Old April 24th, 2020, 06:51 PM   #1
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
Dyno Jet kit help/questions
Anyone else using Dyno Jet stage 1 jet kit and find that it runs way to rich. I bought it and did the stage 1 which by the manual says stock air box and filter (I’m using drop in UNI filter) and stock or slip on exhaust (running stock mufflers at the moment) Eclip on the needles 4 slots down from the top, 2.5 turns out on the Air fuel screw, drilled slides with supplied drill bit, and used suggested main jet from the Dyno jet instructions. This Dyno jet kit uses stock pilot jet. So far I can tell it’s running rich you can smell how rich it is through the exhaust.
Prior to this I have all stock carb components and had 1mm shims under the stock needles, 2.5 turns out on the air fuel screws. Ran great.
But this Dyno jet kit has ruined how this bike runs. Just want know know if anyone has experience with the Dyno Jet kits and what you thought about it. Valves were adjusted, Carbs were sync’d, set float height wet and set to the base of the carb body prior to installing jet kit.
ssrsupermoto is offline   Reply With Quote
Old April 24th, 2020, 11:01 PM   #2
On all jet kits i’ve used, i’ve always ended up with smaller-than-stock jets after dyno-tuning. Down one size on race-bike with full-exhaust and down 2-sizes on street bike. The needles provided does richen up mid-range, so some richness with stock-sized jets can be expected. You’ll want to dyno-tune or used wideband-O2 with data-logging to really dial it in.
Old April 30th, 2020, 04:33 AM   #3
ssrsupermoto
I ended up using the stock pilot and stock main jet with the Dyno Jet needles in the 4th groove from the top and 2.5 turns out on the air fuel screws. I had two sets of slides so I drilled one set and for street riding the drilled set sucks. I put the stock non drilled slides back in, I would say if you had a straight race bike then your would want the slides drill but not for a street ridden motorcycle.
08 plus carb set wit dyno jet - jet kit 150.00 genosr1 Motorcycle-related 1 January 31st, 2017 04:19 PM
FS: Customled Kit and Area P Full Race Exhaust+Dyno Jet Race Kit n250r Motorcycle-related 7 January 30th, 2014 03:27 PM
Dyno Jet Kit Pudge Ate Me 2008 - 2012 Ninja 250R Tech Talk 1 April 8th, 2012 05:43 PM
Dyno Jet Kit stage 2 08 and up Shaol1n Monk Motorcycle-related 2 February 2nd, 2012 10:56 PM
DYNO JET KIT query shporsche 2008 - 2012 Ninja 250R Tech Talk 3 February 26th, 2009 05:23 PM
