Old August 12th, 2015, 04:38 AM   #1
Mike2009
Motorcycle(s): 2009 ninja
2009 250 ninja foggy oil indicator window.
Hi all i recently changed my oil and filter and noticed on my oil indicator window is fogging up oil still looks clear from after i ride it. Today i took it for about a 14km ride and i noticed after it cooled it fogged back up. I checked the coolent and thats still full to the top. I do notice tho that my exaust drips water every time i start it. Can anyone help me with a daiegnosis?
Cheers
Mike2009 is offline   Reply With Quote
Old August 12th, 2015, 05:19 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Probubly OK
Worlds fastest 250 ninja
Old August 12th, 2015, 06:24 AM   #3
/moved to new-gen tech
Old August 12th, 2015, 11:30 AM   #4
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
Try opening the fill cap after riding. There is humidity in the engine. Likely will not cause any issues but sometimes happens in hot/humid areas.
Where are you located?
Foxrider64 is offline   Reply With Quote
Old August 12th, 2015, 11:54 AM   #5
g21-30
g21-30's Avatar
Water (exhaust drip) is a by product of internal combustion engines. Why do you think pipes and mufflers rust out? Don't worry about the water drip.
If your fuel tank petcock gasket (rubber) leaks (gas on the ground or garage floor from an overflowing float bowl), then gas can get into the oil. This will cause the cloudy oil level window and raise the level also.
Old August 12th, 2015, 02:52 PM   #6
That's all normal. Ride longer to help remove the moisture, but depending on conditions it may happen more or less.
It takes time and heat to evaporate moisture from the engine, oil, and exhaust system - but it's always going to be present to some extent.
Old August 12th, 2015, 05:05 PM   #7
Ride to a NASA research center, put the entire bike in their huge vacuum chamber, and the water will boil out of your oil. Problem solved.
Ride it longer, get it hot, see if the issue still exists
Old August 12th, 2015, 08:55 PM   #8
verboten1
verboten1's Avatar
MOTM - June '15
Ride more.
Worry less
Ride more, worry less.
Old August 13th, 2015, 09:44 AM   #9
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
If you frequently ride only short distances, you may want to consider a Thermo-Bob. It'll help your engine get up to proper temps more quickly. https://www.ninjette.org/forums/showthread.php?t=88799
Oil sight window question ccampbell 1986 - 2007 Ninja 250R Tech Talk 23 November 9th, 2010 01:15 PM
