Old June 22nd, 2016, 02:08 PM   #1
Buffalony
Buffalony's Avatar
08-12 Water pump
Sup folks,
Are these water pumps rebuildable? I haven't found anything for rebuilding them. 180 for a new pump seems a bit steep. I found out that the weep hole on my 08 was plugged with what seems to be built up rust from the shaft. I'd like to take it apart to inspect it, but haven't found anything online showing how to do so for this bike. Seems like the impeller is pressed onto the shaft-end.
Thanks.
Old July 1st, 2016, 08:41 AM   #2
tubarney
what do you mean by weep hole?
The part of the pump with the impeller is sealed to prevent coolant leaking into engine cases.
Old July 1st, 2016, 03:17 PM   #3
Just buy a lightly used (<6,000 miles) one off ebay. That's the cheaper option and you're basically getting a new part at that point.
That's what I did. Works like a charm. I think the one I'm using on my pregen is off a newgen, IIRC. Bolts right up.
Old July 4th, 2016, 06:53 AM   #4
Buffalony
Buffalony's Avatar
Hey Tubarney,
At the bottom of the pump there is a tiny hole. It's located between the impeller and oil case end seals. It's for coolant to drip out of if it starts getting past the impeller seal.
Old July 4th, 2016, 06:57 AM   #5
Buffalony
Buffalony's Avatar
I just find it odd that the pump can't be torn down and rebuilt. The impeller seems pressed on. On other pumps I've rebuilt there was a nut on the impeller and rebuild kits available. Just seems a bit lame to have to replace the whole pump.
Does the newgen water pump fit the pregen bike? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 6 August 25th, 2013 09:49 PM
Indicators of water pump seal failure? Sipper' 1986 - 2007 Ninja 250R Tech Talk 6 April 9th, 2013 02:47 PM
[motorcycle.com] - SpeedyMoto EVO Ducati water pump housing Ninjette Newsbot Motorcycling News 0 May 1st, 2010 02:30 AM
