Old June 7th, 2016, 09:24 AM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Need help identifying oil leak
Oil residue on front oil line behind the header as seen on this pic
I only ride this bike on the track so it spends most of its time in the 9K+ RPM range. I dont really notice any oil loss that noticeable but clearly its leaking a little from somewhere.
daverdfw is offline   Reply With Quote
Old June 7th, 2016, 09:49 AM   #2
Brother Michigan
Motorcycle(s): 2013 Ninja 300
Silly question, but are you sure it's oil?
DISCLAIMER: I generally have no idea what I'm talking about.
Old June 7th, 2016, 10:09 AM   #3
daverdfw
definitely not a silly question, I had some fluid I noticed before and It was actually residual fork oil that accumulated on the radiator. I thought its all gone by now. I will try and clean this area and I have another track day next week. So that will be a good test if it was left over fork oil spillage.
Old June 22nd, 2016, 01:58 PM   #4
Buffalony
Buffalony's Avatar
Is it the oil line fitting? They have a crush gasket like brake banjo bolts. I'd wipe it clean and fire it up to look for the leak. Check torque on fitting too.
Still got this oil leak!! xXecuterXx2 1986 - 2007 Ninja 250R Tech Talk 11 August 11th, 2015 11:56 PM
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
possible oil leak? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 17 August 21st, 2012 01:35 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
