Old May 15th, 2009, 08:50 AM   #1
tjkamper
tjkamper's Avatar
Lighting for Fender Chop.
I'm looking at doing a fender chop, but I don't know how to wire a light for the license plate.
Has anyone done this with a light or is everyone riding arround illegal?
Thanks?
Old May 15th, 2009, 10:55 AM   #2
gizmogamez
gizmogamez's Avatar
Motorcycle(s): 2009 Ninja 250R SE Green
the lights are very eays. should just be 2 wires (a hot and a nuteral) any light you add when you do the chop will wire the same.
If you go with LED lights there might be a little more work if the light does not come with a resistor already installed.
gizmogamez is offline   Reply With Quote
Old May 15th, 2009, 11:30 AM   #3
Rynownd
Rynownd's Avatar
I don't think resistors are going to be necessary since the light is meant to be illuminated all the time. The resistors are for turn signals only.
I agree otherwise. There is a two wire harness that plugs into the stock light. Just cut it off and find the hot and ground wires then just connect whichever light you choose.
http://www.southparkstudios.com/clips/224099
Rynownd is offline   Reply With Quote
Old May 15th, 2009, 12:03 PM   #4
tjkamper
tjkamper's Avatar
What lights would you recomend I get and where can I get them. Peferabbly from a chain store so I can get them this weekend instead of waiting on delivery.
Old May 15th, 2009, 12:32 PM   #5
Techno250
bikeless n00b
Techno250's Avatar
Motorcycle(s): None yet. My dream machine is a BLUE 250R.
According the Ninja 250R 2009 parts catalog, the standard bulb for the license frame is part 92069A. Don's Bulbs lists this as 92069-1007, 3.4W 14V incandescent type 158 bulb. So go look for a 158 equivalent at your local parts store, or order online. If you want to go LED, my favorite site is Super Bright LEDs, who have a drop-in 158 replacement (WLED Miniature Wedge Base Bulb) in many colors. They have built-in diodes and current-limiting resistors (LEDs need a resistor not only to provide a load to flasher relays, but to keep from frying the LED).
Hope this helps!
EDIT: This assumes you're re-using parts of the fender or whatever. You could always go with a completely new frame with built-in LEDs or whatever and just mount it and hook up the two wires.
>> fastest=[["green",510],["blue",475],["red",650]].sort{|a,b| a[1]<=>b[1]}[0][0].upcase;fastest
=> "BLUE"
Techno250 is offline   Reply With Quote
Old May 15th, 2009, 12:58 PM   #6
tjkamper
tjkamper's Avatar
If I do just order LED Bulbs, how to I secure them. I know how to run electical. I built my own home and have worked on countless cars. I just need to know how others have done this so I am not making it up as I go along.
Old May 15th, 2009, 03:52 PM   #7
Mo1981
Mo1981's Avatar
Motorcycle(s): 2008 Ebony Ninja 250R
I did LED lighting in a round-about way. These are those crappy $15 windshield fluid lights from Pep Boys.
Matt
2008 Ebony Ninja 250R (a.k.a. "Venom")
Mo1981 is offline   Reply With Quote
Old May 15th, 2009, 04:14 PM   #8
tjkamper
tjkamper's Avatar
Now that's what I'm talking about. Are those the lights that suposidly replace the wash fluid jets on the hood? Did you just drill a hole and then Epoxy them?
Old May 15th, 2009, 04:19 PM   #9
Matt... I like that!!
simple and cheap... just like me.
Old May 15th, 2009, 05:09 PM   #10
Mo1981
Mo1981's Avatar
Yeah, it turned out way better than I expected. My sister's boyfriend liked it so much, I ended up doing his 250 also.
Posted via Mobile Device
Old May 15th, 2009, 07:12 PM   #11
xpander37
Motorcycle(s): 2009 ninja 250r
nice set up Mo! nice and clean.... i just used one led to light up my plate... its pretty weak.... spotlighted pretty much hahah.... but it works.... seems as tho the brake light illuminates the plate pretty well ..... there was a cop behind me while cruising the twn... and he didnt stop me even tho cops here are known to be pricks=)
xpander37 is offline   Reply With Quote
Old May 16th, 2009, 12:26 AM   #12
Cochese
The Grand Royal
Cochese's Avatar
Originally Posted by xpander37 View Post
... there was a cop behind me while cruising the twn... and he didnt stop me even tho cops here are known to be pricks=) doing their jobs.
Fixed it for you.
TJ, my bikelitez kit came with a LED light if your interested...
Cochese is offline   Reply With Quote
Old May 16th, 2009, 02:33 AM   #13
xpander37
Originally Posted by Cochese View Post
Fixed it for you.
haha no i meant pricks.... harassment and racial profiling... lol... if i didnt have my helmet on id be pulled over im sure hahah...
Old May 16th, 2009, 10:07 AM   #14
Old May 16th, 2009, 10:36 AM   #15
Rynownd
Rynownd's Avatar
I like Matt's idea a lot! (Post #7)
But in searching ' LED license plate lights,' the second hit on google was this http://www.1tail.com/sa/c/LED_Licens...ail_Lights.htm
There are also license plate covers that have LEDs in them as well. Such as: http://www.amazon.com/Illuminator-LE.../dp/B001187HQU
Finally, if you follow the link to 'other products by Radiantz Hardcore lighting' you'll find plenty of overpriced crap that I like a little too much. Good company btw; got my rear signals from them.
Old May 16th, 2009, 10:44 AM   #16
Cochese
The Grand Royal
Cochese's Avatar
It sounds to me like their douchebag radar is perfectly tuned to me. "Racial profiling" is a convenience excuse for people to use when they get caught breaking the law.
"harassment" as you put it; nothing more than a police officer doing his job.
It is what it is now in this country. Change is coming alright.
Old May 16th, 2009, 12:23 PM   #17
xpander37
racial profiling, excellent way to give reason to find any excuse or even make up one for a pull over.... cops have said that i havent signaled for a turn (which i indeed did)....also got stopped because i was serving in a lane haha(which was absolutely a lie)...and always walked away with nothing, why??
having being pulled over for a tiny necklace with a cross pendant hanging on the rearview mirror not too long ago... then insulted for still being in school at the age of 29.... yes i guess that would be considered in his job description also hahaha
living in a small town where i am clearly a minority... things happen not all cops are saints thats for sure.... been here 9 years and not a single violation.... and intend to keep it that way...
ok back to topic.... lighting is pretty easy... there is a harness for the plate light... you can find pre made led lighting for autos(which most normally run on 12v) and use them to illuminate your plate..... cut off the harness from the original plate light and crimp or solder it to the new led wires and tada.... new plate light
Old May 16th, 2009, 12:25 PM   #18
B2FiNiTY
Motorcycle(s): 2009 Kawi Ninja 250R
The washer nozzle method looks very clean!!!
B2FiNiTY is offline   Reply With Quote
Old May 16th, 2009, 12:37 PM   #19
Cochese
The Grand Royal
Cochese's Avatar
Nope. There are plenty of reasons to pull people over. Every car, all day long. Pulling violators over for weaving (which I bet you were doing, even if you didn't notice) and minor equipment violations is a great tool that leads to bigger issues, like suspended or uninsured drivers and major warrants. How was Timothy McVeigh caught? Look the answer up... As it may surprise you.
If you aren't getting tickets in 9 years its because you aren't suspended, you don't have warrants and your vehicle is insured. I never claimed all cops were saints. They are like every other demographic... Good and bad are mixed in.
That said, your generalization that the cops in your small town are all racial profiling, harassing pricks is what I take exception to. The first folks to cry racial profiling are. Doing so because they don't take the time to understand the system and enjoy the convenient scape goat. I've come to expect though, however sad it is.
Stay safe
Old May 16th, 2009, 12:52 PM   #20
xpander37
how is someone who i do not even know is so sure of me and my actions? yes i like swerving along the roads to draw attention to myself and perhaps putting others in danger... thats me, you got me figured out.... this town when it comes to cops is a little BS.... perhaps having a gun drawn to my face in my own home because they thought there was an intruder got me a little sour.... but hey... at least he didnt shoot my brains out... i commend him for his super spider senses for saving me from my guest for which i was having a nice beer with lol
hey i dont mind them doing there jobs... its just when i run into insults, bad judgement, and making up lies...... it makes me love em that much more =)
Old May 16th, 2009, 02:45 PM   #21
Cochese
The Grand Royal
Cochese's Avatar
Same reason every person I stop for weaving within their lane says almost the same thing to me every single time... "I was weaving? I didn't even realize!"
You ever used a cell phone and drove at the same time? Ever? Texts or phone calls. Thank about it... be honest. Ever?
If so, then you have weaved within your lane.
I never claimed that I had you all figured out, although that doesn't seem to be the most daunting task on todays to-do list.
...this town when it comes to cops is a little BS....
That's your opinion. What matters is:
A) How it was formed in the first place.
B) how you pass your OPINION off as fact.
....perhaps having a gun drawn to my face in my own home because they thought there was an intruder got me a little sour.... but hey... at least he didnt shoot my brains out... i commend him for his super spider senses for saving me from my guest for which i was having a nice beer with lol...
I'm sure you and your guest had absolutely nothing to do with the police being called to your residence for an intruder. The police always walk into people's houses and menace them for no apparent reason.
I think your locale (Socialist republik of IL) has more to do with your encounters with lies, bad judgment and insults than anything else. If you feel you've been wronged by an individual officer, perhaps you should have done something about it then, like contacting his/her supervisor or filing a complaint, instead of insulting an entire profession anonymously (and ignorantly) on the internet?
All the best.
Old May 16th, 2009, 03:04 PM   #22
Buffalony
Buffalony's Avatar
OK. Stop it children
Back to topic
BTW: No cyclist should get pulled over due to swerving in the same lane
Old May 16th, 2009, 03:18 PM   #23
xpander37
this can go on forever.... however you speak of all this as if your on the front lines.... living in this town for 9 years i see and hear plenty that goes on here... i am not the only one who lives here with these thoughts.... i used my experiences as examples is all... over all i think majority of cops are a joke... i find it humorous lol.... and yes they did step into my place with guns drawn... you know the reason why?.... because my front door wasnt locked and thought there was an intruder hahaha... pretty comical.... law enforcers at their finest!
yes i have maybe swerved in my time... but they should actually stop me while im in the act....
considered writing a complaint, yes..... but in a town like this with nothing for them to do.... i think ill pass on being a target
im very sorry i offended you and anyone else here with my stories....this is really gettin old... i never did say all cops around the world were pricks..... because that indeed would be ignorant of me.... what i originally posted was "and he didnt stop me even tho cops here are known to be pricks=)"
if you have anything else to add, just send a private lol... this thread took a spin in the wrong direction=)
Old May 16th, 2009, 09:38 PM   #24
Cochese
The Grand Royal
Cochese's Avatar
Unfortunately it probably could. The thing is, I am on the front lines. Been on the front lines for 5 years. Been shot at. Been stabbed. Seen stuff I wouldn't feel comfortable repeating here.
Just goes to show your not the only person in that town that has a problem generalizing then.
...over all i think majority of cops are a joke... i find it humorous lol....
You have a lot of growing up to do.
Somebody called them to your house. The police don't walk around your neighborhood trying doors. There is a huge part of your story missing, which is evidentially an intentional omission, as it would bring light to why the police where there investigating an intruder in the first place, but I digress.
You missed the idea behind my post about the weaving. The idea is, you did something to warrant a traffic contact each time you were stopped...
EVEN IF YOU DIDN'T NOTICE IT.
That's your problem then. Your only true recourse if you feel you were wronged during a police contact is to report it to their administration. You are not going to become a target. Not a target for enforcement, not a target for anything. We (the police) don't work that way. The repercussions for us would be far greater than what it would be worth to "harass" you.
You don't have to worry about offending me. What you should worry about is how you represent yourself. What other careers/professions/groups to you generalize about? How do you think it makes them feel?
I doubt your sorry since right before you apologized, you said..
If we're all such a joke, then call 4-1-1 during your next emergency and ask for a direct number to the firemen. See if they'll help you with your theft report, your barking dog complaint, your ex-girlfriend sending you harassing text messages, some drunk weaving down the highway, et al.
This thread has gotten a little off topic. Maybe Alex can split this into a new thread in off-topic.
There is however, absolutely nothing I feel the need to take to PMs. If you have a problem airing your thoughts on the subject, you never should have done so in the first place.
Old May 17th, 2009, 02:18 AM   #25
xpander37
looks as long as a DIY thread... impressive..but please dont expect me to read that.. as i said im over it... we all have our own opinions... lets leave it at that?
Old May 17th, 2009, 02:21 AM   #26
Cochese
The Grand Royal
Cochese's Avatar
Translation ~ "I give up."
Old May 17th, 2009, 02:00 PM   #27
Mo1981
Mo1981's Avatar
They are actually threaded with a nut, so I just drilled a hole and screwed the nut on. All in all, it was a pretty easy job. I've been followed by a couple cops at nite and had no problems, as far as the lights are concerned.
Old May 18th, 2009, 02:15 PM   #28
Army Aviator
Motorcycle(s): Ninja 250R
Why... do you... keep... doing... this... with the... periods in... all of your posts... STOP IT!!!
Try typing a complete sentence, this period crap makes your posts look... retarded.
Army Aviator is offline   Reply With Quote
Old May 18th, 2009, 02:39 PM   #29
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
This is an option:
NJD022588 is offline   Reply With Quote
Old May 18th, 2009, 05:13 PM   #30
Old May 18th, 2009, 08:09 PM   #31
xpander37
lol does it bug you that much?.... its just my thing.... grammar and spelling pftttt, its a forum... not an essay ....
Old May 18th, 2009, 09:21 PM   #32
Buffalony
Buffalony's Avatar
What? Is this frickin english class now. Some people need to learn to keep certain opinions to themself. This is supposed to be a friendly environment/forum. Its why I use this ninjette forum specifically. Sure we get into some heated discussions around here!! But personal, off topic attacks like that shouldnt be tolerated.....
I'm for the periods.
While we do use smilies and acronyms up the arse on the net. Using periods like that is.....well..um.....hmmmm......understanding!. . because it can be another tool used to convey mood, tone or ones own manners while speaking. Smiles and acronyms are not in the english dictionary either.
If Tony feels he has to use periods to express himself properly in a forum environment...... He should.
Tony, I understand what you were sayin about the cops being pricks. A softer way to say that for the LEOs around here would be "Picky".
On the other hand....It doesnt look like your plate would be legible from the distance required in my area which is 30ft. I have two plate lights on mine like NJD022588's pic, and they barely makes the cut.
Old May 28th, 2009, 01:49 AM   #33
tc3jg
Motorcycle(s): 08 ninja 250r
I used two windshield washer sprayer LED lights that you see people putting on their tuner cars. this worked out great because of the location of my plate.
simply wired them right to where the stock ones went
tc3jg is offline   Reply With Quote
Old May 28th, 2009, 10:26 PM   #34
B2FiNiTY
im thinking about getting something like this.
Old May 28th, 2009, 11:23 PM   #35
CANTFUNCTION
CANTFUNCTION's Avatar
Motorcycle(s): 09 ninja 250(red)
I have one like that but it is black. Looks clean and its bright. The light that came with the Targa kit died after a month.
CANTFUNCTION is offline   Reply With Quote
Old May 28th, 2009, 11:57 PM   #36
hzrnbgy
hzrnbgy's Avatar
Motorcycle(s): 2009 Black Ninja 250R, 2004 Yellow Ninja 250R
guys, you might want to check this out
superbrightleds
look for the LED Accent Light Modules ALM-x3
$6 a pop, they have in green, blue, white UV, etc. its completely weatherproof and suitable for automobile applications. im waiting for one on the mail.
they also have 1157 dual power tail lights in there. get the 5 SMD LEDs one.
hzrnbgy is offline   Reply With Quote
Old May 29th, 2009, 06:59 PM   #37
Rocketman
Rocketman's Avatar
Motorcycle(s): 2009 250r special edition
Thumbs up
superbrightleds
Good find.
Rocketman is offline   Reply With Quote
Old May 30th, 2009, 08:09 AM   #38
Buffalony
Buffalony's Avatar
Awesome options guys. I like the washer nozzles. lol great ingenuity. I have a couple of green ones lying around havent figured out what to use them for with out looking too ricey/azn
That led site is pretty good. bookmarked
Old June 2nd, 2009, 07:05 PM   #39
tinng321
tinng321's Avatar
Motorcycle(s): 08 black 250r (sold); '09 black zx6r
superbrightleds
I bought my lights for my car from them. I changed out all 19 bulbs in the instrument panel to blue led.
Cheap plus a flat $5 shipping.
tinng321 is offline   Reply With Quote
Old June 3rd, 2009, 02:36 PM   #40
Buffalony
Buffalony's Avatar
So has anyone here done the ninjettes gauge lights yet?
I had to chop off the rear fender!!! dark_beaverezt Pictures 7 January 10th, 2012 04:05 PM
New pics of fender chop beqwarrior 2008 - 2012 Ninja 250R Farkles 3 June 14th, 2011 05:41 PM
My $0.00 Fender Chop nate-bama 1986 - 2007 Ninja 250R Farkles 32 September 29th, 2010 05:18 PM
DIY Fender Chop Tubesock 2008 - 2012 Ninja 250R Farkles 20 May 18th, 2009 11:47 PM
My custom fender chop! Tintkng 2008 - 2012 Ninja 250R Farkles 12 May 17th, 2009 12:10 PM
