Old June 28th, 2012, 06:18 PM   #1
sendler
sendler's Avatar
Motorcycle(s): 09 Ninja 250, 2011 Honda CBR250R, 07 Ninja 650
Re grinding a square tire
I got rid of my chicken strips today. With a grinder. And an 80 grit disc. My rear tire was starting to feel edgey from the flat spot in the center after 10,000 miles of highway commuting so I thought about grinding it round again. My coworker who is an expert body and frame tech and also a winning stock car- dirt oval driver was walking by so I asked him half jokingly if he ever ground rubber off of a tire before and he said "Only if you want to win!". It turns out that these guys buff up the tires between every heat to take the glaze off. So I borrowed his grinder and went at it with the wheel idling on the stand in first gear. No more than 15 minutes later I had a dust pan full of rubber and a nice round tire again.
http://www.fuelly.com/driver/sendler/cbr250r
sendler is offline   Reply With Quote
Old June 28th, 2012, 06:41 PM   #2
Old June 28th, 2012, 06:44 PM   #3
dude.
just buy a new tire.
Old June 28th, 2012, 06:51 PM   #4
sendler
sendler's Avatar
Still some good life left on that one and it transitions into lean much better now.
Old June 28th, 2012, 07:15 PM   #5
Countersteer
Countersteer's Avatar
Motorcycle(s): <2008 250R> Past Bikes:06 GSXR600 89 CBR1000 78 Hawk 400 86 Ninja 600R 86 & 87 FZ600 81 GPZ550 71 CB360T
I can't necessarily say this is a bad idea... hmmm...
Have you ever read the King James Bible?
To say speed kills is akin to saying guns kill, neither of which is true.
Countersteer is offline   Reply With Quote
Old June 28th, 2012, 07:29 PM   #6
this is a bad idea.
Old June 28th, 2012, 09:45 PM   #7
Monkeytofu
I told you bro
Monkeytofu's Avatar
Shouldn't be a problem unless he sanded it unevenly.
Old June 28th, 2012, 09:49 PM   #8
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
dude.
this is a bad idea.
imma have to go with alex and say just buy a new one cus that seems like a bad idea...plus he seems to know his **** pretty good so id listen...
PsHYk is offline   Reply With Quote
Old June 28th, 2012, 10:54 PM   #9
jmora3
Motorcycle(s): 08 Ninja 250
Talking
I say you make a mold from a good tire and fill it with herculiner! Bomb proof tire! So it should never run out, but if it does then you just refill it!
jmora3 is offline   Reply With Quote
Old June 29th, 2012, 12:10 AM   #10
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Twisties? Hell naw I'm grinding my chicken strips off like an OG
AFM #676
Supersports are for n00bs
Old June 29th, 2012, 06:14 AM   #11
bdavison
Wartown, USA
bdavison's Avatar
Ride it like you stole it, and the tire won't get flat in the middle....LOL
I usually scuff up a new tire with some 60 grit a bit before going out on a first ride to get rid of that horrendous mold release agent. But never attacked one with a grinder.
Old June 29th, 2012, 11:31 AM   #12
Monkeytofu
I told you bro
Monkeytofu's Avatar
Modern tires don't use release agent like their predecessors. They do use it on the inner walls of some tires because it makes them look nice and shiny.
Old June 29th, 2012, 11:44 AM   #13
No release agent on new tires. I took a brand new (52 miles of straight roads actually) set of pirellis out on the track. They stuck like glue, even though I started out with GIANT chicken strips and ended with about 1/4" on each side.
Posted via Mobile Device
Old June 29th, 2012, 12:24 PM   #14
sendler
sendler's Avatar
Never do. 0ver 95 mpgUS for my last three tanks in a row, 750 miles, on my CBR250R now that the warmer weather is here. Hypermiling is my form of competition.
Old June 29th, 2012, 12:29 PM   #15
Chubbs032
Motorcycle(s): 250r
only heard of shaving tires for weight savings at car events
Chubbs032 is offline   Reply With Quote
Old June 29th, 2012, 01:45 PM   #16
Redgeneral
Redgeneral's Avatar
Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650
Have you tried cornering? I hear that works pretty well. :P
Seriously though, I have +12,000km on my stock tires, they're beginning to do the same. Though mine will be replaced first thing next season to give me a little bit of piece of mind.
I've never heard of someone grinding their tires.
Redgeneral is offline   Reply With Quote
Old June 29th, 2012, 02:35 PM   #17
sendler
sendler's Avatar
I never let that stop me from trying something that I know will work well. And then sharing it on the internet.
Old July 2nd, 2012, 07:28 AM   #18
bdavison
Wartown, USA
bdavison's Avatar
I know they keep telling people there is no release agent....whatever.
Michelin DEFINITELY uses mold release agents. They will even tell you they do.
And they are slick as glass when brand new. You can either run 200 miles to get them scuffed in or hit it with 60grit and then go ride the snizzle out of them. Other manufacturers may not use release agent, however their tires are slick too, because they just came out of a mold that is polished smooth so the rubber don't stick. And they too need to be scuffed up before they will be worth anything.
Some of them like dunlop use chrome molds so they don't need release agents, but once they pull it out of the mold, some goober wipes it down with a silicone rag before they shrink-wrap it, and send it out to the stealership.
Old July 2nd, 2012, 08:09 AM   #19
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
My tires are kinda bald, you think I can dremmel some new grooves into it?
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips
edxmon is offline   Reply With Quote
Old July 2nd, 2012, 08:47 AM   #20
sendler
sendler's Avatar
Not the same thing at all.
Old July 2nd, 2012, 10:37 AM   #21
edxmon
edxmon's Avatar
I jest, I jest
Old July 2nd, 2012, 10:52 AM   #22
never had any michelins but i have taken brand new, 0 mile bt003s to the track and took one and a half warm up laps (no warmers) before going balls out with no traction issue.
if you aren't turning much and in fact get 95 mpg which i find really hard to believe unless you are going 35mph in 6th gear everywhere, why would you bother grinding useful rubber off of a tire to make it... turn in faster??? if you drive straight 99% of the time, taking away that rubber on the side is going to do nothing but make the center of the tire wear even faster.
Old July 2nd, 2012, 10:55 AM   #23
dubojr1
dubojr1's Avatar
Old July 2nd, 2012, 11:46 AM   #24
sendler
sendler's Avatar
You don't notice a rear tire getting "edgey" during cornering after it gets flat in the center? I thought everybody new that. Cornering traction of a square rear tire is reduced when you bank up onto the sharper corner that is created by the junction of the flat center to the remainder of the normal tire shape. By grinding away the higher sides, I have simply restored the normal shape of the tire that it started out life with. At the expense of some rubber that I wasn't using very often anyway.
My 88 mpgUS lifetime average is 3/4 highway at 68mph and 1/4 city neighborhoods. The last three tanks have been over 95 mpg since I changed to longer gearing and have started using Pulse and Glide techniques (PnG).
Old July 2nd, 2012, 12:11 PM   #25
dubojr1
dubojr1's Avatar
I'm thinking the point some of us were trying to get across was your cornering must be limited or otherwise your tire wouldn't be squaring off. I also understand your point about the "factory" shape but like Alex said, if you grind the "points" of the square you are decreasing the amount of rubber contacting the road which in turn decreases your contact patch which in turn speeds the wear on the center of the tire.
I guess in summary, the tire should last longer with no grind but would not corner as good as the factory shape.
I hope the way I've worded it makes sense...
Old July 2nd, 2012, 12:22 PM   #26
sendler
sendler's Avatar
I totally understand what you said but you guys are missing something. The only thing I ground away was the sides of the tire that I was not using in the first place. The center will not wear any faster because of it and I have restored the original handling.
Old July 2nd, 2012, 12:35 PM   #27
dubojr1
dubojr1's Avatar
Ok, Let's try this.
Would you agree that a tire that has, let's say 1/2" contact, would wear faster riding straight than a tire that had a contact of 1"? Being 1" of tire has more rubber to wear off than the 1/2" right?
Old July 2nd, 2012, 12:50 PM   #28
sendler
sendler's Avatar
Ok, Let's try this.
I have also restored the normal wear pattern of the tire. Nothing worse. It was dangerous to ride with the square edge and now it rides as new again.
Old July 2nd, 2012, 12:56 PM   #29
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
I gotta say....I don't find this to be a horrible idea. It is kinda sickening to throw away a tire that has so much life left. As long as he ground it evenly, it shouldn't be any different than if he'd done a lot of heavy cornerning during the life of the tire.
Having said that, I'd never try it because I know I'd never get it even.
cbdallas is offline   Reply With Quote
Old July 2nd, 2012, 01:00 PM   #30
dubojr1
dubojr1's Avatar
It isn't time to toss it... From the looks of the pictures he can continued ride on it for a while. His only complaint is the shape.
Old July 2nd, 2012, 01:18 PM   #31
sendler
sendler's Avatar
A tire balance might be a good idea now though. 11,000 miles so far and I've never balanced the tires.
Old July 2nd, 2012, 01:27 PM   #32
EvilPooMonkey
EvilPooMonkey's Avatar
Motorcycle(s): Ninja 250 :)
if you continue to do this...just send me all of your shavings so i can save them up and make a new tire out of the unwanted shavings...we can call this process tire recycling!!!and when my new tire wears down i can shave it and send it to somebody else...rinse repeat...it'll be like the new mascot thing
EvilPooMonkey is offline   Reply With Quote
Old July 2nd, 2012, 01:29 PM   #33
the square tire is not dangerous. it takes more effort to turn in, thats all. when the tire is flat in the middle, the load of the tire is spread out. if you had left the tire alone it would have lasted maybe another 1500 miles until you got to the cords in the middle. now, you will get to the cords probably closer to 1000 miles. yes, it feels weird turning in with a square tire. if you drive straight on a tire that much you shouldnt be worried about turn-in ability. if you are actually concerned with turn-in ability you would have ditched that old ass touring tire a long time ago. figure out what you actually want to do with the bike and tune the bike for that purpose. if its commuting, or, hypermiling or whatever, then its not performance based. so doing performance modifications like grinding down an already race-spent tire when you are not using it as a performance tire is a useless waste of rubber. im not trying to sound harsh but several people have tried to explain this but you seem to not be picking that up then go to talk about how you are only restoring the 'factory shape' of the tire
edit: 1500 miles is low, im thinking softer rubber ... change those to like 4000 and 3000 or something
Old July 2nd, 2012, 01:47 PM   #34
sendler
sendler's Avatar
Nice long paragraph! I'm not sure why you are being so stubborn. The traction is poor on the square edge of a worn rear tire. The rear tire wants to slide out from under you when it gets up on that narrow edge. This is obvious and is quite common knowledge.
Old July 2nd, 2012, 02:17 PM   #35
I'm not sure I'd go that far. The contact patch always flattens out when the tire leans over, so the tire is never just sitting on any edge. The increased steering effort isn't to get over the edge as much as it's to lift the whole bike off of the flat spot in the middle. I'd hesitate to say that re-rounding the profile made anything safer, but perhaps it made the steering effort more linear from straight up and down to leaned all the way over. None of it extends the life of the tire, as it is always going to be limited by the wear in the center in this type of usage.
Old July 2nd, 2012, 02:25 PM   #36
EvilPooMonkey
Old July 2nd, 2012, 04:36 PM   #37
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
My Sport Demons got about 3k on them and starting to square off... been wondering if I need to replace them or just go do some circles in a parking lot for 50 miles each side.... guess all I need is a rear stand and some 80 grit sandpaper... Hell while I'm at it I'll grind the sidewall so it looks like I really get that bitch really low on turns and scrape elbows!
Seriously though, I kinda get the OPs meaning and logic... grinding it down may seem as the same thing as if you actually 'corner' when turning, but I wouldn't trust my life w a modification like that!! If grinding created 1 weak spot in the tire, you won't know it until it's too late!
Buy some new tires... if I had to I would buy some Rosso 2's (I want anyway) and sell you my Sport Demons w 3k on them for the price of 1 tire!
Old July 2nd, 2012, 05:07 PM   #38
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Why not just get new tires?.... The Stock IRC's suck ass anyway, you will be so much happier with a pair of 003/016
And the whole not riding after new tires thing is bullshit, they way the tires are taken out of the molds is different. Before there used to be a residue that was left over when popping the molds, they dont use that method anymore, you are fine. I road the **** out of new 016's after putting them on, and went right out onto the track with slicks fresh from pirelli
----> My Youtube! <----
Old July 2nd, 2012, 07:22 PM   #39
sendler
sendler's Avatar
I would take all of your original take offs but the rear is the wrong size for my CBR250R. The IRC Roadwinner is an excellent commuter tire.
Old September 15th, 2012, 05:01 AM   #40
sendler
sendler's Avatar
I'm up to 14,000 miles now and the square strip in the center of the original rear tire on my CBR250R needed another touch up with the grinder. 15 minutes later I had another big pile of rubber dust on the floor since I hadn't really taken it all the way the first time. Let the tire idle around on a stand and just work the square corners off with a 40 grit disc on your grinder.
Grinding or scraping sound ???? Z300 2008 - 2012 Ninja 250R Tech Talk 3 March 14th, 2013 03:05 PM
Grinding Noise!!! mlj2093 2008 - 2012 Ninja 250R Tech Talk 84 March 5th, 2013 06:41 AM
Grinding The Crack csmith12 Off-Topic 5 January 23rd, 2012 09:00 PM
Grinding noise - chain questions n4mwd 1986 - 2007 Ninja 250R Tech Talk 15 October 6th, 2011 05:51 AM
Grinding Foot Pegs jonb08 1986 - 2007 Ninja 250R Tech Talk 14 June 17th, 2009 06:57 PM
