Old August 30th, 2014, 02:40 PM   #1
SmithSwede
Motorcycle(s): 2007 BMW F800S; 2012 Ninja 250; 2013 Moto Guzzi V7 Stone, 2016 Triumph Street Triple Rx; 1996 Ducati 900 SS CR
High Speed Miss Under Load
Any suggestions?
2012 Ninja 250 with 26,000 miles. Was running fine until problem suddenly developed.
Problem: bike starts missing and bucking under load over about 7000 rpm. This occurs if I try to go over 60 mph. Also occurs if I open throttle way open in lower gears.
Not a problem: bike starts and idles fine. Bike run fine at moderate throttle openings up to about 50 mph. In neutral (no load) bike will rev freely up to redline with no missing.
Bike is regular commuter (100 miles a day). I never leave it sit more than two weeks without doing a 100 mi commute.
What has not fixed it:
Valves adjusted to spec. Air cleaner ok. New spark plugs installed with correct gap. Bought used ECU and swapped. No change. Bought used coils--swapped and no change.
I went through and cleaned all connectors with DeoxIT. All wires and connectors appear sound. There is a good ground. Battery is one year old and fully charged.
Problem exists if bike run with gas cap open (no tank vacuum). Doesn't help if petcock set to prime. Does not help if choke applied while engine missing.
Maybe the pick up coil? (But tach works fine and it will rev to read line in neutral)
Maybe a clogged jet? (But I hate to tamper with carbs and don't see how this could occur on bike run regularly with good fuel)
Overheating a clue??? A few weeks before this missing occurred, the bike would overheat after long freeway run when I was in slow urban traffic. Problem was mud dauber nest on radiator fan preventing rotation and blowing fuse. That's fixed; does not overheat anymore. I would not think these two problems were related, but I'm suspicious because the missing started shortly after the overheat issues.
But how would they be related?
SmithSwede is offline   Reply With Quote
Old August 30th, 2014, 04:01 PM   #2
C-Bass
C-Bass's Avatar
Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE
Sounds like it could be possible valve trouble?
C-Bass is offline   Reply With Quote
Old August 30th, 2014, 04:51 PM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Bad plug wire?
Flat cam lobe? Probably would have noticed that when checking valve clearances, though.
Old August 31st, 2014, 07:46 AM   #4
nbleak21
Motorcycle(s): '09 Ninja 250r
Have you done a compression check?
nbleak21 is offline   Reply With Quote
Old August 31st, 2014, 08:32 AM   #5
cuong-nutz
cuong-nutz's Avatar
How did you know it was overheating?
Did you notice any coolant loss?
Contaminated coolant or oil?
Compression test?
How did your spark plugs look before you replaced it? How are the new ones looking?
No dry rotted vacuum hoses?
HalfFast Racing Team
Old September 3rd, 2014, 07:14 AM   #6
JordanB08
Motorcycle(s): 08 Ninja 250
Im having the same issue with my 08. Is your top speed around 70?
On my bike, in 6th, I cant get it past 9K-10K. It bucks, just like your describing, on all gears except neutral. If i find anything ill be sure to past back here! This issue is killing me!!
JordanB08 is offline   Reply With Quote
Old September 3rd, 2014, 08:21 AM   #7
Seems like the slides may not be lifting properly. I'd reach inside the airbox and lift/drop the slides to make sure they are moving freely. Next step may be to remove and check the diaphragms for damage.
Are both pipes the same temp?
Have you had the carbs off?
Any chance there could be significant moisture sitting in the bottom of the tank? Have you drained the floatbowls and looked at the fuel? You could dump the tank and refill with fresh gas from another location. Bad gas can give you those symptoms as well.
Old September 3rd, 2014, 08:41 AM   #8
JordanB08
Sooooo 30 mins or so after my post I checked more forums. There was a gentlemen who had kind of the same issue. He was complaining of his bike reaching 8K rpms but not being able to go further then that.
http://www.newninja.com/forums/f97/8...er-6777-6.html
TL;DR On page 6, the issue was that his girlfriend left gummy bears under the seat and it clogged up his snorkel leading to the air box. After clearing that up he found that his issue was resolved.
I was having similar issues. I went to my air box and found that the snorkel got removed from its spot and part of it pinched closed. I removed the snorkel so it has proper air for the mixture and now it pulls excellent all the way to red line. Ill be rejetting this afternoon too!!!
So, if you think its worth checking, i would check your air box and snorkel to see if its clogged, pinched, or something similar.
Cheers
http://www.kawiforums.com/ninja-250r...g-snorkel.html
Old September 3rd, 2014, 10:18 AM   #9
SmithSwede
thanks for all the tips! Been too busy at work to investigate further. Will definitely do a compression check.
As to the various questions:
On my bike, it won't go past about 55 or 60 mph.
There is nothing obviously wrong on the intake side based on external observation. No missing or pinched hoses, nothing dry rotted, everything seems tight and in the right place.
Good idea about checking inside the air box for blockage, and ensuring the slides work ok.
I know it overheated because the overheat light would come on. Then I discovered a huge mud dauber nest on the radiator fan that prevented its rotation (and caused that fuse to blow). Once that was fixed, it would not overhead.
I've drained a lot of fuel--it's pretty fresh and doesn't seem to have water in it. That transferred fuel worked ok in a riding mower.
Old September 3rd, 2014, 12:11 PM   #10
Try pulling out the snorkel...
Old September 3rd, 2014, 03:02 PM   #11
JordanB08
Jkv45 knows what I'm talkin bout!!
Old September 3rd, 2014, 03:32 PM   #12
i'm putting $5 on an animal in the airbox
Old September 3rd, 2014, 04:02 PM   #13
JordanB08
I got 5 on gummy bears
Old September 13th, 2014, 02:35 PM   #14
SmithSwede
Thanks guys!! Turned out there was a &$:@$ mud dauber built a nest in the lower snorkel channel. Once removed, it now runs like a top.
So the bugs got me twice. They jammed my radiator fan with a nest, leading to overheating in urban traffic. Fixed that, no more overheating, ran fine at high speed.
Couple weeks later, they got my snorkel, causing the high speed miss.
Old September 13th, 2014, 07:48 PM   #15
JordanB08
Glad to hear its all worked out. I need to know though, were they any mud dabbers in the nest when you took it out?
Old September 14th, 2014, 06:44 AM   #16
SmithSwede
Well, I'm afraid that some insects may have been harmed in the production of this scene from my life. I actually kept the nest--will probably frame it for my shop. But no sign of life.
I've now researched these creatures. They drink nectar from flowers and eat spiders. Indeed, their nests are filled with paralyzed spiders. Female finds spiders, stings them into paralysis but doesn't kill them, then stuffs dozens of these zombie spiders into the nest along with her eggs. Hatching larvae then eat the spiders.
Also turns out they are a well known problem for machinery. At least 3 airplane crashes have been caused by mud daubers building nest in pitot tubes, which then interferes with accuracy of air speed gauges.
FS: Speed and Strength Lock and Load leather gloves. ninjamunky85 Gear-related 0 July 22nd, 2013 08:57 AM
Struggling with High Speed Curves Minikin_Jo Riding Skills 9 December 6th, 2012 11:43 AM
High Speed Braking akima Riding Skills 36 February 20th, 2012 01:47 PM
high speed + wind onizthegnome Riding Skills 26 June 19th, 2011 10:54 PM
[topix.net] - high speed internet Ninjette Newsbot Motorcycling News 0 December 19th, 2010 12:21 AM
