Old March 15th, 2013, 01:22 AM   #1
krolinked
Nerd
krolinked's Avatar
What is the Optimal Valve Clearance?
And Why?
Who has opinions and or experience in choosing a particular valve clearance to get a desired effect?
I would like to understand and gain some tips on setting my valve clearance.
Old March 15th, 2013, 02:04 AM   #2
Check this article out (numbers apply to pre-gen):
http://faq.ninja250.org/wiki/What_ar...ance_ranges%3F
".......tighter clearances will increase top-end power, increase the chance of burning valves, reduce low-end power, and adversely affect idling.
Looser clearances will make it idle better, increase low to mid power, and help to prevent burnt valves, at the cost of top end power. Of course, if you go too loose then you will have a lot of valve train noise."
Old March 15th, 2013, 02:25 AM   #3
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
That is correct. The reason is. The loose clearance allows the valve to open later than a tight tolerance. This effectively advances the cam timing. Also the duration will increase.
Worlds fastest 250 ninja
valve clearance sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 July 18th, 2014 06:19 AM
Should I do the valve clearance inspection myself? nickjpass The Ex-Ninjetters Lair 13 June 13th, 2014 12:50 AM
Valve Clearance Problem ElJokerr 1986 - 2007 Ninja 250R Tech Talk 9 February 22nd, 2013 12:40 PM
valve clearance specs dotsony 1986 - 2007 Ninja 250R Tech Talk 20 March 17th, 2011 02:46 PM
valve clearance??? what are they supposed... ecannon1 1986 - 2007 Ninja 250R Tech Talk 3 May 20th, 2010 10:41 AM
