March 10th, 2012, 04:11 PM | #1 |
Join Date: Oct 2011 Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900 Posts: 320
Choke cable relocate
Working on making the 250 track-only and got a question. Is there a DYI mod to relocate the choke cable? Seen a kit for it but was hoping someone had a home-made solution. Thanks.
March 10th, 2012, 06:19 PM | #2 |
I hear a lot about people zip tying a loop to the carb directly and just using that.
Else, you could use the barrel end from the choke cable and retrofit it to a friction shifter from an old bicycle (likely it won't fit, too big -- use some creativity!). Something like that though would work. That way you won't have to hold it until the bike warms. http://www.treefortbikes.com/product...-friction.html You could probably fix that to the frame somewhere, I'm sure. |
March 10th, 2012, 07:42 PM | #3 |
Thanks for the suggestion Dave...the bicycle thing looks good cause you could modulate the amount. I was thinking about a universal choke cable like this: http://www.ebay.com/itm/Choke-Cable-...#ht_713wt_1165. Think that only has an on/off though.
March 11th, 2012, 01:57 AM | #4 |
CMRA Mini Endurance #6
Join Date: Mar 2011 Motorcycle(s): CBR954, CBR600RR, EX250 Posts: 108
I just have some safety wire with a loop in the end to grab (comes out by the fairing hole). Grab with left hand, full choke, hold/modulate for about 15-30 seconds, good to go.
CMRA #328 Ridesmart.info Instructor |
March 11th, 2012, 10:31 AM | #5 |
It that works, it's good enough for me
Last futzed with by pjed; March 11th, 2012 at 10:31 AM. Reason: spelling |
March 11th, 2012, 01:37 PM | #6 |
March 25th, 2012, 06:47 PM | #7 |
I did this mod today and it worked great. Sorry, I spaced taking pics but I'll try to remember next time I have the fairings off. Pretty simple really. I ran a good amount of safety wire through the eyelet that the choke cable normally connects to. Spun it till I had a good strand away from the fairing and then made a loop back around my finger. Hides behind the fairing when not used
April 21st, 2012, 04:39 PM | #8 |
This doesn't really show how the wire is hooked up to the carb but gives the main idea. Works awesome.
Where to relocate stuff? | djjontran | 1986 - 2007 Ninja 250R Farkles | 8 | July 21st, 2014 09:13 AM |
Never using choke | kano6280 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 29th, 2012 03:26 PM |
License Plate Relocate Fail | HKr1 | General Motorcycling Discussion | 24 | April 16th, 2011 07:00 AM |
slight choke cable issue | scorpio_vette | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 20th, 2009 11:43 AM |
