#1 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
Ok so this is what I ended up getting today.
It isn't the Trek, but the Specialized Langster. It felt super comfortable, so I said why not.
![]() Here are some pictures. I still need to set it up. It is definitely weird riding without a freewheel. It is ok, I have a flip-flop hub so I can convert it to a freewheel at any time. Let the pics begin...(sorry about the quality, used my iPhone) ![]() ![]() ![]() I like it so far. VERY light. I almost got the trek version of this bike. The straight bars felt weird. On a side note, I can convert the bars at any time (joy of no shifters!). Right now, this feels pretty good. I must say, I like how it looks too. Polished aluminum frame with a clear coat. I'm debating on keeping the stickers on there or not. I guess I will for now. ![]() I'm going to run outside and set it up. I need to adjust my seat height, bar position, etc...
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
#2 |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
Hrmm...that's not black....that's not black at all!!
![]() Looks great, though! |
#4 |
Join Date: Aug 2009 Motorcycle(s): '09 Ninja EX250J Posts: 177
now all you have to do is learn how to trackstand and skip stop...have fun! btw, what gear ratio did you end up with?
#5 |
It came with a 42/16.
I definitely do need to learn a trackstand. It would help a lot. I tried it a few times. Was doing rather well until I picked up 30lbs of cat food/litter and cycled home. Yeah, the trackstand wouldn't happen. lol
#6 |
Here are the specs...
FRAME Specialized A1 Premium Aluminum, fully manipulated tubing, compact design, integrated headset REAR SHOCK N/A FORK Specialized FACT carbon, carbon fiber legs, aluminum crown and steerer HEADSET Specialized Mindset, 1-1/8" integrated threadless, steel cage bearings, 20mm alloy cone w/ 10mm alloy spacer STEM Specialized Sport, 3D forged alloy, 6 degree rise, 31.8mm clamp HANDLEBARS Specialized Comp, 6061 alloy, short drop, ergonomic shaping, 31.8mm TAPE Body Geometry cork ribbon FRONT BRAKE Ultralight dual pivot brakes, Teflon pivots, forged alloy w/ cartridge pads REAR BRAKE Ultralight dual pivot brakes, Teflon pivots, forged alloy w/ cartridge pads BRAKE LEVERS Tektro short reach for drop bars FRONT DERAILLEUR N/A REAR DERAILLEUR N/A SHIFT LEVERS N/A CASSETTE Shimano Freewheel, 16t CHAIN KMC Z-510HX 1 Speed CRANKSET Sugino Zen Messenger CHAINRINGS 42t BOTTOM BRACKET Sealed cartridge, square taper, 68mm x 103mm PEDALS Silver cage, black body, w/ toe clip and strap RIMS Alex Race 32, sleeve joint, CNC sidewall 32h FRONT HUB Track, bolt-on w/ track axle nuts, 32h REAR HUB Track bolt-on w/ track axle nuts, 32h SPOKES Stainless 14g FRONT TIRE Specialized Mondo Sport, 700x23c, wire bead, 60TPI, Flak Jacket REAR TIRE Specialized Mondo Sport, 700x23c, wire bead, 60TPI, Flak Jacket INNER TUBES Specialized standard presta tube SADDLE Body Geometry Toupé, super light foam, carbon reinforced base, Cr-Mo rails SEATPOST Specialized carbon wrapped, two-bolt clamp, 27.2mm SEAT BINDER Specialized alloy 31.8mm NOTES Chain stay protector, clear coat, owners manual
#7 | |
![]() I would have liked a matte black bike, but this just seemed so much more solid of a ride. I'm quite happy with it. ![]() It was making a clicking sound after riding around. Found out it was a loose pedal. Put some torque on it and the sound went away. I love the whole single speed thing.
#8 |
Fastly Slow!!!
Join Date: Feb 2010 Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125 Posts: 467
Very Nice!!! Weird seeing a single speed hardtail being built with that frame type these days! Simplicity is the BEST though! Congrats Mark. Don't get pulled over for Wheelies now.
#9 |
Join Date: Dec 2009 Motorcycle(s): 2009 Ninja 250r SE green with Monster energy decals!!! Posts: 223
two thumbs up!!! Very cool!!!
#10 |
MOTM - Mar '13, Jun '14
I'm not sure if you realise, there is no motor!
#11 | |
![]() I plan on learning quite a bit on this bike. ![]()
#12 |
hang on a minute!! Where did it go??????
Dang goblins have been stealing my motors again!!!!!
#13 |
Nice ride, Mark. Would love to get a single speed, but the terrain here is so hilly that I would have to be built like some power lifter to even get the thing to move. Around here, all you see are Triples and Compacts. I have a classic Univega in my stable with a double and I am exhausted after riding the bike for 20 mi.My Merckx has a triple and I can go 100 mi a day easy and still have energy to have a couple of beers and schmooze with friends after the ride. I guess what you ride depends on where you live.
#14 |
Why not get a fixed crank (like a 38T or something) and Shimano Nexus hub? That way you have the simplicity of a single speed, but you have 8 gears to choose from?
Just a suggestion. ![]()
#15 |
Green!
Join Date: Nov 2008 Motorcycle(s): 08 Ninja 250R, 04 Honda CRF230F, 94 Honda XR80R Posts: 505
It's beautiful that's for sure.
![]() Since I know nothing about bikes, what is the advantage of this being a single speed?
2008 Green 250R |
#16 |
Well the main advantage is low maintenance. I got this to goof around on and commute with. I don't have the ability to change gears to minimize effort. I must grind out whatever I have to deal with, a hill or head wind, in one gear. Not to mention not having the full cassette or triple up front, along with the lack of shifters and derailleurs reduces weight.
Single speeds are reliable and extremely low maintenance. All you need to do on a bike like this is:
A bike like my Trek and Cannondale requires cleaning the cassettes (which takes time), adjusting cables, adjusting the front and rear derailleurs (which if they get damaged can get expensive), verifying chain alignment, etc. It just takes longer to clean, longer to keep in working order.
#17 |
Green!
Thanks for the info
![]() All my bikes are single speed, but that's purely because more of the shifter cables have rusted closed ![]() Congratz on the new bike!
2008 Green 250R |
#18 |
Upgrade. You will be floored if you have never been on anything over $500. It is like night and day...especially the shifter quality and the weight.
#19 |
Oh and I just kicked my own butt by riding the fixie 35 miles today. WOW. I have never had my legs burn like that before. lol
That was one nasty headwind I had for over 1/2 my ride.
#20 |
now hop on your trek...it'll feel sloppy with a freewheel, like you have no control. but guess what? your cadence will be more consistent and you'll blast past everyone on the hills...wait your in texas, the winds are probably worse than the hills out here!
#21 |
Well we get some good hills when we get to the "hill country". Some nasty ones too. That is true, the winds can be terrible. I'll keep training on the Langster (in FG mode), so when the MS150 comes up next month, I'll be like "wow, this is nothing".
![]() I know what you mean about it being "sloppy". I was floored how tight the drivetrain felt on the FG. You really do feel like you are connected. My foot slipped off a pedal while I was in full sprint and I was laughing because I couldn't get it back on. hahaha Maybe I'll post up a video of the bike path I like to cruise on so people can get an idea of what a path around me looks like (very hilly, but short hills. So short they yell at you "sprint up me!" Next thing you know your legs are jello. lol
Rear Ended a Tahoe | Malicious Logic | !%@*#$%!)@#&!%@ I crashed! | 24 | December 9th, 2012 07:28 AM |
Rear-ended on motorcycle | Motofool | Videos | 36 | October 29th, 2012 11:54 AM |
ended being a spendy slide..... | racegunnr | !%@*#$%!)@#&!%@ I crashed! | 7 | August 14th, 2012 04:48 AM |
First time it ended like this. | Skippii | General Motorcycling Discussion | 10 | March 22nd, 2012 07:55 AM |
totally got rear ended today.... | realmess | !%@*#$%!)@#&!%@ I crashed! | 17 | February 4th, 2012 10:24 AM |
