Old February 21st, 2009, 02:29 PM   #1
Gregular
Not on the rug... man
Gregular's Avatar
Motorcycle(s): 2009 Diablo Black Ninja 250r, 2009 Triumph Daytona 675 Special Edition
Testing update - Rear view camera
Just having a break and thought I'd upload some photos of the rear view cam in action.
Everything is very much loosely installed at the mo and I don't have my tail tidy yet so it's making it kinda hard to decide where the camera goes - maybe drill a hole just above the number plate (but then the white led number plate light might interfere) or mount just below the middle led strip that I installed, but that might not be high enough. Hard to say yet, I get the feeling that if mounted at the bottom of the number plate it would wobble too much.
Will have to wait on that I guess, but good news is the screen fits nicely between the cluster and a double bubble screen
and the camera has night vision, it has a ring of infra red leds that look well cool at night
Still needs some adjustment though and there may be a fault on the camera as there's some haze on the left that's deffo from the camera as you can rotate the view on the screen and the haze moves with the rotation
Last 2 pics are without the lash as that interfered with the night shots.
Ohlins Shock,Sato Rearset,Woodcraft Clipons,Pazzo Levers.Skidmarx-Hugger/DB Screen,RG Racing-Crash Protector/Tail Tidy,Camera,HIDs,LEDs
Full Yoshi,Dynojet PC3,Urbane Intake,Bergman Spin On Oil Filter
Gregular is offline   Reply With Quote
Old February 21st, 2009, 02:41 PM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
That is amazing Greg - going for the James Bond 007 bike are we?
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old February 21st, 2009, 02:46 PM   #3
Gregular
Gregular's Avatar
maybe lol, that 6 month wait for my bike burnt a serious hole in my pocket
The rear view camera part is just a scam to get lower insurance, the screen has a wired composite input that I'm gonna be using for on route entertainment
I'm just jokin, though the features that the screen has like extra inputs/rotation/4 wireless channels and more are pretty cool
Old February 22nd, 2009, 02:37 AM   #4
Trozza
Motorcycle(s): Ninja 250r
Geezzz, that looks good. I'm doing it for sure!! My shoulders suck and as a result I can't see much in the rear view mirrors.
Where did you get the screen from and is it waterproof/water resistant?
Trozza is offline   Reply With Quote
Old February 22nd, 2009, 05:21 AM   #5
Gregular
Gregular's Avatar
Well I'd hang 10 for now.
All is not as peachy as it seems and I need to iron out a few crinkles
The camera supplied has some haze on the left part of the image, this remains day or night vision and is bad enough for me that I will be seeking a replacement or refund for the whole lot. I'm hoping that this is just a defect of the camera that came supplied.
The flexible bracket supplied has a very poor mount for the screen and screams 'Temporary install. Please steal me' ..... But not to worry on this score, you can't use that to mount the screen where I want to - above the cluster. I'm gonna fab up a bracket that makes it fit snugly in there and makes it a permanent install and look like a permanent install.
It's not waterproof, there are vent holes at the bottom (nothing to worry about unless submerging), the buttons aren't sealed (but the positions of buttons are memorised so if I turn my bike off with screen on, when I start the bike later on, the screen comes on. So once its setup I won't need to press buttons that much and I'm going to cover these buttons in some clear silicon which should be flexible enough to allow continued use and be waterproof). Plus the positioning under the double bubble should mean it doesn't get that wet anyways.
But it's not all bad. The screen image is very good and its easy to pick out small objects on it with a cursory glance. Traffic should be real easy to quickly spot. Will have to wait to see what its like for real on the road though.
The screen also has plenty of adjustments for brightness/contrast/rotation has a wired video input socket
The screen can support up to 4 wireless cameras which I think is really cool. For example if I lived in a slightly rougher part of town and had to park in an alley that had recently been used for muggings/assault/theft, I could have a 2nd wireless cam installed at the end of my alley and switch to that camera as I was pulling up to make sure it was safe and clear. This is just speculation for now, I have not tested what the range of the camera is yet. But there is potential for a garage cam/alley cam/see if the folks are in cam lol
But I'm just waiting now, any more work requires modding it and I can't do that if I have to return it. Until I get to talk to the supplier tomorrow, I can't do any more
Old February 22nd, 2009, 09:26 PM   #6
Sailariel
Sailariel's Avatar
Greg, That looks like it has the potential for a real breakthrough in sport bikes. Rear view mirrors just don`t make it. I got some mirrors for the ZX10R and they are a small improvement. I still have to rely on blind spot mirrors. Your setup looks like the answer.
Old February 22nd, 2009, 10:42 PM   #7
Trozza
Yeah, I just cut out a mock piece of paper for a 3.5" screen, and I can't figure out where to put it with a OEM screen in place. Might have to get a double bubble as well.. But I'll hold off until you get yours sorted.. Iron out the kinks so to speak.
Old February 23rd, 2009, 01:47 PM   #8
Gregular
Gregular's Avatar
Sounds like a damn fine excuse to invest in a double bubble
Ok, so progress has been made
I managed to contact the supplier once. I'm not overly impressed with their service really - no phone number to contact them on and they churn out 1 email reply a day it seems and the reply kinda made the assumption that there was nothing wrong with the camera even though he'd looked at pictures I emailed him.
Maybe my impatience is starting to grow, I'm fed up waiting now and when things don't work right I want to be able to talk to someone and get the ball moving.
So anyhow..... down to the problem - the haze or whiting out on one side turns out to be a reflection of the LEDs off the lens cover.
Take the waterproof lens cover off and hey presto! We got a mighty fine picture. And the reason it's on one side is cause the camera is not perfectly in the middle of the housing.
Whilst I waited hours for the guy to reply to me I tried to fix it.
Toyed at first with just leaving the cover off and putting some silicon on the circuit board and to cover the holes - this is still an option really but doesn't look so clean (plus I wasn't sure at the time if I was gonna be returning it so couldn't experiment too much)
Desoldered the wiring to the circuit board. No more LEDs - no more night vision but no more glare and the camera can remain in the housing. This is still an option too as the nightvision in use on the roads could be pants and pointless. Dunno yet.
Looked at creating a better seal between the lens cover and spent hours adjusting the circuit board position and trying to use various packing materials to push the foam (the little ring of foam is what's used as standard to stop the glare) up against the lens cover better. To cut a long story short, rubber washers are great
So here's a pic of the camera partly assembled. I've removed all the stock packing material
Here's a pic of the washers I used, sorry dont know the sizes (but they are very snug fits around that central pillar), I just raided one of my 'useful parts bins' and came up with them
So with my tail tidy in place (arrived today ) I marked up with a ruler where my license plate would finish and then started to place the camera with masking tape and experiment.
I'm trying to keep the camera in the middle (not off to one side) and the best 2 positions I've come up with so far are
at the back but I do end up with a tiny bit of license plate at the top and a tiny bit of hugger at the bottom.
On top of the hugger, but it looks a little bit exposed there - like when it's parked up, I'm just thinking of vandalism or theft really. And there's still the power cable to run and it's not so easy to hide from there.
Any thoughts/suggestions on placement would be gladly received
And here's another shot of the console end (the monitor is showing a good image, just when I take a shot, it looks crap)
So here is the site I got the package from. The product does work and does require some tinkering - mount brackets are flimsy and no good for mounting above cluster, camera has glare problems that can be fixed, screen is not waterproof (but can be made so)
the image is good, but in use on the road I cannot say yet
I do not know if the nightvision is any good either yet
and customer service is not the best in terms of contactability
http://www.4kam.com/bikeeye_wireless...iew_camera.htm
More to come
Old February 27th, 2009, 09:59 PM   #9
Trozza
Out of those two positions I think the one higher up would be best, like you said if its sitting on the hugger its going to be easily seen and it will increase your chances of it being stolen.
Would it get much dirt chucked onto it in that position?
Old February 28th, 2009, 03:20 AM   #10
Gregular
Gregular's Avatar
Ok, DIY is coming this weekend so gonna start a new thread.
It will have everything except for a ride review as my bike is still on its stand for probably another week.
Gonna leave you with this little teaser
Old February 28th, 2009, 03:25 AM   #11
Trozza
That looks good.... Looking forward to the DIY
Old February 28th, 2009, 03:31 PM   #12
headshrink
headshrink's Avatar
Fantastic!
Old March 3rd, 2009, 04:18 PM   #13
Gregular
Gregular's Avatar
DIY is still due the weekends gone and time has flown by so fast. Any spare time has been spent on my lightning kit from tapeworks and once I started experimenting with it, I couldn't stop.
DIY for the camera is still coming, as is the completion of the mirrors DIY and and the crash protectors DIY.
I just got real carried away with working out how to place the kit, it's so freakin cool!! Sorry
Old March 5th, 2009, 12:03 AM   #14
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
This looks nice. Maybe in the summer I can afford this.
On a side note, you got some serious mods for only 2 miles.
islanderman7 is offline   Reply With Quote
Old March 5th, 2009, 11:22 AM   #15
Gregular
Gregular's Avatar
I know, I know. I'm itching to get her on the road.
The wait for the bike to arrive killed me. I read all the forums and each month I couldn't help substituting my lack of bike with an upgrade.
But it's no biggie, I worked hard at school, got good grades, got a good job that pays well and generally have a fairly awesome life. I'm no millionaire lol but there's not much I'd change in it either. I try to live an honourable life and so far karma is treating me well
So with that said, I reckon it's ok to treat myself every now and then and hand on heart, even though she only has 2 on the clock, I have a huge grin on my face every morning I wake up and have a quick sneak peak in the garage before I make my way to work.
DIY's are still on route, just gotta finish it all first
Old March 5th, 2009, 12:49 PM   #16
islanderman7
The Sexy Filipino
Haha, were in the same boat. But I just graduated last year and awaiting to get into Grad school next year.
I too find myself having a sneak peak more than I used to now that my bike is not working.
Be safe if this is your first bike.
Area P CF Standard,Airbox Removed,K&N R-0990,Factory Pro Jet Kit 3.0, Zero Gravity DB
I'm not riding too fast... I'm flying too low.
Old March 5th, 2009, 01:12 PM   #17
yikes... is there a story behind that?
Old March 5th, 2009, 01:36 PM   #18
islanderman7
The Sexy Filipino
Oh sorry, its not that serious. Remember my frayed clutch cable story? Still haven't been able to repair it.
I didn't realize that it would take 2 weeks to get a part from CheapCycleParts because most OEM parts they have listed they do not carry on hand. So it takes 3-5 business days to get it shipped to CCP warehouse, then another 3-5 business days to get to me.
Old March 5th, 2009, 01:39 PM   #19
whew!
as an aside, I've ordered stuff from bikebandit and though they may be a few dollars more, I received my parts within a week to my mailbox. something to consider the next time you need parts in a hurry.
Old March 6th, 2009, 12:27 AM   #20
snoopy07
snoopy07's Avatar
Hi, nice job, but I think there will have mud on your camera at this place...
snoopy07 is offline   Reply With Quote
Old March 6th, 2009, 09:43 AM   #21
Sailariel
Sailariel's Avatar
Greg, The spot on top of the hugger seems to be a good one. Have you thought of getting a small fog/bullet light and putting the camera inside. You can always find a glass shop that could cut you a lens out of glare-proof glass. It would fool thieves and would protect the camera as well. If you look at my avatar, you will see an example of such a light.
Old March 10th, 2009, 04:47 PM   #22
thebulbousone
thebulbousone's Avatar
i was just at advanced auto parts and they have a waterproof,wireless 2.5" color screen back-up camera on sale for $79.99. its made by peak (the same people that make the anti-freeze) and looked pretty cool. think this might work?
thebulbousone is offline   Reply With Quote
Old March 10th, 2009, 07:17 PM   #23
headshrink
headshrink's Avatar
How did you mount the monitor? I am interested in mounting a GPS in the same position.
Old March 27th, 2009, 10:19 AM   #24
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
I just found this. Cool stuff!
Hmm.. wondering if you could use a MPC(size of a playstation portable) with some kind of OS to run a camera, video recorder, GPS, media player, bluetooth, wifi, SSD or 16gb flash memory in a waterproof case...
Anyone?
my flickr™
sometimesido is offline   Reply With Quote
rear view camera auntymunga 2008 - 2012 Ninja 250R Farkles 29 August 21st, 2014 04:02 PM
Rear view camera for your 2fiddy psych0hans 2008 - 2012 Ninja 250R Farkles 11 October 7th, 2012 04:05 PM
Rear-view camera giveaway Toly General Motorcycling Discussion 1 May 5th, 2011 12:07 PM
Rear view camera for newgens JeffM 2008 - 2012 Ninja 250R Farkles 7 April 17th, 2011 09:21 PM
[topix.net] - A Camera's View Of The LA Supercross Ninjette Newsbot Motorcycling News 0 January 25th, 2011 01:51 AM
