February 12th, 2011, 12:02 AM | #1 |
Join Date: Feb 2011 Motorcycle(s): 09 Ninja 250r Posts: 3
New Here, Have some Tech Questions
So I just bought my fiance a 09 250r. 3 weeks ago we were leaving and the bike was stalling with open throttle. So we take it back and they find its the carbs or jets. They replaced the jets and now its 3 weeks later.....
Well I get the bike home it ran fine to me ( I have a R6) so I dont know how it should feel. But I get home and noticed that it idles roughly about 1k rpms but its not steady and is contantly moving from 1,000 - 1,300. I mess with the idle screw but it doesnt calm it. I also come to find out that the choke is not working...... I think when they took it apart they did not sit the choke cable correctly as when I engage it I can see the cable moves loosely. So my question is do you think when they put the new jets in and cleaned the carbs it did something to the idleing?? Second how hard is it to reseat the choke cable?? I dont want to take it back to this dealer because they are screwing around and I dont want to waste anymore time. Thanks for reading my post and giving some feed back. |
February 12th, 2011, 02:26 AM | #2 |
the choke cable connects to the carbs at the top front to a sliding bar looking arrangement. make sure when you pull the choke lever you see the sliding bar move. If it doesn't, the cable isn't connected properly or is severely out of adjustment.
you can see the sliding bar in this photo directly above what is labeled "carb sync adjustment screw". the varying idle is most likely due to dirty pilot jets that they probably did not clean when they went through cleaning the carbs. you will need to remove the carbs to clean them if they are indeed blocked. http://www.ninjette.org/forums/showthread.php?t=65198 personally... I would take it back to the dealer and have them fix their eefff upps. |
February 12th, 2011, 08:12 AM | #3 |
Well they just put new pilot jets into the bike yesterday before I picked it up???
February 12th, 2011, 08:33 AM | #4 |
It looke like the choke cable is out of adjustment because when I pull on the cable by hand it still does not pull the sliding part to open up the choke. The thing is it was not a name dealer like Kawasaki or anything it was a dealer that sells used bikes and I have to keep on their ass just to do the simple things.
February 12th, 2011, 09:18 AM | #5 |
Resident Old Guy
February 12th, 2011, 10:43 AM | #6 | |
Your other options are to take it somewhere else and pay again to have the carbs cleaned properly or remove them and do it yourself. |
February 12th, 2011, 10:54 AM | #7 |
Also, idle works better on these bikes when set closer to 1500 rpm when fully warm (knob on the left side of the bike).
ecotrons tech questions. | bigbadbob | 1986 - 2007 Ninja 250R Tech Talk | 1 | April 17th, 2015 10:50 AM |
Tech Questions | 08ninja250 | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 25th, 2011 08:41 PM |
[topix.net] - Motorcycle Tech Questions and Answers | Ninjette Newsbot | Motorcycling News | 0 | September 3rd, 2010 05:40 PM |
[topix.net] - Tech Questions & Answers | Ninjette Newsbot | Motorcycling News | 0 | August 13th, 2010 10:30 PM |
[sportrider - tech] - Street Tires, Clutch, And Cylinders - Questions And Answers - A | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2010 11:40 PM |
