Old November 29th, 2012, 10:19 PM   #1
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Pirelli Diablo Supercorsa Front
What do you guys think? Is it worth going to a 120 in order to get the sexiness that is this tire? I'm thinking of running the Supercorsa front a rosso 2 rear.
AFM #676
Supersports are for n00bs
Old November 29th, 2012, 10:35 PM   #2
Don't your tires work fine?
Old November 29th, 2012, 10:43 PM   #3
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yea but...
that one is stickier...
AFM #676
Old November 29th, 2012, 10:44 PM   #4
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Besides slower steering and less change in your pocket, what would you gain over the Rosso II?
geeker is offline   Reply With Quote
Old November 29th, 2012, 10:45 PM   #5
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
I thought they had 110 for it... yea know some of track 250s that run this set up
THE GOOD LIFE
Old November 29th, 2012, 10:47 PM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
It is apparently a much stickier tire, even better than the Rosso 2. If it means I'm that less likely to **** up and lose the front then I'd like to get it but I really don't want a 120 on there since it will make the flickability lamer
Originally Posted by cuz View Post
I thought they had 110 for it... yea lots of track 250s run that set up
I couldn't find a 110. Thats what I've read though
AFM #676
Old November 29th, 2012, 10:49 PM   #7
rusninja
Ninjette wanabe :D
rusninja's Avatar
Motorcycle(s): white 300 :D
Do it and tell me how it is
VROOOM vrooom >.>
rusninja is offline   Reply With Quote
Old November 29th, 2012, 10:51 PM   #8
Jono
Jono's Avatar
Better tires only hide your mistakes.
Old November 29th, 2012, 10:51 PM   #9
geeker
geeker's Avatar
I think your efforts would be better spent on Rosso IIs and then dialing in your front suspension for your weight.
Old November 29th, 2012, 10:52 PM   #10
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Oh hey I found a 110, not a lot of people seem to carry it
AFM #676
Old November 29th, 2012, 10:53 PM   #11
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I'd prefer my mistakes to be hidden than end up in a ditch
AFM #676
Old November 29th, 2012, 10:54 PM   #12
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Hmm, should I?
http://www.mphbikes.com/pirelli-diab...0-70-17-front/
AFM #676
Old November 29th, 2012, 10:55 PM   #13
geeker
geeker's Avatar
Watched twist of the wrist yet?
Old November 29th, 2012, 10:56 PM   #14
I call BS.
Old November 29th, 2012, 10:56 PM   #15
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Its on my **** to get done list
AFM #676
Old November 29th, 2012, 10:57 PM   #16
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Quite a beefy tire, if you feel that it's worth the change from your DR2's then go for it I guess?
menikmati is offline   Reply With Quote
Old November 29th, 2012, 10:57 PM   #17
cuz
cuz
cuz's Avatar
a quick Google search does wonders
Da cheapest 1 i found im sure there's a better deal out there
http://www.ronayers.com/ProductDetai...79/SKU/1197686
THE GOOD LIFE
Old November 29th, 2012, 10:57 PM   #18
rusninja
Ninjette wanabe :D
rusninja's Avatar
http://www.pirelli.com/tire/us/en/mo...subtype%3Droad the super sp's come in 110/70 and 150/60 :S
VROOOM vrooom >.>
Old November 29th, 2012, 10:59 PM   #19
cuz
cuz
cuz's Avatar
FYI
There are different compounds
THE GOOD LIFE
Old November 29th, 2012, 11:04 PM   #20
Jono
Jono's Avatar
I call BS.
It's very true for automotive racing and I am guessing it would be true for motorcycles as well.
I autocrossed my car for a year before I owned my bike. I learned quite a bit about how tires change the car. With super grippy tires you can get away with many mistakes but with okay tires you really have to be a good driver to get the car to do what you want it to do. You have to be super smooth with crappy tires (not saying you shouldn't be smooth with super grippy tires) but once YOU can push the limits of a car with crappy tire then once you move up to grippy tires you will be able to go much faster than someone who skipped the basics and started with the most expensive grippy tires they wanted.
I am tired am probably not being clear with my thoughts.
Old November 29th, 2012, 11:07 PM   #21
menikmati
Seems like Sean is comprised entirely of straight cash, homey.
If so, buy it and sell your DR2?
Old November 29th, 2012, 11:12 PM   #22
Jiggles
Jiggles's Avatar
MOTM - Apr '13
FYI
O.o?
AFM #676
Old November 29th, 2012, 11:22 PM   #23
no, I get that; you gotta get good on a bad setup before you can really be good on a good setup. It's the same idea as starting out on a ninja 250 to learn to carry more corner speed and less straight speed, or starting with Sora components on your road bike instead of Ultegra.
...but to play devil's advocate:
The Dunrocks suck. They slide. They don't turn in quickly at all. They don't stay stable mid-lean. They're vague when pushed at all. They generally are good at nothing except keeping the rim off the ground.
now compare that to BT45's, or Diablo scooters. They flick over quickly. They stay planted and stable mid-lean. They don't feel slick. They get up to temp quickly and stay sticky.
If anything, stickier tires show off my problems more, because they allow the bike to follow my every bad input and show me where I'm going wrong, whether that's too much bar input while shifting my weight, or just a bad line in general (I'm guilty of both).
Old November 29th, 2012, 11:30 PM   #24
geeker
geeker's Avatar
Aren't we all?
Old November 29th, 2012, 11:32 PM   #25
Jono
Jono's Avatar
I see what you're saying there. I never experienced the dunrocks. I have BT45s on my ninja and Roadwinners on the KLX. Side note: I don't get why people bad mouth the Roadwinners, they work fine for the street. On neither bike do I have issues with the tires. If the tires were to slip for any reason it would be because of me making a mistake.
But Jiggles has decent tires. DR2's. He doesn't NEED anything with more grip. He is just scared he is going to lowside for some reason.
Old November 29th, 2012, 11:36 PM   #26
The dunrocks are terrible. Count yourself lucky.
The roadwinners (from the 2 times I've ridden on them) are alright. Nothing super confidence inspiring, but with so many better options out there, I would never buy a set.
Jiggs, get faster first
Old November 29th, 2012, 11:37 PM   #27
Jiggles
Jiggles's Avatar
MOTM - Apr '13
But, why would I not want a tire with MORE grip!? That's just crazy!
The roadwinners are totally fine for the street, I never had a problem with them and I scrubbed the strips off them too.
AFM #676
Old November 29th, 2012, 11:38 PM   #28
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I went pretty fast at button willow!
I got a 2.38, I'll bet the next time I'm out there I can break 2.30
the 250 lap record is 2.08
AFM #676
Old November 29th, 2012, 11:39 PM   #29
geeker
geeker's Avatar
Read the book, or watch the movie, and it will help call those fears.
Old November 29th, 2012, 11:40 PM   #30
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I'll still want the stickiest tires.
Can we get a velcro track?
AFM #676
Old November 29th, 2012, 11:48 PM   #31
geeker
geeker's Avatar
The sound would be deafening on the never ending Velcro strip.
Old November 29th, 2012, 11:51 PM   #32
Jiggles
Jiggles's Avatar
MOTM - Apr '13
You have never heard @Nemesis's bike
AFM #676
Old November 29th, 2012, 11:53 PM   #33
I got a 2.38
Watch out Rexbo. Here comes Jiggs
Old November 29th, 2012, 11:54 PM   #34
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Also. I have the SC2 120 front. It is quite sticky/awesome. However, they are hard to get because they don't usually ship to the west coast. When I have to get a new front it will be a Diablo Rosso II. NOT because I don't like the Supercorsa, I think it's great. I'm not at a point where I think I'd be able to tell a great difference between the two, and wont be there for a while. I know the SC2 is better, but I don't need it yet, I'm just not there. Neither are you. Stick with the Diablo Rosso IIs, you have more to work on first, like butt to seat removal :P
CVMA #531
Old November 29th, 2012, 11:56 PM   #35
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Too late I ordered one hahahaha. It's going on the next front tire replacement, should be a few thousand miles more or about 4-5 more trackdays
AFM #676
Old November 29th, 2012, 11:59 PM   #36
Trailerboy531
Steve has used his SC2 front and DR2s for the whole race season. I think you have more than 6-7 Track days on yours... Save your money, this will get more expensive! :P
CVMA #531
Old November 30th, 2012, 12:02 AM   #37
Looks like I don't need to worry about replacing mine before my next track day then! I'll likely buy a new set and bring them with me though, just in case.
Old November 30th, 2012, 12:05 AM   #38
Jono
Jono's Avatar
Hahaha.You do realize 30 seconds is a huge amount of time in racing.
Maybe you will be faster once you start shifting gears more often! Oh and I am sure that new tire will make you like 10 seconds faster.
Old November 30th, 2012, 12:21 AM   #39
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I'm willing to place a bet
The only thing that will have changed is the front tire
AFM #676
Old November 30th, 2012, 02:11 AM   #40
cuz
cuz
cuz's Avatar
That's a fast tire need to keep the speed up (so it can work to it's potential)
GL
THE GOOD LIFE
[motorcycle-usa.com] - Pirelli Diablo Supercorsa SP on 1299 Panigale Ninjette Newsbot Motorcycling News 0 January 27th, 2015 03:00 AM
[roadracingworld.com] - Pirelli's Diablo Supercorsa SP Chosen As Original Equipment O Ninjette Newsbot Motorcycling News 0 January 26th, 2015 05:20 PM
[sportrider - latest stories] - New Pirelli Diablo Supercorsa SP Tire Take to the Tra Ninjette Newsbot Motorcycling News 0 September 7th, 2012 05:20 PM
[motorcyclistonline] - Pirelli Presents the New Diablo Supercorsa: Top Performance on Ninjette Newsbot Motorcycling News 0 November 15th, 2011 02:50 AM
[topix.net] - BIKES: Pirelli Presents The New Diablo Supercorsa Ninjette Newsbot Motorcycling News 0 November 14th, 2011 09:10 PM
