Old May 20th, 2012, 01:08 AM   #1
stretched cam chain
theres too much slack in my cam chain even when the tensioner is fully extended and its smacking around in there. anyone ever swapped the cam chain before? it seems pretty straight foreward... clutch cover and valve cover off, cct off, cams off, chain out and replace... put back together... right?
Old May 20th, 2012, 04:41 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
nope
you have to split the case and lift the crank up to get the chain out. it goes around the crank and has no link.
It is odd to stretch a cam chain. are you sure the tension er has not failed?
Old May 20th, 2012, 06:14 AM   #3
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
Oh it stretches, all chains stretch from use. I had to replace my cam chain in my 1994 last summer. The chain was $60, and the work was over to $600 because, like you said, the case had to be split open to get the chain off.
http://mefi.us/images/fuelly/sig-us/112292.png
sombo is offline   Reply With Quote
Old May 20th, 2012, 12:53 PM   #4
hmm... the tensioner seems to work fine... but it goes all the way out and the chain still has slack... to the point that it hits the case. im worried it will jump and i'll wind up smashing valves into pistons... what do you think the chances of that are, eric?
i'm wondering if it will hold up for 3 practice sessions and a race... if it will i'll run them next week and tear it down after. if its risky then maybe i'll skip the race weekend
Old May 20th, 2012, 03:22 PM   #5
flynjay
flynjay's Avatar
The odds are pretty good. Mine did that last month. Valves are all buggered up.
Runs fine now..... once I replaced the motor.
Old May 20th, 2012, 03:32 PM   #6
its a good thing engines are cheap and i have other bikes. anyone ever locked a motor on the track before? i've seen some videos. they make pretty cool crashes
Old May 20th, 2012, 04:19 PM   #7
Racer x
Racer x's Avatar
My friend had a two strike lock up at over 100 mph. Quick clutch work saved it..
Yes if it's slapping that bad don't risk it. APE sells a manual tensioner for the 08 and newer.
Old May 20th, 2012, 06:04 PM   #8
cuong-nutz
cuong-nutz's Avatar
Oh. Caca. How many miles do you have on your bike.
HalfFast Racing Team
Old May 21st, 2012, 12:03 PM   #9
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
buy the APE, I need to tighten my APE down again, just started ticking last night
----> My Youtube! <----
Old June 11th, 2012, 09:42 PM   #10
My chain breaker has a cam chain pin and I saw a youtube video where someone replaced theirs on a dirt bike "the easy way" by splitting it, attaching to the new chain with a wire and turning the engine over until it came out the other side, preserving the timing. I'm still not sure how he connected the chain together without a master link of some kind.
Old June 12th, 2012, 07:33 AM   #11
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
Does it not run like crap? If it is stretched enough to slap around, seems the timing would be way late.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old June 12th, 2012, 09:24 AM   #12
bike runs fantastic
Old June 12th, 2012, 10:20 AM   #13
cuong-nutz
cuong-nutz's Avatar
Too lazy to re read but did the slack cause your motor to fail?
Old June 12th, 2012, 10:35 AM   #14
no. the chain isnt stretched. the noise seems to be from the chain guide itself tapping the cct. not sure why it makes noise but the chain is within spec.
Old June 12th, 2012, 11:24 AM   #15
greg737
Motorcycle(s): -
On the old gen side there have been guys who've measured their worn cam chain at various points and they discovered that cam chains almost never stretch (wear) uniformly.
Instead the worn chain will actually be within wear tolerance measurement spec over some lengths of it and way beyond wear tolorance when measured at other points along the chain. This uneven wear sets up a "tight-loose-tight-loose" situation as the cam chain runs around across the cam gears and the engine gear. That's why it starts to make that knocking sound, and that's why it sometimes beats the cam chain tensioner to pieces.
The cam chain tensioner is designed to absorb the relatively slow changes in cam chain tension (a "lash" effect) that are caused by normal engine accelerations and decelerations. The cam chain tensioner is not capable of dealing with the extremely rapid "tight-loose-tight-loose" high-frequency lash that an unevenly worn cam chain deals out.
Old June 12th, 2012, 03:29 PM   #16
thats a good point greg. i measured it at a few points but really to be sure it should be removed. looking at the pins, they did look uniform and i couldn't see any stretching. but without measuring the entire thing it very well could be partly stretched.
Old June 12th, 2012, 03:33 PM   #17
its not an old engine and hasn't suffered any oil starvation so the only reason the cam chain would have stretched i think is if something got in there, or somehow the cam shaft locked for a second or something. i could see pregen cam chains stretching unevenly after sitting in the same spot for years with 50k miles on them already then start up and ran before changing all the fluids. but on a fairly new engine seems iffy
Old June 12th, 2012, 05:30 PM   #18
Racer x
Racer x's Avatar
I will check the one I have over many spots and see what I get.
Old June 28th, 2012, 01:57 AM   #19
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
Bringing this thread back to life. What exactly does this sound like? I ask because I've noticed a slapping sound in my engine for a while now too that just doesn't sound right. It kind of slaps for a few revolutions then stops for a few revolutions and the pattern repeats.
I have not inspected anything yet as I've been reading through these threads to try and get an idea of what's going on. I have an 08 with just over 16k miles. Seems pretty low to me judging from these other high mileages I've read about regarding this issue.
ATGATT
Scattcatt is offline   Reply With Quote
Old June 28th, 2012, 02:49 PM   #20
Have you replaced the drive chain yet? Probably about time.
Old June 28th, 2012, 04:40 PM   #21
Scattcatt
Scattcatt's Avatar
The drive chain as in the chain that goes to the rear wheel? Yes, this is the bike's 3rd one at minimum (bought it used with an aftermarket chain already on it, then I later replaced that one)
ATGATT
Old June 28th, 2012, 05:10 PM   #22
Will this work well on our bike?
Yep. Just wanted to rule that out.
Old June 28th, 2012, 06:52 PM   #23
i'm just gonna go ahead and say no, it's a bad idea to cut and reweld your cam chain. will it work? if you do it perfectly. can you **** everything up in the blink of an eye? yep.
now, if you had a proper cam chain press like i do... thats another story
Changing cam chain scorch 2008 - 2012 Ninja 250R Tech Talk 17 April 28th, 2014 08:46 AM
Cam chain rattle noise silentIm 2008 - 2012 Ninja 250R Tech Talk 18 March 23rd, 2014 01:54 PM
cam chain tensioner kittyslasher 2008 - 2012 Ninja 250R Tech Talk 2 June 16th, 2013 09:17 AM
Do cam chain tensioners ever need to be replaced? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 6 July 17th, 2012 05:17 PM
New Cam Chain Tensioner before valves? headshrink 2008 - 2012 Ninja 250R Tech Talk 21 March 24th, 2010 10:30 PM
