November 4th, 2011, 07:25 AM | #1 |
Am I the only one who laughed when I watched this video?
This is just plain old ridiculous. Watch it and you'll see what I mean.
November 4th, 2011, 07:51 AM | #2 |
Join Date: May 2011 Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue Posts: 623
Is that scott's damper not connected to anything?
November 4th, 2011, 08:03 AM | #3 |
Looked at Scott's site & photos, looks like the damper is set up as shown in their photo.
Lot's of stuff on that Ninja! |
November 4th, 2011, 08:05 AM | #4 |
Blue Shell magnet
Join Date: Aug 2011 Motorcycle(s): 1997 Ninja 250 Posts: 816
Lol wow...some people...
November 4th, 2011, 08:09 AM | #6 |
On scotts site the sliver part with the slot has a pin in it that is connected to the frame. That bike in the video has no pin. look at 1m18s you can see that the slot is empty.
November 4th, 2011, 08:18 AM | #7 |
November 4th, 2011, 09:49 AM | #8 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
I don't see a problem there. I just see a video of a husband who's lovingly customized a Ninjette for his wife! That exhaust seemed overly noisy for my tastes.
November 4th, 2011, 10:01 AM | #9 |
November 4th, 2011, 10:02 AM | #10 |
Join Date: Oct 2011 Motorcycle(s): 250 Ninja - Soon Posts: 96
I have to agree with you Akima,,,,
I don't see anything out of the ordinary on this bike, most of it was done to help out his wife to get on and off the bike safely, and handle it at a stop. Some is cosmetic, the green rims, but hey most put on just the pinstripe, he decided to do the whole rim, he did a tail eliminator, and got rid of the front blinkers, and incorporated it into the mirrors instead. Yes the exhaust is a bit loud, even for my taste, but to each his own, my Yosh pipe on the 750 is loud, and I like it. Actually if you listen to all he has done, it's all be done correctly, and nothing has been done to hamper the bike.... I have seen this vid in the past, and I liked what he did, and still do sorry I don't see this as a fail.....but that is just my opinion |
November 4th, 2011, 10:18 AM | #11 |
Join Date: Aug 2011 Motorcycle(s): None yet, yet. Posts: A lot.
thats a lot of fking mods.
id rather have the Repsol |
November 4th, 2011, 10:37 AM | #12 |
Join Date: Oct 2011 Motorcycle(s): '06 Ninja 250 Posts: 87
I agree with everyone else, I think it looks good and well done, other the the above mentioned problem. Short people should be able to ride too. All the better on a good looking bike.
Behind every great man is a woman rolling her eyes. - Jim Carrey |
November 4th, 2011, 10:54 AM | #13 |
It has a glorified straight pipe on the exhaust. A Steering dampener, which is NOT necessary on these bikes. And it's been dropped so far that it has chewed up the inside of the rear fender and the dogbones only clear the ground by a couple inches. He spent all that money on this bike (powdercoated rims, full exhaust, jet kit etc) but gets cheapy mirrors, leaves open holes where the turn signals used to be, and then keeps the stock tires... that's a joke. I bet the fender slams into the bodywork too. then to top it all off, there's stickers all over it.
The details aren't there. It just made me laugh, that's all. There's nothing wrong with modifying a bike so that his wife can ride comfortably with him by lowering it. In fact, I applaud that. The rest of it just makes me laugh. That poor ninja |
November 4th, 2011, 10:59 AM | #14 |
Nooblet
MOTM - Oct '13
The stock tires aren't that bad. Unless you're racing, I see no reason why you can't use the stock tires until they wear out, before buying a new set.
He might also be planning to fill the indicator hole. Just out of curiosity: why do you think a steering damper is not necessary? I don't know much about them. |
November 4th, 2011, 11:37 AM | #15 |
Always.
Join Date: Mar 2011 Motorcycle(s): '08 Ninja 250, '05 GSX-R600 Posts: A lot.
I don't understand... what's wrong with this video that's so funny?
p.s i never understood risers to lower the bars LOL
blink-182 |
November 4th, 2011, 12:04 PM | #16 |
Join Date: Sep 2009 Motorcycle(s): Blue 2009 Ninja 250R Posts: 103
I was waiting for someone to hop the curb and smash his bikes...I might have laughed if that happened.
November 4th, 2011, 12:10 PM | #17 |
Steering dampeners are needed on some supersports because the angle of the forks is so close to 90 degrees with the ground because it makes the bike turn in quicker. This also makes the bike less stable and much more prone to tank slappers. The steering dampener gives resistance to the bars turning and therefore gets rid of that tendency to tanks-slap.
The forks on a ninja 250 are very far from 90 degrees. This means that the bike is very stable at speeds and is not likely to go into a tank slapper. The only time you would need a steering dampener on this bike is if you dropped the front end significantly with out lowering the back, or raising the back significantly without raising the front. The front of these bikes can be dropped an inch or so easily without any worries, but they do get the occasional wobbly front if you take railroad crossings/humps in the road too fast and take almost all the weight off the front end. Even then, the 250 is light enough that you can just stiff arm the bars still and give it throttle and come out fine. here's a good article to just get the basic ideas of bike/motorcycle geometry. I'm not using wikipedia as a rock solid source here, just a quick reference, so please no one flame me for my use of wikipedia as an informational site: http://en.wikipedia.org/wiki/Bicycle...cycle_geometry It's just so overdone, yet so half done that it just made me laugh a little. They turned a perfectly good, fun bike into a bike that won't lean very far because it is so low to the ground. And we all know that quick turns and lightness are the best traights about a 250. Besides, wouldn't common sense say that you wouldn't want the back wheel rubbing on the inside of the fender when you ride. |
November 4th, 2011, 01:14 PM | #18 |
im at work and i just busted out laughing when i saw the $500 damper that ISNT CONNECTED! lmfao!!!!
November 4th, 2011, 01:38 PM | #20 |
Winging It In Life
Join Date: Aug 2011 Motorcycle(s): 2010 250R; 2011 250R (sold) Posts: A lot.
The only thing that made me laugh was the way he spoke. He didn't even pronounce 'accordingly' correctly.
My sense of humor is humorous. Btw, that's a nice looking Repsol.
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015) 2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current) |
November 4th, 2011, 04:05 PM | #21 |
November 4th, 2011, 04:16 PM | #22 |
Winging It In Life
You're the only one who laughed when you watched this. I'm the only one who laughed when I watched this.
November 4th, 2011, 04:18 PM | #23 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Totally thought she was going to be hot... Nope... Looks like she could be his mom
----> My Youtube! <---- Unregistered, watch my youtube page! |
November 4th, 2011, 04:34 PM | #24 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
4.5" drop, and the bike has 6.1" ground clearance stock. And that's not taking into account the sag from the rear shock. I hope they enjoy not being able to get over speed bumps, curbs, and parking lot entrances.
All he did really was squid out the bike. An unnecessarily loud exhaust, "stage 2" jet kit (LOL), lowered it so it's nearly sitting on the ground, installed a nearly useless damper that's not even connected, and cheaped out on the integrated front mirrors. Sure it may be a bit more comfortable for her to sit on when sitting still, but it seems pretty useless as an enjoyment bike.
Life's better on the Mountain. |
November 4th, 2011, 08:21 PM | #25 |
I don't get the joke...I thought maybe someone was gonna hop on the bike in the end and steal the bike. Sadly disappointed.
November 4th, 2011, 09:00 PM | #26 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
That bike must ride horribly... I can understand lowering it for a shorter rider... but not so much that it's unrideable. They don't make front lowering blocks that large because it isn't advisable.
I too caught the undertail that was worn through from rubbing on the back tire... that doesn't seem very safe to me Trust me I understand modifying an entry level bike... I've spent over $2K on my $4.5K bike, so I don't feel adding mods is useless... but when it makes the bike unsafe or nearly unrideable it is indeed a fail.
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
November 4th, 2011, 09:11 PM | #27 |
Short people need to ride too, that's why we lean to one side! I'm not quite that short, but dang 4.5" drop; the new generation 250 only has 6.1" of ground clearance! A pothole would bottom that thing out, need not mention a speedbump!
But hey, if she rides it, I have no qualms. |
November 4th, 2011, 09:29 PM | #28 |
Ambrosia.
Thinking about it, I can't imagine how much lean angle is gone from a 4.5" drop. If I could scrape pegs leaning at stock height, and I didn't even get to the edge of the tire...
November 4th, 2011, 09:51 PM | #29 |
There's a limit to s2pdty
Join Date: Apr 2011 Motorcycle(s): 250r ninja (sold) Posts: A lot.
What's wrong with this vid o.o? it's their bike... I believe they're entitled do what ever they want. It doesn't seem practical and some of it doesn't make sense. but yeah it's their bike.
November 5th, 2011, 05:32 AM | #30 |
The plot was lame and the ending... anticlimactic. He wasn't as gangsta as most of the walk around videos I've seen, but I still must give this video a thumbs down.
November 5th, 2011, 07:56 AM | #31 |
MOTM - Mar '13, Jun '14
Anyone know where I can get a pair of those valve stem covers?
November 5th, 2011, 08:03 AM | #32 |
Kamikaze Squirrel
4" drop brings the bike seat height to 26".
That's one tiny wife. I don't get all the hate though, he dressed up the bike for his lady. I'm sure plenty of people would do the same to ride with their SO. |
November 5th, 2011, 03:15 PM | #33 |
Winging It In Life
Rewatched the video. Was that older woman his wife?
November 5th, 2011, 06:08 PM | #34 |
I wonder if there is a tally on how much money went into modifications on that bike.
I had a pretty good chuckle with this video. I respect his initiative to get the bike ridable for his wife but some of those mods are not in the rider's best interest. Especially if he/she is a new rider. A 4.5" drop is quite a bit and is kinda dangerous. An integrated tail light only makes it more difficult to see the signals and with that hole in the rear fairing, I cant imagine how much stuff is going to end up being flung up there on a rainy day. |
November 6th, 2011, 09:05 PM | #35 |
August 10th, 2013, 06:25 PM | #36 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
are they members here?
I watched to see the 2nd bike, and the race exhaust sound clip
I never knew Jardine made a race muffler for the 250 http://youtu.be/ZAuRcjDjihc the youtube button dont work for me, I copy the "share url" from youtube page and paste here but it dont work?
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
August 10th, 2013, 06:33 PM | #37 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
August 10th, 2013, 06:38 PM | #38 |
well... okay so are they members here?
well... lol okay, but the exhaust and the Repsol bike is why is posted it
August 10th, 2013, 06:40 PM | #39 |
I bet if you look in the bling area you will find the old thread about this and it may tell you if they are members or not.
August 10th, 2013, 06:55 PM | #40 | |
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- Last futzed with by Bob2010; August 10th, 2013 at 09:32 PM. |
I laughed way too hard at this. | daisha | Off-Topic | 9 | June 14th, 2013 09:52 PM |
Just watched twist of the wrist 2 | DennyV | Riding Skills | 25 | September 8th, 2012 01:28 PM |
Watched a guy go down in front of me | AlanDog | !%@*#$%!)@#&!%@ I crashed! | 13 | July 13th, 2012 06:47 PM |
Watched my first rider go down | OddlyOrdinary | General Motorcycling Discussion | 25 | March 15th, 2012 12:54 PM |
I just laughed so hard, I cried. | CynicalC | Off-Topic | 13 | October 4th, 2011 02:45 AM |
