Old January 27th, 2016, 08:30 PM   #1
Sharkride
Sharkride's Avatar
Motorcycle(s): 2010 ninja 250
Pre gen rear sets install?
Ok so I got some pre gen rear sets. And the clutch side installed with not issues. But I'm having problems with the brake side. It seems the master cylinder will not line up as if I should be using the pre gen one. I hope that not the case but then if it is I do have one laying around...any help would be great
Never rode a motorcycle but own 2
Sharkride is offline   Reply With Quote
Old January 27th, 2016, 09:14 PM   #2
Sharkride
Sharkride's Avatar
Pic
Old January 29th, 2016, 12:25 PM   #3
tonybaloni
Motorcycle(s): EX250KAF 2010
Re.pre gen rear sets
If it's any help,when I fitted some chinese rear sets I had same problem but found by reversing the master cylinder from its original position everything lined up great.Also fitted hydraulic stop light sw.which simplified the instalation. I'm still looking for a suitable pedal return spring though! Good luck
tonybaloni is offline   Reply With Quote
Old January 29th, 2016, 12:32 PM   #4
RickM
Motorcycle(s): 2000 EX250
you might be able to make it fit by adjust the threaded pushrod between the pedal and the master
RickM is offline   Reply With Quote
Old February 1st, 2016, 06:52 PM   #5
Sharkride
Sharkride's Avatar
Yeah I tried that. No luck. I really just want the right sets now
Old February 9th, 2016, 05:46 AM   #6
/moved to pre-gen tech
Old February 9th, 2016, 08:39 AM   #7
taz
taz's Avatar
MOTM - May '17
from the pic you put up of the brake master if you would rotate it so the bolt hole threads are on the other side it might work better. here is a pic for reference. https://www.ninjette.org/forums/atta...1&d=1455032298
Old February 9th, 2016, 09:12 PM   #8
Sharkride
Sharkride's Avatar
Yeah I flipped the master. I don't know if I was installing it wrong or what but now it fits. Just ordered some pads and pull the brakes off and did a crazy cleaning...a few more week I should be on the road...spring riding
Wanted: Clip Ons and Rear Sets for pre-gen Mike K Items Wanted 4 May 18th, 2015 07:35 PM
Rear shock option for pre-gen. Jammerkiller 1986 - 2007 Ninja 250R Tech Talk 11 April 24th, 2014 08:51 PM
Pre Gen Rear Fairing 20ninja03 Motorcycle-related 1 April 24th, 2011 08:42 PM
Interest in a Pre-Gen Rear rack? mikesova General Motorcycling Discussion 2 September 14th, 2010 04:58 AM
Help a newb install rear sets (with photos) jamesbernatchez 2008 - 2012 Ninja 250R Tech Talk 5 November 16th, 2009 11:17 PM
