi Master
JR unless your racing I recommend to non programmable.
June 27th, 2010, 09:42 PM | #10 |
The Sportisi Master
Info is available on my site.
http://www.sportisimoto-usa.com/ignition.php
June 27th, 2010, 09:53 PM | #11 |
I won't be racing, I been reading some reviews about your product and it seems that improve throttle response. If this is true count me in for a non-programmable. I also read about the kick stand kill switch, do I loose it? I'm mainly interested to get a better acceleration or throttle response.
June 27th, 2010, 09:54 PM | #12 |
The Sportisi Master
yes better acceleration is a nice perk. The kill switch will no longer operate as it is bypassed.
June 27th, 2010, 09:55 PM | #13 |
The Sportisi Master
3 down 2 to go.
June 27th, 2010, 09:59 PM | #14 |
June 28th, 2010, 09:35 AM | #15 |
Join Date: Jun 2009 Motorcycle(s): 08 Ninja 250 Posts: 87
Count me in for a non-Programmable!
Puig Windscreen, Ebay Tire Hugger, Dynojet Kit, Woodcraft sub-frame sliders, K&N 0990 Air Filter, Fender Eliminator, Rear Solo Seat Cowl |
June 28th, 2010, 10:31 AM | #16 |
Join Date: Apr 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 114
Hi,
I have some questions about this product - I am a noob to bike mods so please forgive my ignorance. Is this similar to a "chip" or ECU mod for a car? (I had a GIAC ECU mod to adjust turbo boost psi for an '01 Audi S4) For the non-programmable - what is the difference between the two maps? If I have the CDI issue - (I'm not entirely sure I do) would installation of the product address it? If I were to install the original CDI - would the sidestand kill switch work? - In case I decide to sell the bike. Thanks! Ash |
June 28th, 2010, 10:59 AM | #17 |
The Sportisi Master
Yes the kick stand woul work if you were to use the stock cdi again. I haven't had any complaints of the rpms being screwed up with the units. The two maps are designed to have an aggressive map and a a slightly less aggressive map. Premium fuel is recommended.
June 28th, 2010, 11:07 AM | #18 |
Thanks for the fast response - put me down for one too.
June 28th, 2010, 12:55 PM | #19 |
Matt, When u ship this or my other goodies, can I get some just black and white stickers for the race bike (w&b) ? I seen it on a black vr exhaust. Thanks.
June 29th, 2010, 10:39 AM | #20 |
The Sportisi Master
If your in on this pm me your emails so I can send out paypal invoices.
June 29th, 2010, 11:17 AM | #21 |
PM Sent
June 29th, 2010, 11:40 AM | #22 |
PM sent
June 29th, 2010, 12:11 PM | #23 |
Pm sent
Posted via Mobile Device |
June 29th, 2010, 12:22 PM | #24 |
Pm Sent!
June 29th, 2010, 06:15 PM | #25 |
The Sportisi Master
Order is going out friday. So if you want to get one now is your chance.
June 30th, 2010, 09:18 PM | #26 |
Just courious. What is the timing curve look like compaired to the 94 and older dci box? And is there a way to adapt it to a pregen? What is the max timing?
June 30th, 2010, 09:26 PM | #27 |
The Sportisi Master
There is a way to adapt it but when you compare the maps while the brt tis has a slightly better map then the pregens its not worth the hassle or the extra cash.
July 1st, 2010, 06:23 AM | #28 |
Hey Matt, do you have a red hugger for my 08 250 available?
July 1st, 2010, 08:07 AM | #29 |
July 1st, 2010, 08:32 AM | #30 |
self wrencher
I think the BRT is more optimal since it's tuned with the 08 engine whereas the older cdi is for the older engine. BRT non prog has two maps for you to select.
July 1st, 2010, 08:38 AM | #31 |
Good - glad I'm getting one.
July 1st, 2010, 09:28 AM | #32 |
Just so you know, I haven't received any invoicve.
July 1st, 2010, 09:39 AM | #33 |
July 1st, 2010, 11:24 AM | #34 |
The Sportisi Master
Invoices will go out today.
Separately. The exhaust isn't ready just yet
July 1st, 2010, 11:32 AM | #35 |
What sort of time frame are we looking at?
July 1st, 2010, 11:36 AM | #36 |
The Sportisi Master
From order date to in your hands about 9 days.
July 1st, 2010, 11:37 AM | #37 |
Sweet...
July 1st, 2010, 11:51 AM | #38 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
So this unit come with a pre loaded map alredy? Plug and ride?
July 1st, 2010, 04:09 PM | #39 |
The Sportisi Master
yup
July 1st, 2010, 09:14 PM | #40 |
The Sportisi Master
Invoices sent out. Tomorrow is the final day of this GB. SO hurry
Where is Matt from Sportisimoto USA? | samw | Motorcycle-related | 25 | August 18th, 2012 12:50 PM |
Sportisimoto VR Carbon FSE | NathanUc | 2008 - 2012 Ninja 250R Farkles | 12 | July 28th, 2011 08:10 AM |
FS: Brand New Sportisimoto rear sets! | kogary | Motorcycle-related | 13 | July 25th, 2011 01:27 PM |
Sportisimoto-usa.com | ztrack157 | Motorcycle-related | 566 | July 9th, 2011 09:49 AM |
My Sportisimoto Bodywork | ztrack157 | Motorcycle-related | 6 | May 18th, 2011 02:39 PM |
