Old October 10th, 2011, 03:52 PM   #1
THE BIG SITT
THE BIG SITT's Avatar
Milwaukee Offset Screwdriver
Where did you guys with a MOS get one? If online, please provide a link
THE BIG SITT is offline   Reply With Quote
Old October 10th, 2011, 03:53 PM   #2
/moved to items wanted
Old October 10th, 2011, 04:55 PM   #3
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
only place around me that had them was home depot. its not actually a screwdriver per say , its a attachment to go on a drill or ratcheting screwdriver so if you dont have a ratcheting screwdriver youll need one of those as well. as for trying to use that to change jets and all while carbs are still on.. i couldnt do it.. was simpler to remove the carbs.. loL! but def comes in good use for adjusting the mixture screws once you do rejet.
#1
greatwhiteninja is offline   Reply With Quote
Old October 10th, 2011, 05:23 PM   #4
Cuongism
Cuongism's Avatar
http://www.homedepot.com/buy/tools-h...er-173834.html
Old October 11th, 2011, 08:17 AM   #5
dubojr1
dubojr1's Avatar
Originally Posted by Cuongism View Post
+1 Got it local though. Awesome tool!!!
Old October 11th, 2011, 11:25 AM   #6
Cuongism
Cuongism's Avatar
The link let's you input your zip code to see if it's available at your local home depot.
Old October 11th, 2011, 12:47 PM   #7
THE BIG SITT
Well I got the MOS! For future reference, it is better described as an attachment to a powered drill. I found them located in the drill accessory section at Home Depot, which is apparently the only store authorized to sell them, at least in my area. As stated earlier, you will need a ratcheting handle to use the MOS.
Old October 23rd, 2011, 12:53 AM   #8
paulforaname
paulforaname's Avatar
Motorcycle(s): Ninja 250R
hi,
i got a offset ratchet with sockets and phillps and flat plus hex attachments on ebay for about $25 delivered here is link http://www.ebay.com.au/itm/320690846...84.m1439.l2649
was able to shim my needles after aftermarket exhaust installed without removing carbs but be carefull as easy to strip heads, i had to use a very small vice grips to undo the left front screw on the left carb.. and replaced screws this better quality ones
paulforaname is offline   Reply With Quote
Old January 8th, 2012, 03:33 PM   #9
samw
Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R
Just picked up one of these at Home Depot!
samw is offline   Reply With Quote
Old January 8th, 2012, 03:35 PM   #10
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Got mine at OSH best tool ever
----> My Youtube! <----
Pilot Jet screwdriver size brian12 1986 - 2007 Ninja 250R Tech Talk 6 September 11th, 2013 10:57 AM
[webbikeworld.com] - Vessel Motorcycle JIS Screwdriver Kit Review Ninjette Newsbot Motorcycling News 0 August 11th, 2013 02:30 PM
Is a JIS screwdriver a necessity? slickt0mmy 1986 - 2007 Ninja 250R Tech Talk 7 June 26th, 2013 05:14 AM
woodruff offset key for timing advance? Lucagst 2008 - 2012 Ninja 250R Tech Talk 4 February 13th, 2013 08:25 PM
[webbikeworld.com] - JIS Screwdriver Review Ninjette Newsbot Motorcycling News 0 October 17th, 2011 07:40 AM
