May 11th, 2012, 11:42 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2012 ninja 250 Posts: 296
quick question before I head off to work
Recently I replaced the clutch plates on my 12' ninja 250.
There's no more slipping! But I've noticed that I have lost some top speed? I used to redline in 6th and be slightly above 100mph on the speedo. Now I'm barley reaching above 90mph at redline in 6th. Any idea's on why this could be? It's not a huge deal or anything... But i'd like to know what could be causing this? |
May 11th, 2012, 11:55 AM | #2 |
Your clutch is slipping at high temperatures of the oil.
It may get better when the new disks break-in more.
May 11th, 2012, 12:36 PM | #3 |
Could it be cause I'm using crappy oil? or a different one rather then the one the kawi dealer uses?
May 11th, 2012, 12:56 PM | #4 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
Just out of curiosity. What was the reason for changing clutch plate? I see you have a 2012
May 11th, 2012, 01:38 PM | #5 | |
http://faq.ninja250.org/wiki/Preferred_Brands Also, verify that the clutch lever has the proper free play.
May 11th, 2012, 02:05 PM | #6 |
Join Date: Apr 2012 Motorcycle(s): 2003 Kawasaki Ninja 250R Posts: A lot.
Good question!
http://www.facebook.com/groups/DeMdNjPagrouprides/ I live my life a quarter mile at a time! Who is affraid of the big bad jiggles???? LOL |
May 11th, 2012, 03:25 PM | #7 | |
May 11th, 2012, 03:28 PM | #8 |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r Posts: 217
May 11th, 2012, 04:33 PM | #10 |
When I start to red line 13k 14krpm in 6th I'm going about 90mph. I'm still gaining speed, but I usually let off and don't keep going.
I believe my clutch is is adjusted loosely, I have quite a bit of play in the lever... My clutch went out before like what said by alex, I did some wheelies \ burnouts, but also the main reason I think it that I was riding around with my clutch adjusted incorrectly and it was way too tight. I think it was constantly engaged and burnt out fast. Posted via Mobile Device |
May 11th, 2012, 04:51 PM | #11 |
Did the replacemet plats get an overnight bath in oil so swell properly?
Upgraded clutch springs might help too.
May 11th, 2012, 04:53 PM | #12 |
They didn't. Didn't know that had to be done.
May 11th, 2012, 06:39 PM | #13 |
Assuming everything is adjusted properly, this would be my guess...
May 12th, 2012, 07:59 AM | #14 | |
If you didn't replace the springs, that may be the cause of the current slip. The current slip will deform the new metal discs (they are new, right?) and will make the springs weaker. Over-heat and contaminants are the two enemies of clutch health. If the engine's rpm / speed ratio has changed that 10% for worse, clutch slip is happening.
May 12th, 2012, 09:07 AM | #15 |
Thanks guys.
Should I buy new springs and replace them? Or should I just wait and buy a new clutch and new springs and just replace them when it gets worst? Posted via Mobile Device |
May 13th, 2012, 05:37 AM | #16 |
Before doing anything, I would keep an eye on the rpm and speed in order to see if the problem improves or worsens.
Best luck!
May 13th, 2012, 12:34 PM | #17 |
I agree that observing it for a short while longer may lead to a more accurate diagnosis. Since the clutch wasn't pre-swelled in an oil bath prior to install, things may tighten up as it swells inside the bike. I haven't a clue, however, if it will do so in a way that puts uneven pressure on the springs......
quick question | Electronic M | 2013 - 2017 Ninja 300 Tech Talk | 57 | March 17th, 2015 04:41 AM |
Quick question | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 26th, 2014 11:40 AM |
Quick Question | PsHYk | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 10th, 2012 02:58 PM |
Quick Question! | shiftdrift06 | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 1st, 2012 08:31 PM |
quick question i am off for work about lifting front of the bike | reaperw | 2008 - 2012 Ninja 250R Tech Talk | 26 | January 13th, 2012 11:47 AM |
