July 24th, 2012, 05:40 PM | #1 |
Are the newgen and pregen cranks the same?
Kawasaki is making things pretty difficult when it comes to cranks. They list different part numbers numbers for the pregens and newgens:
Years / part number / price 1988-2005 = 13031-1247 = $533 2006-2007 = 13031-0013 = $416 2008 = 13031-0112 = $437 2009-2010 = 13031-0120 = $437 From what I can tell, its a safe bet that the pregen cranks are interchangeable, but what about with the newgen cranks? Below are two photos of cranks. The Kawasaki specs say they use the same bearings and have the same size journals, but why do they have different part numbers? Pregen Crank Newgen Crank Anybody know what the difference is?
July 26th, 2012, 12:07 PM | #2 |
Sort of related here: are the cams from the 86-87 bike interchangeable? I know those had more top end and a cam swap is easy
Posted via Mobile Device |
July 26th, 2012, 12:27 PM | #3 |
dont know the difference but when you change to a new crank make sure you do a squish check on the clearance between the bearings you put in and the crank surface... they are matched to each other with pretty tight tolerance. i forget what its called but they make these little ink strip things that squish when you assemble it. if its too tight of a squish you have to get smaller (or maybe bigger depending) bearings surfaces or something
Newgen exhaust on pregen? | !!(0_o)!! | 1986 - 2007 Ninja 250R Tech Talk | 26 | April 16th, 2013 08:26 PM |
Track Bike: Pregen or Newgen? | Jiggles | Ninjettes At Speed | 16 | April 7th, 2013 09:24 AM |
pregen engine in newgen? | alex.s | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 19th, 2012 11:09 PM |
Pregen vs. Newgen | ambudriver | General Motorcycling Discussion | 7 | May 7th, 2011 07:36 PM |
Various farkles for sale (both newgen and pregen)... | Verus Cidere | Motorcycle-related | 15 | May 10th, 2010 02:27 PM |
