#1 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
Barnett Clutch Kit
#2 |
MOTM - Sep '18, Feb '16
Better call them and ask. I have used these kits a lot and never seen a black clutch plate. I don't think it matters. But better check with Bennett
#3 |
Wannabe Reborn
A quick Google returned this:
http://www.barnettclutches.com/servi....aspx?faq_id=6 It's just a general FYI for clutch service from Barnett, not specific to the bike. Looks like bike specific instructions may be enclosed with kit. Have your taken bike apart yet? Does it have a blue/black plate in it originally? I haven't gotten to mine yet, so I don't know specifically. Obviously Racer X is a good resource as I'm sure he has seen his fair share of 250 clutch kits...let us know how it turns out. I've been eye balling this kit mainly cause I want to upgrade/replace the clutch in my bike.
#4 |
I sent Barnett an email. Their reply can be found below. I'll post a little review of the kevlar clutch for road use in a few hours.
"Bradley, the plates are in fact exactly the same. Makes no difference how you install them. The difference in the color is just that they are from different lots. The green and black adhesives are just different ones that were used at different time. The greenish color is the one we are using at present. Both work equally well. The blue/black color was discontinued due to EPA regulations here in the ‘wonderful. state of California! If you look at the dates on the individual bags, you’ll see the one plate was made at a different time...." |
#5 | |
Are you upgrading the clutch springs themselves as well?
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#6 |
Yes, new frictions, steels and springs. I've had the kit for a while now, just been waiting for the moment when the old clutch needed replacing.
The Barnett clutch is as smooth as OEM. The force required to pull the clutch lever back is about 50% more with the new springs but its not so hard that you will get tired in city peak hour traffic. Seems like a pretty good replacement for the stock set-up. |
#7 |
The weak link so to speak of is the springs, the plates and steels Kawasaki uses in the Ninjette bigger brother's like the KZ1000 ETC...
Kawasaki uses weaker springs, due to its a beginner's bike, this causes could cause slippage at high RPMs, as experienced with the EX500. Upgrading to the ZX600 springs is a common upgrade on the EX, and I believe it should be as well on the Ninjette as well. And we must also keep in mind that the Ninjette only uses 4 springs!! So it needs all the help it can get.
#8 |
I am thinking about having a custom cover and clutch drum made. I would like to use a zx6 clutch. The release mechanics would probably need to be changed to hydronic and a new side cover would need to be fabricated. It's about 1400 bucks from what people tell me.
#9 |
Would be awesome to see, but not at that cost, too bad.
#10 |
Yes a bit pricy. Five or six springs are the thing that is needed. Or a lock up. But that requires a new cover also. That is the money part
#11 |
I've done the spring modification to both my EX and Ninjette it's definitely worth while investment.
[roadracingworld.com] - Barnett 2013 Triumph 675 Clutch Kit | Ninjette Newsbot | Motorcycling News | 0 | November 3rd, 2013 09:10 PM |
[sportrider - latest stories] - Barnett ‘Second Generation’ Ducati Dry Clutch Kit | Ninjette Newsbot | Motorcycling News | 0 | November 9th, 2011 10:40 AM |
[motorcyclistonline] - Barnett Clutch Kit: Ducati Multistrada 1200 & Diavel | Ninjette Newsbot | Motorcycling News | 0 | May 19th, 2011 09:50 PM |
[motorcyclistonline] - Barnett Perfomance Clutch Kit- 2006-11 Kawasaki ZX10R | Ninjette Newsbot | Motorcycling News | 0 | April 20th, 2011 11:40 PM |
[motorcyclistonline] - Barnett Clutch Kit - Harley Davidson XR1200 | Ninjette Newsbot | Motorcycling News | 0 | July 12th, 2010 08:40 PM |
