December 6th, 2014, 08:01 AM | #1 |
Join Date: Oct 2014 Motorcycle(s): 2009 Ninja 250r (FI) Posts: 16
Indicator Problem - Turn Signals Not Working
Hi guys,
A problem I found out last time I came to ride my bike was that none of the indicators / turn signals are working, not even the light on the dashboard. I checked the fuse just now which was absolutely fine, changed it for another one anyway and it fixed the problem (all indicators worked; everything back to normal, could hear the relay clicking on and off). Sprayed some electrical contact cleaner around the fuses, then realised that they stopped working again! Spent ages spraying contact cleaner, switching out fuses for new ones and could not get the indicators working again. Bought a new relay (not a direct replacement as it was 4 pin and slightly higher current rating compared to the stock 2 pin one, but the guy in the shop said it should work), and that didnt fix the problem. Wondering if you guys could point me in a new direction as to what could be wrong? Pretty sure its not the bulbs as all 4 worked momentarily. What I thought it could be: - Original relay is temperamental and the one the guy in the shop gave me is not the right one - Switch at handlebars is not working - Wiring somewhere (although I checked the connections into the fuse box and into the relay). Must point out I am using stock turn signals. Electrical problems extremely frustrating! Cheers for the help. |
December 6th, 2014, 08:13 AM | #2 | |
The second statement is easily verifiable by-passing the relay.
December 6th, 2014, 08:26 AM | #3 |
Thanks for response.
So if I bridge the connector which plugs into the relay with a small piece of wire, should this show if it is the relay which is the problem (ie if all lights come on, it is the relay. If no lights come on, then it is probably a problem with the wiring, especially as the relay was working earlier)? I'll have another check over the connectors into the fuse box and into the relay. |
December 6th, 2014, 09:45 AM | #4 | |
Take a look at the circuit: http://faq.ninja250.org/wiki/Wiring_...s_%26_diagrams
December 6th, 2014, 09:49 AM | #5 |
And get the proper turn indicator relay
December 7th, 2014, 06:32 AM | #6 |
Wiring diagram helped a lot, thanks.
Just went out to the bike now and traced each wire and found the fault to be at the ignition barrel. Managed to get the indicators flashing with the existing relay by simply moving the thick cable that comes out of the ignition barrel, so they are working for the time being. In terms of cutting open the thick heatshrink that is holding together all of the cables to get access to the wire for the indicators, is there an easier way of getting to the cables through the back of the lock barrel? To be honest I don't really want to go about dismantling the lock barrel. Also noticed that the heat shrink containing all of the wires from the ignition barrel is zip tied to one side right after the point where it exits the bottom of the ignition barrel. Is it common for Kawasaki to use zip ties in the factory or is this is a sign that someone has been in there before me? Cheers for help guys, solving the problem slowly! |
December 7th, 2014, 09:56 AM | #7 | |
I don't know about the zip tie. You may find some useful information in this article: http://faq.ninja250.org/wiki/How_to_...gnition_switch
Turn signals went out and the dash indicator as well | charliegod | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 24th, 2014 04:33 PM |
Turn Signal indicator problem! | Kevin2109 | 2008 - 2012 Ninja 250R Tech Talk | 12 | March 22nd, 2014 09:17 PM |
Turn Signals not working correctly | aspenratt07 | 1986 - 2007 Ninja 250R Tech Talk | 5 | April 1st, 2013 08:46 PM |
turn light indicator stopped working... | DaMan22 | 2008 - 2012 Ninja 250R Farkles | 6 | July 26th, 2012 07:52 PM |
Turn Signals Stopped Working! | DisciplesHeart | 2008 - 2012 Ninja 250R Tech Talk | 18 | March 21st, 2012 08:45 PM |
