April 20th, 2013, 09:25 AM | #1 |
Couple of questions
First off, the carb has been a little flakey/finicky. While I had it out to shim the needles, I was gonna chem dip it but that didn't work out because I couldn't get all the screws to break loose. So I figured I'd save that for another time and just use some Seafoam.
Filled the tank full, add the seafoam additive, went for a long highway drive. I held it at about 11k for little over an hour with a one break in between that hour (stopped to get something to eat). No problems, sounded fine when I started her back up. I get back into town, remove my ear plugs (cause the wind on the highway was loud on the helmet), and notice a loud ~rapid~ chatty noise from the engine. Sounded like it was coming from the valve train, but I could also hear it in the right side of the engine near the tranny area (either way, it was louder on the right side of the engine). I remember that I hadn't changed the oil on the bike since I bought it, even though I only put 1k miles on since then. I was only going to change it since I didn't exactly trust the seller, but I had forgot about it (I check the oil levels all the time, it was full, doesn't leak, and doesn't appear to burn any). I didn't ride the bike for a day and went to get supplies to change the oil. The oil color itself was fine, a little dark but still a slight golden tinge to it (not completely burnt). No metal-y flake or powder in it. Until I pulled the screen off. I found what looks like machine shavings in there. They're aluminum (or something else, doesn't stick to a magnet). They don't look like baring pieces or cam lobes or such (I've done my share of classic chevy engine tear downs and rebuilds). They look like.. well, machine shavings. I'm assuming since that I the oil doesn't have any metallic flake or dust, or in the filter either, that this was something previous? The oil cover bolt has some wear marks on it like someone used an over sized wrench or something (i.e. looks like someone changed the oil that didn't know what they were doing - not a professional place or such), so I'm going to assume the original owner did the oil changes himself, but never looked at the screen. So two questions; does that sound about right on the metal shavings? Maybe something left over from the factory (or else this engine had some work done on it)? And for the value train noise, is it possible the timing chain stretched? Edit: added pics. |
April 20th, 2013, 09:47 AM | #2 | |
It is also possible that the valves are out of adjustment, inducing noise. It is possible that the cam chain is within spec but not properly tensioned due to defective or neglected automatic tensioner or damaged rubber guides (hence metal debris from chain slapping the aluminum case).
April 20th, 2013, 10:27 AM | #3 |
I noticed something else. I got my filter, o-ring, and crush washer from Ryde Now (only Kawa dealer in town) and the crush washer is too small for the drain plug. Maybe they stripped out the original hole and re-cut it for something bigger, and this is where the metal shavings came from (they had some sort of make shift gasket on the drain plug). What's the diameter of the original drain plug threads?
April 20th, 2013, 10:47 AM | #4 |
It is a M12 x 15 mm length.
The washer-gasket is 12 x 22 x 2 mm.
April 20th, 2013, 02:10 PM | #5 |
Okay, the washer is correct (12mm ID). And the bolt is not (13.8mm OD on the threads). They definitely re-cut it for a larger plug instead of helicoiling it. That's most likely where the shavings came from. That just leaves the valve train noise (I already adjusted the valves a couple of weeks back).
April 20th, 2013, 03:56 PM | #6 |
Excellent catch !!!
The tensioner should be serviced each time that the valves are. Note: Do not turn the engine while the tensioner is out. This related thread shows some tips about the tensioner: http://www.ninjette.org/forums/showt...ner#post666203
April 20th, 2013, 05:02 PM | #7 | |
April 20th, 2013, 05:14 PM | #8 |
You are welcome
Couple simple questions.. | corksil | General Motorcycling Discussion | 21 | February 14th, 2014 11:26 AM |
My first ninja a couple of questions | stegser | General Motorcycling Discussion | 12 | January 23rd, 2014 09:23 PM |
Couple questions, unrelated. | thurt88 | General Motorcycling Discussion | 15 | May 4th, 2012 11:27 PM |
Couple of quick questions | zach | 1986 - 2007 Ninja 250R Tech Talk | 10 | July 8th, 2009 06:47 PM |
Couple of questions | pantera | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 6th, 2009 01:27 AM |
