April 21st, 2011, 11:05 AM | #1 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
DIY: VEX inspired LED turn signals (Picture intensive!)
So this is my first DIY and didnt think to start until I already dove into the project. However its pretty clear on how to do it.
I Found VEX's DIY on his foot peg turn signals and liked the idea and ran with it. Also I found something similar to what I did on another forum, but I think I did a cleaner job with it I decided to go with RED wide angle 5mm LEDs because I figured that the more light that went in the cagers eyes the more they will notice me turning. You can find the LED's here http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_1915wt_905 I orders 40 of them in total, only took a couple days to reach me, really great shipping I decided to use the rear fairings to put the LED's in, there visible to others and are also pretty hidden. I used 18 LED's per side. Now for the pictures I used a 1/16th drill bit at first to help the bigger 13/64 bit not "walk" Each holes center is a 1/4 inch apart This is with the 100 ohm resistors that I ended up taking off because it made the LED's way too dim, however thats how they were soldered, + to - (in series) 6 LED's each row creates a load of 12v (each LED is rated at 2V) Even if the voltage jumps to 14v it shouldnt burn out the LED's (i hope ) Thats with all the LED's soldered in with the all the +'s at the front and all the -'s at the rear Hot glue is amazing, use higher temp glue, it works much better but you have to wait a bit for it to cool. It not only holds everything in place it also makes it water resistant (waterproof maybe) Notice the resistors still on Had to cut all the heat shrink off then re solder it without them, good think i didnt have to take the LED's and the hot glue out. That would have killed everything Wire both ends up like this, I try and use heat shrink for everything, it looks much cleaner and much better then electrical tape. More heat shrink lol All done and ready to go on the bike Yes my fender is still on I'm waiting on my hot bodies FE kit to come in As of now, when the bike is idling the blinkers dont flash, I need to get a new electronic flasher. Just have no idea what one will work Strange thing is, if if I rev the engine then they start to flash. Makes no sense but whatever All in all I love the mod, it looks amazing and the red matches better then the amber. It took forever (4 hours) because its such little tedious soldering and drilling but it wasn't too hard. Any questions?! |
April 21st, 2011, 11:15 AM | #2 |
That is pretty dang slick Try an fl32 flasher relay from autozone.
April 21st, 2011, 02:32 PM | #3 |
Join Date: Aug 2010 Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D Posts: 266
awesome work man
April 21st, 2011, 02:39 PM | #4 | |
KThanksBye
However when the bike is revving past 4k the voltage jumps to 14v, meaning i guess it did burn out one of the LED's killing on of the strips I still have 2/3 of my right turn signal but im pissed. Oh well I got new resistors and it should be fine Thanks |
April 21st, 2011, 03:22 PM | #5 |
SLIME-R
Join Date: Feb 2011 Motorcycle(s): *SOLD* '10 Kawasaki 250R SE A.K.A. SLIME-R *SOLD* Posts: 596
Amazing job and love the creativity. However, what is your plan with replacing the burned out LEDs? It seems to me that you have made it where everything is a do or die type set up. It would be nice to figure out a way to do this mod. where you could replace the LEDs easily, as you could be pretty sure that at some point or another one or more will burn out before the rest even if you take care of the voltage issue.
It's still an amazing DIY Mod. I just think some more thinking needs to be put into it. |
April 21st, 2011, 03:31 PM | #6 | |
KThanksBye
April 21st, 2011, 05:11 PM | #7 |
Certainly looks cool.
April 21st, 2011, 07:07 PM | #8 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
Great mod, very clean job!
April 21st, 2011, 09:51 PM | #9 |
/linked from the main DIY thread
April 21st, 2011, 10:33 PM | #10 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
That is pretty freakin' sweet Kevin!!! Can't wait to see how you fine tune it and to actually see it in person!! Are you gonna be at the LA ticket to ride? I'd love to see how bright it is in person
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
April 22nd, 2011, 12:31 AM | #11 | |
SLIME-R
Again, Great job! |
April 22nd, 2011, 01:05 AM | #12 | ||
KThanksBye
April 23rd, 2011, 07:29 PM | #13 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
Excellent! I had no idea this idea came from Vex! Glad to see you did them the right way. Here's my try at the same thing, not nearly as pretty as yours...
http://www.newninja.com/forums/f98/s...t=Travisty%27s
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
April 23rd, 2011, 07:52 PM | #14 | |
KThanksBye
April 23rd, 2011, 08:00 PM | #15 |
KThanksBye
This is what im thinking right now, my co-worker has an A4 and the lights are awesome. On the Audi they dont actually flash as the blinkers but that wont stop me :P
EDIT: Just re-thought my idea, it wont work cuz my HID's are so F'ing bright no one is going to be able to see the turn signals, lol Last futzed with by Kevin2109; April 23rd, 2011 at 09:41 PM. |
April 23rd, 2011, 10:47 PM | #16 |
MOTM - Oct '15
Go for it dude! Yea, I have another idea for the front mounts as well... I need to get off my butt and make it happen..
April 24th, 2011, 07:56 PM | #17 |
MOTM - Oct '15
Here's an update to the fronts:
http://www.newninja.com/forums/f98/s...tml#post149024
April 24th, 2011, 08:47 PM | #18 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
Those look awesome kevin and spooph I'm gonna have to check yours out spooph. I like what you are doing with the fronts.
09 ninja 2fiddy SE Driving slow things fast |
April 24th, 2011, 10:01 PM | #19 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
what do i have to do to see the imageshack images? it says that the domain is unregistered...
W.
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
April 25th, 2011, 01:10 PM | #20 | |
KThanksBye
Amazing! One question though... Do you think there going to stand out from the headlight enough? I know with my HID's its had to even look at them lol let alone notice a blinker behind it. I cant wait for the updates Seems to still work for me.... I can PM the pics or Email them to you if you would like |
May 21st, 2011, 11:27 AM | #21 | |
Join Date: Jan 2011 Motorcycle(s): 2006 Ninja 250R Posts: 9
Here is the voltage regulator at RadioShack: http://www.radioshack.com/product/in...ductId=2062600 You probably want to put one or two of these on it since it will get hot too: http://www.radioshack.com/product/in...ductId=2102857 Let us know what comes of it!
--Doerrman You can't learn less. |
May 21st, 2011, 11:33 AM | #22 |
KThanksBye
I think you were reading a post that I put Yeah I ended up using those 12v regulators. This is just a rough drawing I made for someone. Used one regulator per side, and put it all in a project box with heat sinks and cut a hole in the box so the heat sinks could vent. I'll have the bike apart this weekend and will take pictures
May 23rd, 2011, 04:08 AM | #23 |
^^^If you install the LEDs in parallel, you only lose 1 LED (not a string of 6) when 1 burns out!
May 29th, 2011, 05:22 PM | #24 |
Join Date: May 2011 Motorcycle(s): 2008 Blue Ninja 250r Posts: 112
looks awesome.....
June 3rd, 2011, 12:06 PM | #25 |
Good job, looks very nice.
April 15th, 2012, 10:17 PM | #26 |
Newbie Researcher
Could you put a single voltage regulator before the indicator switch so you would get a constant 12v to all the indicators at once and you wouldn't have to deal with project boxes at every site?
April 17th, 2012, 10:18 PM | #27 |
Join Date: Mar 2012 Motorcycle(s): 2009 NINJA 250R Posts: 40
nice job. looks cool.
September 24th, 2012, 06:56 PM | #28 |
KThanksBye
----> My Youtube! <---- Unregistered, watch my youtube page! |
September 24th, 2012, 07:08 PM | #29 |
Love my kittehs!
Join Date: Apr 2012 Motorcycle(s): 2011 Ninja 250R SE Posts: 266
As a waterproofing agent, we use Red and Blue RTV silicone from time to time to make good liquid proof seals on our equipment, might work for this too?
Do you play on XBL? Do you play Halo 4 or COD Black Ops 2? PM me and I will give you my gamertag! |
White 250r w/Green Pearl - Build journal - Picture intensive | s2kenny | Pictures | 35 | May 18th, 2012 11:10 AM |
LED headlight strips (Warning: Picture Intensive) | Live2ride | 2008 - 2012 Ninja 250R Farkles | 12 | November 9th, 2011 06:00 AM |
DIY: Shorten stock turn signals | Gorilla25 | 2008 - 2012 Ninja 250R Farkles | 4 | November 1st, 2011 02:26 AM |
DIY: Installing Mirror-Mounted Turn Signals | noche_caliente | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 28th, 2011 01:56 PM |
DIY: Relocating the rear turn signals | noche_caliente | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 15th, 2009 05:15 PM |
