Old August 17th, 2009, 09:55 PM   #1
redbike
Motorcycle(s): ninja 250
power loss while accelerating hard
When I accelerate hard in first gear, my motorcycle loses power for a second. The engine will make less noise and I will slow down.
Does anyone know what could be the problem?
I was reading the CDI thing but I only notice problems in first gear when I try to accelerate hard. If I accelerate slowly, everything seems fine.
I'm worry it could my the clutch or the gear or something. But my bike is 09 and fairly new. I'm not sure that is problem.
Any ideas would be appreciated.
redbike is offline   Reply With Quote
Old August 17th, 2009, 10:26 PM   #2
Postiez
Postiez's Avatar
Motorcycle(s): Red '08 250
Is your bike cold when this happens?
Postiez is offline   Reply With Quote
Old August 17th, 2009, 10:32 PM   #3
how high is the tach reading when this happens?
Old August 17th, 2009, 10:35 PM   #4
redbike
I try to accelerate slowly but i should still happen when it is warm. It does seem a little more likely to happen when i start my bike.
I'll test it when it is warm.
Old August 17th, 2009, 10:38 PM   #5
Postiez
Postiez's Avatar
Ya give that a try, even on a warm day if i dont let my bike warm up for a bit that will happen to me
Old August 17th, 2009, 10:51 PM   #6
shporsche
shporsche's Avatar
Motorcycle(s): Ninja 250 09
Yup that happens to me when the bike is cold.
Not fun when trying to cross a intersection and the bike wont move fast to get through the gap.
shporsche is offline   Reply With Quote
Old August 17th, 2009, 10:53 PM   #7
Postiez
Postiez's Avatar
haha ya, my house leads right out onto a main highway, bad times
Old August 18th, 2009, 10:25 PM   #8
redbike
thanks for the help.
i tried accelerating when my bike is warm. it is better. but it does seems like i have low power for the first little bit. I don't know if it is because the RPM is low or because it is the same problem.
It still seems a bit slow in the first .2 seconds
Old August 18th, 2009, 10:35 PM   #9
so, the bike acts like it stutters or stalls for a few tenths of a second and then "catches" when in the lower rpms (idle to 4000rpm)?
Old August 20th, 2009, 02:02 PM   #10
redbike
yes. it seems slower at first. but maybe it is in my head
I have an aftermarket exhaust. I don't think my bike has a jet kit. do you think that could be an issue?
Old August 20th, 2009, 02:04 PM   #11
lol... I'm still trying to get a clear picture of what the issue is.
mind starting over for a slow old guy?
Old August 20th, 2009, 02:18 PM   #12
demp
aftermarket exhaust, has it been re-jetted? I only bring that up because if your bike was running lean, and was cold, I can certainly see this being an issue, (I'm no expert, but I thought I'd ask the question )
Old August 20th, 2009, 02:23 PM   #13
redbike
no problem kkim.
I guess the only problem is that when i turn the throttle a lot in first gear, sometimes my engine gets very weak. So when i'm in first gear with no throttle and i crack it, instead of going faster, i kind of go slower.
As Postiez said, it is probably because i didn't warm up my engine long enough. It kind sucks. I think i need to warm up my bike quite a bit before the problem is gone.
Old August 20th, 2009, 02:31 PM   #14
okay... gotcha.
these bikes do take a long while to warm up. I'd say on the order of 5-10 minutes. If not fully warmed, they can stall and sputter when trying to take off from a stop.
The bikes come lean from the factory which leads to this cold blooded nature. Add to that the fact that the bikes are not always setup the same way when it comes to carb tuning (quality control) and you have some bikes worse that others when it comes to being lean from the factory.
My advice is to shim the carb needles to richen up the mixture a bit.
http://www.ninjette.org/forums/showthread.php?t=9465&
You can also ride off with the choke partially engaged during the first 5-10 minutes to richen up the mixture... just don't forget to turn it off once your bike is fully warmed up on the road.
Old August 20th, 2009, 03:06 PM   #15
g21-30
g21-30's Avatar
Many people think of a "choke" as a plate over the carb, which restricts the air intake; thereby causing a lower air/fuel ration....more gas in relation to the air.
On our bikes, the "choke" is just another jet, which allows gas into the carb. You might say it's like simulating "shimming" the needles. If it helps you to control the bike, prior to total warmup, why not do it (choke it). After the bike is warmed up and more responsive, turn the choke off.
Old August 20th, 2009, 04:01 PM   #16
demp
Question, can you actually damage the bike if you left the choke on? (I don't... I'm just curious)
Old August 20th, 2009, 05:36 PM   #17
some believe you can... I'm not one of them.
Old August 20th, 2009, 08:28 PM   #18
g21-30
g21-30's Avatar
Old August 23rd, 2009, 07:34 AM   #19
Greg_E
Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R
The choke is normally a plate that causes higher vacuum in the carb which pulls extra fuel into the mixture, so an extra jet that does the same thing would be a better idea.
Greg_E is offline   Reply With Quote
Old August 24th, 2009, 08:54 PM   #20
Ntotot
Ntotot's Avatar
Motorcycle(s): 08 Black Ninja 205r - SOLD, Now -> a Z750
it won't damage the bike but you will have difficulties starting the engine later on because of the gas/petrol flooding in the combustion chamber.
i won't spoil my bike with choking when cold... just leave her for 2-5 minutes while having a can of coke/stick of cigarette before making my journey.
Ntotot is offline   Reply With Quote
Old August 24th, 2009, 09:26 PM   #21
Momaru
Momaru's Avatar
Hmmm, wonder if this is any way related to my bike feeling like it bogs when I grab a handful of throttle from a dead stop, no matter how warm or cold the bike. The first half second seems like the engine's not sure what's going on and rev's drop from idle a bit, then life on the 250 resumes as the engine tops ~4k (will have to try it a few times while really paying attention to confirm that number).
Of course, I'm not sure how the needles are shimmed atm, but I know they are the dynojet needles. Haven't messed with 'em since I bought the bike because, other than me trying to take off from a stop like a budding squid, bike seems happy. Will probably take a look at 'em soon.
Proud member of the Blue Army
Old March 8th, 2010, 06:22 PM   #22
Timm3h
This is the exact same issue that I am having as well. I am not trying to bring a thread back from the dead, but did anyone find a solution? I have shimmed needles 2 washers, no snorkle, clean carbs, drained tank, replaced gas
Timm3h is offline   Reply With Quote
Old March 8th, 2010, 10:20 PM   #23
fujimumu
fujimumu's Avatar
Motorcycle(s): Blue 2009 Ninja 250R
Make sure your bike is warmed up before you try to go WOT from a dead stop. You can also try to rev the bike up more slowly at first and let the clutch out with the rpm's around 5-6k
fujimumu is offline   Reply With Quote
Old March 9th, 2010, 01:26 AM   #24
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
One night when I took the bike out last summer, it was like I was hitting a dead zone in the rpm range. It was weird, it would pull hard until about 4k, then it would bog until 7k then take off again. It did that through out the whole ride, then never did it again.
I've had quite a few little quirks like that, such as my speedo not working properly one morning, an afternoon ride where the right turn signal was not working, ect. The issues always seem to resolve themselves though.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink
Cedilla is offline   Reply With Quote
Old May 17th, 2010, 07:29 PM   #25
alexit69
alexit69's Avatar
Motorcycle(s): Black Ninja 250r
bump on this thread
I'm having the exact problems, but it's happening every time I ride. It'll be more pronounced when I first ride off but it's less obvious as I ride along.
This happens more notably in first and a little in 2nd... At around 4000 Rpm, the engine stops pulling even if I crank the throttle a little more. At this point, the tach goes up real slowly and at around 7000 rpm, it catches on again and gives me the usual power. So between 4 and 7000 rpm, i'm literally slowing down and cars are passing me... it's not good for starting from red lights....
After i get off the highway (engine fully warmed) I still feel that around these tach readings, there's a slight loss of power although less pronounced than the times i first leave my starting point.
Maybe it's bc i put too much Seafoam in the batch of gas... someone in another post warned me abt this earlier today, but I don't know if that's the direct effect of putting too much Seafoam in a tank. I'll drain out the gas and put a fresh batch to see if that's the source of my problem.
Somebody has insight on this? How did you fix your problem Redbike and Tim? Thanks everyone
alexit69 is offline   Reply With Quote
Old May 17th, 2010, 07:50 PM   #26
fujimumu
fujimumu's Avatar
I'm not quite sure its a loss of power in that RPM range more than a lack of power that the 250 makes. For me sometimes it seems like opening the throttle too wide in low RPMs makes it harder for the engine to rev up. I usually try to keep the engine running around 6000 RPM and rev to about 4000 while letting the clutch out to get moving from a stop.
Old June 7th, 2010, 08:11 PM   #27
Momaru
Momaru's Avatar
Originally Posted by alexit69 View Post
bump on this thread
Any news? Sounds to me like perhaps a bad batch of gas/hiccup for Chris (esp if it resolved after that ride). However yours may be too lean in the midrange. Have you shimmed your needles at all? My try adding a shim or two to richen things up a little.
Regarding too much Seafoam; if you just top off your tank it'll dilute the Seafoam and should fix the issue (if that's it) after a gallon or so, unless you put WAY too much in.
Old June 8th, 2010, 08:21 AM   #28
alexit69
alexit69's Avatar
problem solved... more or less
Hey Mo, sorry i haven't updated my reports yet.
I topped off the tank instead of draining it completely and the problems seems to have been solved (prolly too much Seafoam). However, I think i'll need to shim the needles since I get some hesitation when I cold start the bike and it wears off as the engine gets to riding temp. Lemme describe: when i start the bike after a long rest and start riding, it seems to want to choke when I get on the gas (esp when I give it more gas) AND it doesn't want to rev over 6-7K rpm, but this only happens after i start the bike. After 2-3 min, everything is back to normal. Needless to say, I do warm up the bike while i'm gearing up (abt 1 min or so). I'll shim the needles and remove snorkel and hope to resolve this hesitation after cold starts.
Do you think this'll solve the hesitations or should i just let the bike warm up a lil longer? (I'll prolly shim anyways but just wanted to know the source of this prob)
Old June 8th, 2010, 10:53 AM   #29
fenwaynomar45
Greenman!
fenwaynomar45's Avatar
the same thing happened to my bike last night scared me when my headlights lost power. I thought it was because it was cold but 25 minutes into the ride it still did it
fenwaynomar45 is offline   Reply With Quote
Old June 8th, 2010, 11:25 AM   #30
Momaru
Momaru's Avatar
That sounds like a loose electrical connection to me, unless your bike was also acting strange. Even then, I'd suggest checking electricals.
Old June 8th, 2010, 11:45 AM   #31
Momaru
Momaru's Avatar
Glad to hear that was most of it and you salvaged the tank-full. Gas is expendable, but still sucks wasting it.
A jetting problem that gets better as the bike warms up usually indicates a lean condition. Shimming the needles and/or backing the mixture screws out will richen the mid and low power bands respectively (which carb part works where in the band is considerably more complicated than that, but that's the short version). Removing the snorkel will allow more airflow thereby 'leaning' the air/fuel mixture. If you decide to adjust the carbs, I'd suggest pulling the snorkel first as that will impact your final tuning setting.
Old June 8th, 2010, 09:03 PM   #32
alexit69
alexit69's Avatar
thanks for the tip! I'll prolly be doing that this week!
Old June 28th, 2010, 05:00 PM   #33
omnivore
omnivore's Avatar
Motorcycle(s): CBR Fireblade, KTM 950SM, YZF750 (x2), R6, ZZR250, XR200, KTM 50SX Sr.Pro, Honda Spree
Riding with choke on will also foul plugs sooner, and possibly result in deposits in combustion chambers and on valves if done for long time.
Your issue could be fuel filter or kinked fuel line. Sounds like fuel delivery issue to me.
KTM 950 SM,YZF 750 Street, CBR929 EnduranceBike,YZF 750 vintage racer, R6 racebike , SOAR #22
omnivore is offline   Reply With Quote
Power hesitation when accelerating? mrb 2008 - 2012 Ninja 250R Tech Talk 17 December 5th, 2013 02:35 PM
loss of power reignman 1986 - 2007 Ninja 250R Tech Talk 7 June 1st, 2013 04:04 AM
Loss of power, but I think I know why... rmorse 2008 - 2012 Ninja 250R Tech Talk 1 August 13th, 2012 08:16 AM
Loss of power? oblivion007 2008 - 2012 Ninja 250R Tech Talk 2 June 4th, 2011 08:07 PM
Loss of power on highway (all the power) aldenso 2008 - 2012 Ninja 250R Tech Talk 10 May 7th, 2011 10:27 PM
