February 16th, 2013, 04:34 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Low Beam Good, High Beam dead
I was looking at the schematics to the headlight and it seems as if there are 2 bulbs (high and low) on the diagram but after some research this isn't the case. Now I'm curious why when I switch to my highbeam it turns the bulb off while the lowbeam runs fine?
February 16th, 2013, 04:37 PM | #2 |
It uses an H4 bulb, which has 2 filaments; one for low, one for high. It only runs one filament at a time, either low or high.
So basically, your high beam filament is burnt out. Get a new bulb. PS: I think you're referencing a wiring schematic for the 08-12 bikes. Those have 2 headlight bulbs. |
February 16th, 2013, 04:45 PM | #3 |
Is it a common part I can pick up at an auto shop or do I have to order this? Kneedraggers is all out....
February 16th, 2013, 05:03 PM | #4 |
It's just a standard H4 bulb. They can be found at any auto parts store, or Walmart.
February 21st, 2013, 03:44 PM | #5 |
They also have it at harbor freight. Whatever one you get, don't get the super bright ultra halogen bulbs (varying nomenclature). Just get the standard el cheapo ones they hide from you. The super brights get too hot, take too much power, don't last very long, and cost a lot more. I've seen them damage the wiring on cars before because they draw too much power and get too hot.
low beam or high beam brighter? only choose one | passive101 | General Motorcycling Discussion | 3 | July 26th, 2013 06:27 AM |
make high beam into low beam? | DaMan22 | 2008 - 2012 Ninja 250R Farkles | 2 | July 12th, 2012 06:34 PM |
HID Low and High Beam | Pudge Ate Me | 2008 - 2012 Ninja 250R Farkles | 7 | November 29th, 2011 09:52 AM |
