#1 |
Join Date: Apr 2010 Motorcycle(s): kawasaki Ninja 250 Posts: 12
highway riding, top end giving out?
hi all
i have a friend that keeps telling me that my 250's top end will give out with extended highway uses...i.e. speeds 60-80mph (for me at least) anyone have any problems with their 250's? or is it only a known issue in the older 250's. i have an 08 btw just curious as i plan to use my bike as a commuter and the majority of the riding will be highway i'd love to hear input from you guys about this Thanks! |
#2 |
Ride it and enjoy it. The 250R is a very reliable bike and thrives on high revs. The top end is about 100mph.
#3 |
Green!
Join Date: Nov 2008 Motorcycle(s): 08 Ninja 250R, 04 Honda CRF230F, 94 Honda XR80R Posts: 505
The 250 does fine on the highway and handles speeds in the 70s and 80s just fine...it'll even get close to 100, though pushing is just isn't worth the ticket.
I've read plenty of stories about people riding 10+ hours at highway speeds and other using it to go cross country at mainly highways speeds. And most of those are the old gen 250s. The 08+ should only do better since kawi has reworked the engine to be even more reliable, especially in there upper RPMs. Your friend doesn't know what he's talking about and has obviously never owned a 250. Other bikes will handle the higher speeds better, BUT the 250 does just fine, and as long as you take care of the bike, there's no reason the engine would give out. ![]()
2008 Green 250R |
#4 | |
Join Date: Jun 2009 Motorcycle(s): Ninja 250 x2, Ninja 650R Posts: 165
My '05 Ninja 250 finished the 2009 Iron Butt Rally. I also ridden this 250 on a 24hr / 1,529 mile BBG ride, in which I was on the 80mph I-10 in TX. I cruised that section at 85mph for 400 miles. |
#5 |
Join Date: Jan 2009 Motorcycle(s): 2008 250R (Black) Posts: 298
Hi. I have an 08 myself and i have clocked a lot of hours at around 70-80, no problem at all. You can go 90-100 for hours. I got 8000 miles on it, and its still running as if it was new. These engines have been around for over 30 years, and they love rpm. If you don't use the whole rpm-range regulary, the bike will be sad.
#6 |
Join Date: Jul 2010 Motorcycle(s): Black '11 ZX-6R Posts: 209
#7 |
Join Date: Apr 2010 Motorcycle(s): 2009 Honda CBR600RR Posts: 633
I hate doing that to a bike, I don't care if there are facts based either way. Simply put if you don't maintain the bike and you continually hard rev the engine to redline for prolonged periods of time, there is no way you can tell me that is not hard on the engine. I personally do not ride long periods of time on the highway because I will eventually move to a bigger bike (already considered it) and I do not wish to have what I would call *hard miles* on my bike. I also hate the lack of power and uneasy feeling when trying to pass people on the highway, people here see a sport bike go to pass them and they always seem to feel the need to push on their gas.
I keep to back roads and in town as much as possible. It's what this bike is made for imho.
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja |
#8 |
I usualy ride 100+ miles at a time at highway speeds with no problems. Just be sure to check and change your oil regularly.
#9 |
glad to hear that!, he was referring to something on the motor, having the top end going out on the motor rather than "top end speed"
i'd like to keep to backroads also, but with my commute to work there's no avoiding the highway shrugs i have no idea but i'll just continue to enjoy my bike ![]() |
#10 |
MOTM - Mar '13, Jun '14
I've read a lot of posts on here and most of them are about their lower end giving out on the highway. Their is usually the suggestion of a corbin seat, bicycle shorts, or monkey butt suppositories.
#11 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
I've ridden at 75mph for 3 hours one day and the bike way perfectly fine. Your body will give up long before the bike will. The bike is designed to be just fine in the higher revs just like a mazda rx-8 loves to go to its redline daily.
![]() 09 ninja 2fiddy SE ![]() |
#12 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Rev it up and keep up on your maintanence. You should have no problems. I put 10,000 at 70MPH + on my bike last year with no problems.
Addicted to anything that has an engine and rolls. ![]() |
#13 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
With regular oil changes, the 250's entire design is rock solid. I have over 30K on my 2008, and valves, journals, cams, and the rest all well within spec. I put 4,300 miles on her in 2 weeks about a month ago, 1,300 of which was in 2 days, all at above free-way speed limits. So, no worries dude, make her scream! I can't speak to an ill-maintained bike however, because I maintain my bikes very well... I change oil every 2,000K miles, and I use Kawi-dyno juice (Not trumpeting it for others to use, I simply like to see what's going inside my engine, and oil is good for that, and it gets expensive changing the oil with synthetic and the like every 2K...)
![]() My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
Highway Riding Questions | Proteus | Riding Skills | 12 | August 18th, 2014 05:03 AM |
Highway riding? | lstat | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 20th, 2012 05:10 AM |
Highway riding Noob | erittz | Riding Skills | 9 | April 9th, 2012 07:21 PM |
Highway Riding | Snake | Riding Skills | 48 | November 30th, 2010 11:15 PM |
