Old April 22nd, 2009, 05:31 PM   #1
Rawr
Blue Blue Blue
Rawr's Avatar
Motorcycle(s): 2008 Candy Plasma Blue Ninja 250R
Master Cylinder woes....
ok...so i was in an accident a little while back....the fluid reservoir was drained empty...so i went out and bought some and filled it all up...started bleeding them to get all the air out...well took her out and the brakes still felt really weird...so i sat down and started bleeding some more...thats when i notice fluid leaking out of the top of the master cylinder...when i press all the way down on the pedal a small bit of fluid flows from the lower washer area on the top of the cylinder assembly...i took out the bolt and retightened it all down...and it still leaks....any thoughts? i really dont want to have to buy a new master cylinder...=(
Rawr is offline   Reply With Quote
Old April 22nd, 2009, 05:43 PM   #2
Rawr
Blue Blue Blue
Rawr's Avatar
o...forgot...this is the rear master cylinder we are talking about
Old April 22nd, 2009, 06:42 PM   #3
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
warranty?
my flickr™
sometimesido is offline   Reply With Quote
Old April 22nd, 2009, 06:46 PM   #4
Rawr
Blue Blue Blue
Rawr's Avatar
bike was considered totaled by the insurance company..............i dont believe my warrenty would still apply.....also....if i took it in and just told them nothing...wouldnt they ask about the slight damage to the end of the brake pedal?
Old April 22nd, 2009, 07:13 PM   #5
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
I'd start with new washers/gaskets and see what you get. If nothing is "bent" or warped that should take care of the issue.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
DIY - Installing a ZX-6R Master Cylinder VeX 2008 - 2012 Ninja 250R Tech Talk 33 August 27th, 2018 11:30 AM
Aftermarket Master Cylinder krolinked Ninjettes At Speed 11 October 15th, 2014 07:12 AM
Retrofit: Radial Master Cylinder ds650rida 1986 - 2007 Ninja 250R Tech Talk 10 October 1st, 2014 12:01 PM
Front brake master cylinder ninjagaiden09 2008 - 2012 Ninja 250R Tech Talk 7 April 22nd, 2014 08:51 AM
Which Master Cylinder should i get? krolinked 2008 - 2012 Ninja 250R Tech Talk 7 January 12th, 2013 01:01 PM
