Old February 28th, 2013, 08:13 AM   #1
xaple
xaple's Avatar
Unresponsive Throttle
Back story: I had a gas tank that had a huge dent/bend/crease in it that I had been using for the past 2 or 3 months. I discovered that a tank in such a condition could have rust on the inside that would cause problems with the carbs, such as clogging.
I now have a new tank that's in pristine condition but I'm not happy with the way my throttle is responding. If i pull in the clutch and try to give it a lot of gas it doesn't really do anything, like its coughing or something. Same thing happens when I'm moving or not moving. If i try and get a fast start sometimes it will pick up and go other times it will kind of lag a little then kick in.
I also have a full Area P exhaust system that I installed myself with a stage 2 Dynojet kit. I believe i have the #96 jets in (not 100% positive) with the idle screws turned out 2.5 turns and a washer under each needle. Kerry (AreaP owner) walked me through the whole process personally so i cant imagine my tune up was the problem being as it hasn't always been this way.
does this sound like a problem cleaning the carbs could fix? Or is it something more?
xaple is offline   Reply With Quote
Old February 28th, 2013, 08:24 AM   #2
Check this thread first:
http://www.ninjette.org/forums/showthread.php?t=124374
Old February 28th, 2013, 08:26 AM   #3
DaBlue1
DaBlue1's Avatar
Have you checked to see if your filter is dirty or snorkel is blocked?
http://www.ninjette.org/wiki/Troubleshooting_Guide
Old February 28th, 2013, 09:04 AM   #4
xaple
xaple's Avatar
Cleaned my filter out not to long ago and I removed the snorkel. Bike has 9k miles btw
Old February 28th, 2013, 09:13 AM   #5
xaple
xaple's Avatar
Originally Posted by Motofool View Post
where exactly is http://www.hondaatvforums.net/forums...ash_filter.jpg
that thing
Old February 28th, 2013, 09:29 AM   #6
DaBlue1
DaBlue1's Avatar
Originally Posted by xaple View Post
Here
Old February 28th, 2013, 09:50 AM   #7
xaple
xaple's Avatar
Here
thank you Looks like i got a project for the weekend
Old March 2nd, 2013, 09:17 AM   #8
iZapp
former ninja 250'er
iZapp's Avatar
Motorcycle(s): Aprilia 1000R, CRF450, CBR600RR tracktoy, Ninja 250 -- GONE!!!!!
if your fuel filter is clogged, it would imply that the bowls WOULD be full of fuel, at least until the demand for fuel by the engine exceeded the flow of fuel through the filter. At that point the fuel level in the float bowls would begin to drop and eventually the motor would begin to bog.
so, if the engine starts hard, or will only run with choke, or will not accept any throttle, then i would suspect the tiny primary jets (aka pilot jet) inside the bowl. this is very likely.
if it revs up, but falls on its face then the main jet is the issue. not likely.
if it revs up, runs ok, but seems to lack some power, then air delivery is the issue like filter.
hope that helps.
iZapp is offline   Reply With Quote
Old June 28th, 2015, 04:10 PM   #9
DamonDanner
Motorcycle(s): 2010 Ninja 250
something to check...mine did the same thing so I went to check the little fuel filter...my petcock was on the "reserve setting" took off the fuel line and almost NO GAS FLOW...put it to the down position and gas really flowed...don't know if I got a piece trash in that tube or what, bout to go test it now... mid range was really boggy, but other than that is seemed OK. test ride! Yes...reserve setting wasn't letting enough gas get through...now how to fix that? I blew through the hose into the tank...still plugged.
DamonDanner is offline   Reply With Quote
Old June 28th, 2015, 04:58 PM   #10
Ghostt
Ghostt's Avatar
FYI,
NewGen doesn't have a reserve, it has, ON, PRI, OFF. no reserve. Also remember that it's a vacuum peacock, so if the engine isn't running, and the petcock is set to ON , no fuel should flow, that's why there is a PRI /prime, thus allows fuel to flow without vacuum.
PreGen doesn't have a prime, just ON, RES, OFF and vacuum is needed all the time.
violente et ignorantia
ZX-2R BLOG
Old June 28th, 2015, 05:01 PM   #11
DamonDanner
Prime
hmmmmm... well in the "on" position it ran normally, will switch back to "prime" and see if it acts up again... thank you for the tech info on that! Perhaps I have my positions on the petcock confused? Arrow down is on correct? "3 oclock" would be prime?
Old June 28th, 2015, 05:09 PM   #12
Ghostt
Ghostt's Avatar
Not sure on the NewGen, but with the engine off, you should have no fuel flow when set to ON, only PRIME Will allow fuel to flow.
If fuel is flowing with the petcock in ON, then it's time to rebuild the petcock.
ZX-2R BLOG
Old June 28th, 2015, 05:14 PM   #13
DamonDanner
ok...had positions wrong...it's operating normally!
Old June 28th, 2015, 05:38 PM   #14
Ghostt
Ghostt's Avatar
good deal
ZX-2R BLOG
Unresponsive throttle (2007 Ninja 250) Twitchy Stitch 1986 - 2007 Ninja 250R Tech Talk 25 November 26th, 2014 10:58 PM
Full throttle kills bike, throttle lag response. Diegone 2008 - 2012 Ninja 250R Tech Talk 10 April 30th, 2014 03:25 AM
[twisted throttle] - Visit the Twisted Throttle Open House & 10th Anniversary Party o Ninjette Newsbot Motorcycling News 0 April 13th, 2012 07:40 AM
Bike acceleration occasionally becomes unresponsive OddlyOrdinary 2008 - 2012 Ninja 250R Tech Talk 10 October 28th, 2011 08:57 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
