March 9th, 2013, 11:04 AM | #1 |
Join Date: Mar 2013 Motorcycle(s): Kawasaki Ninja 250, Kawasaki 650 Posts: 113
Headlight Retrofit Question
Hey guys, I'm new to this so sorry if I am doing something wrong with posting. I am doing a DIY retrofit for my 2011 Ninja. I ordered projectors and 6000k HIDS. My question is... I am in the process of doing this and I know some people spray paint the reflective housing black to make it look cooler since they are putting projectors in. I just wanna make sure I'm being safe, so spray painting the reflective housing is ok right? Since I am putting projectors in and the reflective housing isn't needed..or is it. Thanks in advance
March 9th, 2013, 11:14 AM | #2 |
Welcome to the site, Jake !!!
Please, post all you want ! Sorry, I cannot help you with your question, but somebody soon will.
March 9th, 2013, 11:45 AM | #3 |
ok thanks
March 9th, 2013, 11:56 AM | #5 |
Fast-Guy wannabe
MOTM - Jan '13
Your safe if you are indeed installing projectors(heavy solid glass half domes) and not just HID bulbs. Honestly most of us that have gone the route of projectors couldn't use the reflector housing a d had to ditch it and use a whole new mounting plate. How this help don't hesitate to ask a question. And good luck with the project because when don't right its a ****ing nightmare if your a perfectionist like myself.
March 9th, 2013, 12:04 PM | #6 |
Thanks Jason. yes I got projectors along with the hids. As we speak I am trying to seperate the headlight from the reflector. It's a bitch but Im getting there..hope this turns out well. I purchased Matte black spray paint ( high heat tolerance..meant for BBQ's) so I think that should work.
March 9th, 2013, 12:10 PM | #7 |
Fast-Guy wannabe
MOTM - Jan '13
What brand of projector did you get? I know they vary in size quite a bit.
If you haven't already read this http://www.audiotether.com/250RHID/250RHIDretrofit.htm I used most of tri's ideas and few of my own to get the results I wanted. |
March 9th, 2013, 12:13 PM | #8 |
I went through bkmoto. The guy sells kits for lots of bikes, and they have a step by step with picture instruction set so you can do it yourself. I am not sure the projector size
March 9th, 2013, 12:18 PM | #9 |
The link you gave me has a great idea with creating your own mounting plate. But it seems like a lot of work, is there really any advantage to that? I was just gonna use the one I have now from stock and paint it, because I know the projectors I have will fit in there.
March 9th, 2013, 12:32 PM | #10 |
Fast-Guy wannabe
MOTM - Jan '13
Bks stuff is much small I believe I have my doubts of the output compared to what I have but I can almost garentee their stuff is much easier to install and quite bright as well.
March 9th, 2013, 12:35 PM | #11 |
Now you kind of have me worried. I am trying to be safe and be very noticeable, you say yours might be brighter which may be true, but would you agree that even though bk's may be smaller, they are going to be brighter than your typical stock halogen lights that come on the ninja? All I am aiming for is to be better than stock, I just want an improvement.
March 9th, 2013, 12:41 PM | #12 |
Also, I just measured the projector itself, and it looks to be 2.5 inches across, including the angel eye rim.
March 9th, 2013, 12:53 PM | #13 |
Fast-Guy wannabe
MOTM - Jan '13
The bk guy swears his stuff is good but I've never seen it in person but I recall there being a thread by him about his stuff and there was supposed to be some lighting shots but after a week or so I gave up wait for the picks so I don't know him he ever got them posted.
My dad tried to go the plug and play $250-300 route with his F-250 after seeing the results of my bike(yes their that impressive ) but when we plugged the kit in it was so laughably weak that I swore he plugged it in wrong. After confirming the kit was crap and the zero customer support we sent the stuff back and he ordered what I had. My dad originally ask me if he ordered what I got would I help him install it, I said NO so fast his head spun in the end after lots of F-bombs and many late nights he light look and function great. I happened to be around when a coworker asked if he'd help her do the same thing he did to her car and without hesitation a resounding NO was his answer Sounds like your already comitted to what you have but if your having any doubts then plug the stuff in before I stalling it and check their output. It should be fairly obvious if thier brighter then stock. I'm not trying to knock the BK stuff at all Im just saying what I have is great and I've never seen the BK stuff in person. |
March 9th, 2013, 01:00 PM | #14 | |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
http://www.ninjette.org/forums/showt...ght=projectors |
March 9th, 2013, 01:00 PM | #15 |
Ok, I will keep posted on how it turns out. hopefully I will have this done by tomorrow. I think it should be somewhat of an improvement from stock because when driving at night only one bulb is on because I dont drive at night with brights, and this kit will let me have both running on at low beam. I will try and do pictures to show how it turns out.
March 9th, 2013, 01:01 PM | #16 |
Yes I do believe those are bk moto lights. That is what is posted on their website under installation for the lights I got. Those look like they have turned out very well.
March 9th, 2013, 01:02 PM | #17 |
Even if Jason's are brighter than those, i think we can all agree those seem to have a really nice output, at least compared to stock.
March 9th, 2013, 01:04 PM | #18 |
Fast-Guy wannabe
MOTM - Jan '13
Yeah see his pics prove his stuff is bright I never doubted their stuff for a moment
Here's one pic of how mine turned out |
March 9th, 2013, 01:06 PM | #19 |
Yep. As much interstate riding as I do/have done on my 250, I think this upgrade would have been well worth it early on. The low beam hardly reaches the edges of the road, but I don't want to blind people with my high beams so...yeah, precarious situation. Not to mention the interstate I ride is edged with woods, so deer would be a problem.
March 9th, 2013, 01:11 PM | #20 |
I just live in a city, my main reason for the hid projector upgrade was to be more safe and make it look cool. Where I am, drivers are bad, there was a kid just killed the other week. People just don't look. I am trying to light my bike up like a ****ing christmas tree so people can see me easily. I have put blue leds all over it as well, If I have to pay a ticket, so be it. At least I'll live to pay it.
March 9th, 2013, 01:17 PM | #21 |
Get as much reflective stuff as possible too. Wheel strips are a good start if you haven't already, I've also thought about getting some reflective tape from cyclegear to put on my helmet and anywhere else.
March 9th, 2013, 01:21 PM | #22 |
Already got stuff on my wheels. If you don't care about the risk of getting pulled over, check out ebay. They have little blue led clips you can purchase for a few bucks. They take watch batteries and you can put them anywhere on your bike. From behind I look like a cop ( at least here in arizona) because I have a blue led near my brake light and when people see blue and red it catches there eye. And if you want some good reflective stuff, check out white high viz grade reflective tape. I got some and holy **** it reflective, At night time with a light on it is super bright so i put some of that on my backpack. Also my helmet and bike is white. I try to avoid black gear because it's harder to see plus here in az, it gets deathly hot in black.
March 9th, 2013, 01:28 PM | #23 |
Yeah this reflective tape I'm referring to is high vis. I already have blue LEDs for my plate lights, and they're legal here. I know some states require a white or amber colored plate light but not here :P
March 9th, 2013, 01:31 PM | #24 |
Nice man, that looks dope. do you have any other advice for lighting? I saw on ebay they have little mini xenon lights you can wire and have them on the front part of your bike to add additional light to oncoming traffic. Not sure if I should do it yet or if it'll even make a difference.
March 9th, 2013, 01:35 PM | #25 |
I have no idea, I'm not an electrical (or mechanical) guru. Maybe some of those LED strips to give your bike the audi-style headlight look. Or just literally wrap your bike in Christmas tree lights :P
March 9th, 2013, 01:36 PM | #26 |
ok well thanks, ride safe
April 2nd, 2013, 02:21 PM | #27 |
Join Date: Oct 2012 Motorcycle(s): '09 Ninjette (Black(and some blue)) Posts: 25
I used Vinyl
I had some carbon fibre look Vinyl lying around at home, and used that to cover the reflector.
So far, after 3 months of heavy use, the Vinyl is still working, and hasn't bubbled or anything. I figured it would be easier to remove than paint if I ever needed to return the headlight to stock |
April 2nd, 2013, 02:23 PM | #28 | |
April 4th, 2013, 12:40 PM | #29 |
UPDATE: After installing the kit a few weeks ago everything was perfect. Until today while washing my bike I look at the headlight and notice the two Angel eye rings have literally popped off the headlight projectors and are sitting in my headlight. I don't know why this would have happened, I don't ride my bike rough and I slow down at speed bumps. Nothing out of the ordinary...
So I'm pretty pissed because I would have to take my bike all apart again and RE-SEPERATE the headlight from lens all over again in order to get the rings out. Any ideas why this would have happened?! |
April 4th, 2013, 12:41 PM | #30 |
They are molting.
April 4th, 2013, 12:46 PM | #31 |
Use epoxy this time.
I'm not sold on BKmoto projectors. I've never used them, so I don't mean to slam them, but they seem awfully involved. Simpler is better when it comes to taking your headlight apart for a retrofit. |
April 4th, 2013, 12:50 PM | #32 |
I didn't use anything to hold them on. When I purchased the projectors the rings were already connected to the projectors itself. ****. I really don't want to re-do this whole separating lens from headlight **** again.
April 4th, 2013, 01:28 PM | #33 |
Fast-Guy wannabe
MOTM - Jan '13
Haha welcome to the world of retro-retro-retrofitting
April 4th, 2013, 01:33 PM | #34 |
If it's any consolation, I need to take mine apart and use some butyl tape on the lens so it seals and doesn't steam up. I also plan on making a foreground limiter while I'm in there.
I feel like I'm never done with my bike between the fuel tuning, and the random parts I have on there |
April 4th, 2013, 02:01 PM | #35 |
Ug alright. Well it won't be bad if I leave it be for now right?I'm gonna be busy for a week or two before I can do this so they're just gonna sit in there. I kind rocked my bike back and forth and they didn't seem to budge too easily. Just looks dumb..
April 4th, 2013, 02:09 PM | #36 |
Fast-Guy wannabe
MOTM - Jan '13
Play it off like a BOSS and before you know it all the cool kids will be doing it.
April 4th, 2013, 02:17 PM | #37 |
Just like the tire cord threads.
Headlight question | MrAtom | 1986 - 2007 Ninja 250R Tech Talk | 4 | October 22nd, 2014 10:34 PM |
Headlight Retrofit Question | 2fidyswag | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 13th, 2013 01:43 PM |
Headlight bulb question | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 22nd, 2012 08:11 PM |
Headlight question | Malicious Logic | 2008 - 2012 Ninja 250R Tech Talk | 8 | September 10th, 2012 07:36 PM |
Headlight Question. | BSNinja250 | 2008 - 2012 Ninja 250R Farkles | 11 | January 20th, 2010 10:24 AM |
