Old February 6th, 2016, 09:23 AM   #41
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
If you want to use a new radiator in an old frame. Use the new gen motor mounts
Worlds fastest 250 ninja
Old February 6th, 2016, 11:51 AM   #42
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Originally Posted by UFOmoplata View Post
Originally Posted by InvisiBill View Post
Get new fork springs. The stockers are worthless for anyone big enough to reach the controls. Depending on your weight, the NewGen springs from your pile of parts might work well. https://www.ninjette.org/forums/showthread.php?t=231171
I weigh about 160lbs so .7 Sonic springs will be ordered eventually.
Assuming they're still stock, those NewGen forks in your pile have .65 springs in them. RaceTech's calc says .66 for street, so .65 should at least be pretty close, for free. You could even trim them a bit to make them stiffer. It's up to you if the slightly stiffer aftermarket springs are worth the cost.
Old February 6th, 2016, 11:52 AM   #43
InvisiBill
InvisiBill's Avatar
Originally Posted by RacinNinja View Post
Ok, let's do some Maths! As my favorite YouTuber would say....
100/80-16 front. 16 inches is 406 mm. 80% of 100 mm is 80 mm, that gives us an overall diameter of 486 mm.
110/70-17 front. 17 inches is 432 mm. 70% of 110mm is 77mm, giving us an overall diamter of 509 mm.
That's a difference of 23mm! This would definitely affect your handling, simply swapping front to front and not changing tire size.
I can't recommend a front wheel swap without swapping the rear too. Sure, you could get a 100/70-17 for the front but that's only good for 7 mm, leaving a 16 mm difference.
IMO, you would need to increase rear ride height 16mm to offset the difference. I don't like dropping the forks in the clamps, especially with undersprung bikes because the tire could hit the fairing.
Up to you! If my math is off, feel free to correct me.
Rear tires....
130/80-16. 16 inches is 406mm. 80% of 130 is 104mm, giving the rear overall 510mm. Increasing the size to a 150/60-16...406mm plus 90mm (smaller height!) is only 496mm.
You would need a 150/80-16 and I'm not sure that would fit properly or at all.
There's a sidewall at both the top and bottom.
100/80-16 = 566mm
110/70-17 = 586mm
100/70-17 = 572mm
130/80-16 = 614mm
150/60-16 = 586mm
150/80-16 = 646mm
140/70-16 = 602mm
http://www.invisibill.net/ninja/tirecalc/ will save you some time calculating (though it's still good to know how those figures are derived).
Old February 6th, 2016, 12:08 PM   #44
UFOmoplata
UFOmoplata's Avatar
Motorcycle(s): 2007 Hoodrat 250
I got it figured. Got pics. I'll post later the how-to.
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes."
UFOmoplata is offline   Reply With Quote
Old February 6th, 2016, 12:11 PM   #45
UFOmoplata
UFOmoplata's Avatar
No it is not worth it to me. I looked at your link and saw new gen springs are perfect so I'll use those. Combining with 15wt.
Thanks for your help.
Old February 6th, 2016, 01:04 PM   #46
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
100/80-16 = 566mm
110/70-17 = 586mm
100/70-17 = 572mm
130/80-16 = 614mm
150/60-16 = 586mm
150/80-16 = 646mm
140/70-16 = 602mm
HAHA! Oops....figured I made a mistake somewhere. Thanks!
Goin' fast on slow bikes!
Old February 6th, 2016, 02:00 PM   #47
UFOmoplata
UFOmoplata's Avatar
Update is on my blog. I'll post here later when my laptop is fixed.
Old February 7th, 2016, 08:24 PM   #48
UFOmoplata
UFOmoplata's Avatar
Guys, if you run a newgen engine in pregen frame, you more likely will need to replace the newgen water inlet pipe with the pregen pipe.
I found it easier to use the pregen radiator due to clearance issues with the gas tank and aero.
Since the motor mounts and radiator don't match, bolt it on the left motor mount to snug up the hose clearances with the gas tank. You will need to create a radiator bracket. Plastic will work.
If you plan on running front aero, you'll need to trim it some.
IMGUR pics are showing up HUGE. If you want to see pics, they're on the blog.
Last futzed with by UFOmoplata; February 8th, 2016 at 07:29 AM. Reason: Pics not cooperating
Old March 23rd, 2016, 06:14 AM   #49
UFOmoplata
UFOmoplata's Avatar
Nothing much going on here.
Major Needs:
-new few tap
-new plugs
-carbs rejet/cleaned
-front brake caliper bracket finished
-5.1 brake juice
-lights wired
Minor needs:
-fender chop
-fairing bolts
-mirrors
-tank pads
-more stickers
-Danmoto slip-on?
Old March 29th, 2016, 05:46 AM   #50
UFOmoplata
UFOmoplata's Avatar
Hooked up tail lights. Brake light works fine. Turnsignal is acting funny. When turned on, one side flashes while the other is blank.
Side note: front signals are not wired. Would that cause this? Battery is charged plenty.
https://youtu.be/BLJRsiFCSyg
Old March 29th, 2016, 06:11 AM   #51
HoneyBadgerRy
HoneyBadgerRy's Avatar
When you upload IMGUR images click the resize button (square with a arrow underneath is and to the right of it) then click the image button, then paste the image address.
Old March 29th, 2016, 06:50 AM   #52
allanoue
allanoue's Avatar
MOTM - Sep '14
[YOUTUBE ]BLJRsiFCSyg[ /YOUTUBE]
Old March 29th, 2016, 12:06 PM   #53
spent_too_much
spent_too_much's Avatar
I have aftermarket turn signals on my 250. The connectors sometimes come loose, and I get that rapid flashing. You state that the fronts are not hooked up, so my guess is just that. Hook all 4 up, and then test - or at least both front and rear on the same side. That should cure your issue.
Old March 29th, 2016, 01:17 PM   #54
UFOmoplata
UFOmoplata's Avatar
And if that doesn't work, looks like I'm going to autozone.
http://faq.ninja250.org/wiki/My_LED_...9;t_work_right
Old March 29th, 2016, 01:24 PM   #55
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
If ballast resistors didn't come with your LED's, save yourself the headache and just go get an electronic flasher. The standard flasher will always be fast, no matter how many LED's you hook up.
Old March 29th, 2016, 03:58 PM   #56
UFOmoplata
UFOmoplata's Avatar
https://imgur.com/a/vKlit
It's black. New plugs too then.
Old April 1st, 2016, 12:34 AM   #57
SRH
Motorcycle(s): Kawasaki, Hondax3, Suzuki, Ducati
Led bulbs will cause problems in the turn signal circuit. The problem is the way they are wired from the factory. As is, each side uses the other as a ground, or rather a terminator for any leftover voltage. LED bulbs use so much less current, there is too much voltage left over and causes both sides to light up at the same time. One way to correct this is the "Diode Mod", the way I chose to correct it. Here's a link to my diode mod pics and instructions on Photobucket:http://s1081.photobucket.com/user/Ee...?sort=3&page=1
Also, to keep from having to use load resistors with my complete LED changeover, I used plug-n-play bulbs from Super Bright LEDs.
LED headlight bulb I used on my Ninja: http://www.cyclegear.com/SPEEDMETAL-LED-Conversion-Kit
SRH is offline   Reply With Quote
Old April 1st, 2016, 05:41 AM   #58
UFOmoplata
UFOmoplata's Avatar
Done these things:
-cleaned carbs
-new plugs
-new fuel tap
-fresh charged battery
With a little coaxing from starting fluid, I was able to start the bike. It ran for all of five seconds before it shut off.
http://faq.ninja250.org/wiki/My_bike...get_it_started
According to the above link, I'm not exactly in a bad spot. If anyone has any other tricks they would like to share with me, I'd greatly appreciate it.
Old April 1st, 2016, 05:44 AM   #59
HoneyBadgerRy
Done these things:
-cleaned carbs
-new plugs
-new fuel tap
Adjust idle speed and try again.
Old April 1st, 2016, 06:00 AM   #60
UFOmoplata
UFOmoplata's Avatar
Thank you sir. I'll put this info to use.
Old April 1st, 2016, 06:02 AM   #61
UFOmoplata
UFOmoplata's Avatar
You mean the screws in the carbs? I believe I set them at 2.5 turns out which I now realize is stock setting.
D'oh!
Old April 1st, 2016, 06:06 AM   #62
HoneyBadgerRy
You mean the screws in the carbs? I believe I set them at 2.5 turns out.
The screws on the bottom of the carbs are the idle mixture screws (they control how much gas the bike get at idle), there is a know on the bottom left side of the carbs that controls the butterflies and keeps them open. It is possible that you have the butterflies to far closed for the bike to run.
I like to run the screw until it touches the throttle and turn it in two turns until i get the bike running, and adjust either direction. (don't be afraid to try 3 turns just to experiment)
Old April 1st, 2016, 06:13 AM   #63
UFOmoplata
UFOmoplata's Avatar
Yeah, there's a long, black cable with a knob at the end of it that I didn't know what for. Is that what you're talking about?
Old April 1st, 2016, 06:14 AM   #64
HoneyBadgerRy
Yes, one end is for you to adjust, the other pushed on the throttle and moves the butterflies.
Old April 1st, 2016, 10:50 AM   #65
UFOmoplata
UFOmoplata's Avatar
Okay, fiddled with the idle screw. Made sure the fluids were topped off. I was able to get it running somewhat with idle jumping from high to low and everywhere in between.
I thought I was onto something until oil started puking out of the breather filter...massively. Back to square one...
I'll have a video shortly. I may have put too much oil in.
Old April 1st, 2016, 10:53 AM   #66
HoneyBadgerRy
That's a possibility. When was the last time you checked the valves?
Old April 1st, 2016, 11:10 AM   #67
UFOmoplata
UFOmoplata's Avatar
Never checked valves yet. I really do think I put way too much oil in.
Found a new leak. This time coming from the water pump.
Old April 1st, 2016, 11:10 AM   #68
Bigballsofpaint
1.8 quarts of oil, don't put the whole 2 quarts....
Current - 2015 30th Anniversary Ninja 636 ABS - 1969 Honda 305 Scrambler
Previously - 2011 Ninja 1000, 2008 Ducati 848, 2011 Ninja 250 SE
Old April 1st, 2016, 12:06 PM   #69
HoneyBadgerRy
When you drain all the oil out (like in a rebuild) it takes every drop of two quarts.
Old April 1st, 2016, 07:18 PM   #70
UFOmoplata
UFOmoplata's Avatar
Just want to get this thing idling at the very least. I'll worry about jetting later.
Besides the idle knob, is there anything else I should mess with?
Old April 1st, 2016, 07:25 PM   #71
HoneyBadgerRy
Idle is all in the idle speed knob that adjust the butterflies, and the mixture screws that control the amount of fuel.
Old July 15th, 2016, 09:25 PM   #72
UFOmoplata
UFOmoplata's Avatar
Main 108
Pilot 38
2.75 turns
2 washers
Seafoam is running through it.
Still need to play with idle some. May need to adjust the valves next. Is this what a ninja should sound like?
Old July 16th, 2016, 09:22 PM   #73
SRH
Main 108
Pilot 38
2.75 turns
2 washers
Old July 16th, 2016, 09:36 PM   #74
SRH
Carbs and valves
Once you get away from the factory "tuned air box" it becomes quite time consuming to get the carbs dialed in. Before any carb adj/mods, though, valves should be checked for correct clearance, as clearance will affect intake air volume and consequently, A/F ratio. Once valve clearance is determined to be correct, full steam ahead on the carbs. Here are a couple of links you may find helpful.
J model valve adjustment
Carb tuning
You'll find a factory service manual essential and indispensable.
Last futzed with by SRH; July 16th, 2016 at 09:39 PM. Reason: missing info
Old July 17th, 2016, 07:00 AM   #75
UFOmoplata
UFOmoplata's Avatar
Starts up easy now.
Was having idle issues standing at 4000, so I messed with carbs again.
Took out a washer and opened the mixture screw to 3 turns. Idle now stands at 6-7000.
from what I read online, it sounds like a vacuum leak. Intake boots aren't cracked so I'm leaning towards one of the smaller lines not having a clamp on as the culprit. In the meantime, I'm going to set the carbs back to the setting I had it at.
Old July 17th, 2016, 07:02 AM   #76
UFOmoplata
UFOmoplata's Avatar
Carb tuning
Thanks for the info. I need some clearance gauges first. Wonder if harbor freight has them?
Old July 17th, 2016, 09:26 AM   #77
SRH
Am I correct that you have a F model bike with a J engine? Unless you're already familiar, I highly recommend that you read the information you'll find via the J model valve adjustment link in my last post.
If you're not familiar, you'll also need a micrometer and a source for shims just in case you need to replace any.
I've never been a fan of shim-under-bucket designs, or over bucket for that matter but I understand the concept and why manufacturers utilize them. I also can relate to one's reluctance to endeavor that task, but if one wants a top running machine, as well as the satisfaction of knowing that machine, procedure must be followed.Although I'm an F model owner, I read the valve adj write-up in that link. Wow. I thought mine was difficult. Good luck with yours, I'm interested to see your bike run with all the mods.
Old July 18th, 2016, 08:05 AM   #78
UFOmoplata
UFOmoplata's Avatar
The service dept quoted me ~150 for valve adjustments. I can pay for that. As far as the high idle, they're saying it's somewhere in the carbs. I have a hunch where. It might have something to do with the Kleen air lines.
Old July 25th, 2016, 05:51 AM   #79
UFOmoplata
UFOmoplata's Avatar
While the carb is @ducatiman, did a few aesthetics things. Proper fairing bolts from Bikebolts.com. Removed the black plastidip. I'm starting to like the all silver look. Want to get a black front wheel to match. Powdercoating is too much trouble.
Removed the brace out of the fender to cut out a smaller, lighter fender. Inspired by:
80s version
What's left:
-water pump
-coolant flush
-tires
-brakes bled
-mirrors
-lights wired
-electronics tray
Old August 13th, 2016, 12:17 PM   #80
UFOmoplata
UFOmoplata's Avatar
About done.
Just minor things now:
-Flushmounts from MadHornet is taking forever. It's been three weeks now. Lighting it up would be cake. Need some sort of relay system for the LED taillights, though.
-Some sort of exhaust. I want that cafe sound. I'm thinking that Shorty GP would work:https://www.amazon.com/Radiant-Cycle...oddies+exhaust
-As of now, it's just header.
-Exhaust wrap - Pregen lower fairing and header don't clear. Need to cut it some, or at least sand out clearances.
-If it's too loud, I'll get a Danmoto of some sort.
-Plate mount: Plate
Nothing Major:
-Brake lever: Maybe tighten it up just a bit more.
-Go get it reg'd and plated.
-Bar end mirrors: Need to get those plastic inserts out somehow. The mirror are the type to go inside the handle bars instead of clipping on to the bars.
-New tires: Stock tires are rock hard. Maybe some time in the sun will soften them up?
What I DID do:
-@ducatiman carb service. He said I had the wrong emulsion tubes and that could have contributed to my idle issues. Fixed that and just need to run new gas through it.
-Cut out a fender: Smaller and lighter.
-Brakes bled.
-Wire tucking.
-Fork springs: newgen springs installed/15wt oil.
You could kind of see the fender in this one. I only ever take these profile shots for kind of a visual goal.
Last futzed with by UFOmoplata; August 13th, 2016 at 09:25 PM.
stock ex250 wiring harness ghetto rigged? cream 1986 - 2007 Ninja 250R Tech Talk 7 March 24th, 2015 11:25 PM
CERTIFIED!! 7oxSin Riding Skills 11 November 12th, 2013 11:30 AM
Ghetto girl joins the gang! goobsmiracle New Members 25 February 10th, 2013 05:22 PM
Ideas on my cheapo ghetto tank bag? papawhellie Motorcycle Gear 4 November 4th, 2012 09:24 AM
Ghetto Digital Dashboard / GPS Project patw General Motorcycling Discussion 23 June 14th, 2010 02:26 PM
