Old August 24th, 2016, 07:40 PM   #41
mgentz
Board Member
had this. synthetic oil cured it...
some oils just suck.
Old August 24th, 2016, 08:13 PM   #42
bogiejr
bogiejr's Avatar
That is something I also wondered if the type of oil was causing this. I have a semi syn in there now. Was your filter screen dirty? Did you keep same weight when switching to synthetic?
bogiejr is offline   Reply With Quote
Old August 25th, 2016, 04:32 AM   #43
mgentz
Board Member
Went from Dino to full synthetic. My screen was not dirty. I clean it regularly and I always use k&n oil filters.
I did not change oil weights.
Old August 25th, 2016, 12:06 PM   #44
bogiejr
bogiejr's Avatar
Thats good to know. Did this synthetic oil change involve an oil filter o-ring swap? I don't believe K&N filters give you new o-rings. However, I don't use their over priced Chinese filters but do have their air filters.
The type of oil could definitely play a factor in this. Im running a semi-blend 10W-40. Only used kawi conv oil until around 3K during break in.
Old August 25th, 2016, 02:07 PM   #45
5w-40 means when its cold, it behaves like a 5 weight oil. when its hot, it behaves like a 40 weight.
when single viscosity oil warms up, it gets less viscous.
but a 5w oil is less viscous than a 15w oil, when they are at the same temperature.
multiviscosity oil means that the oil does not change viscosity as much as a single viscosity oil would. as in, when it heats up, it doesn't thin out as much.
so if it was single viscosity 40 weight... when it got cold, it would be much too thick. if it was single viscosity 15 weight... when it got hot, it would be much too thin.
engines are made of metal. metal changes size when it heats up. every single clearance on the engine is "incorrect" when it is cold. only once they are hot do they take the correct clearances. the clearances they take up when cold are very different. the cold weight of the oil must match these cold clearances. if the cold weight oil doesn't correctly match the cold clearances of the engine, you get bearing and oil pump wear.
when a lubrication system is designed for a maximum amount of viscosity for the given clearances (e.g. on ours, 15w cold) when you try to push oil with less viscosity through it (10w, 5w, cold) then the oil pump won't produce as much pressure until it warms up and those clearances tighten up. the crank and cams also will have too much clearance until it warms up.
someone thumbed up this post and i noticed i misspoke.
when you run an oil with a cold weight that is higher than stock, it raises the oil pressure. the flow is essentially constant.
Old August 25th, 2016, 02:11 PM   #46
bogiejr
bogiejr's Avatar
You are correct that the oil preasure will be higher with a higher base weight oil. However, flow is quicker with lower weight oil especially at startup and in cold temps.
Old August 25th, 2016, 07:34 PM   #47
every oil pump i've seen is constant volume type that doesn't "leak back" which means flow should be linear with oil pump rpm. oil weight, oil pressure, oil temperature... nothing changes the fact that the oil pump is constant volume per rpm.
Old August 25th, 2016, 07:38 PM   #48
mgentz
Board Member
Pressure can be increased by modifying the relief valve. Volume is volume with our OEM pump.
Old September 6th, 2016, 03:28 PM   #49
bogiejr
bogiejr's Avatar
update...
Drained the oil and spun the filter off. As soon as I got the filter off, I realized what the problem probably was because I found that the filter grommet was jammed against the union Bolt causing it not to move up and down. I believe this was from the Grommet being improperly sized. I fixed it, reinstalled it, and it's been working fine ever since. Still trying to prove it out but I think that was the major problem. Hopefully, it's fixed now. To be more clear about it, the top of the filters grommet was jammed against the end of the threads on the union Bolt.
Old October 2nd, 2016, 09:45 PM   #50
Glad it's fixed!
Old October 26th, 2016, 10:05 AM   #51
bogiejr
bogiejr's Avatar
Anyone tried the fram oil filter instead of wix? Generally not a fan of fram, but it looked like it was made well. India made.
oil pressure light contact148 2008 - 2012 Ninja 250R Tech Talk 28 June 21st, 2018 06:54 AM
Oil Pressure Light on Startup quicklooker 1986 - 2007 Ninja 250R Tech Talk 28 July 19th, 2013 07:16 AM
Oil pressure light question... Iffita 1986 - 2007 Ninja 250R Tech Talk 3 October 9th, 2012 07:44 PM
Oil pressure switch randomwalk101 2008 - 2012 Ninja 250R Tech Talk 13 February 23rd, 2011 06:58 PM
Oil & Temp light staying on longer at start-up headshrink 2008 - 2012 Ninja 250R Tech Talk 5 June 19th, 2009 01:24 AM
