Old September 7th, 2011, 10:57 PM   #1
ARc
Revolver Wario
ARc's Avatar
Motorcycle(s): 2003 Ninja 250
Logo Dude
Turn Signal Relay Help
So the first bike shop that I went to swapped my CDI box with a box that wasn't even for the right bike, and took parts of my carbs. I just found out that they swiped my turn signal relay too, so I was wondering if you guys could help out.
Is there an alternative to the Denso fe246bh that I can use? I read in another thread someone used a Napa 552 thermal relay flasher, but not sure if that's 100% legit. Would I be better off getting the Denso off of eBay? Or is there a comparable part I can get at an Autozone or something?
ARc is offline   Reply With Quote
Old September 7th, 2011, 11:50 PM   #2
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
a tridon E34, pretty sure its that one... Tri (user CThunder_blue) he uses these things plenty and knows what he's talking about.
Anyway that one should work, but check with Tri!
Trailerboy531 is offline   Reply With Quote
Old September 8th, 2011, 11:45 AM   #3
ARc
Revolver Wario
ARc's Avatar
Logo Dude
Would you be referring to the EP34? Are these things readily available from a local shop?
Old September 8th, 2011, 12:45 PM   #4
ARc
Revolver Wario
ARc's Avatar
Logo Dude
Thanks for the help. Just ended up buying a used relay on eBay.
Old September 8th, 2011, 01:21 PM   #5
HKr1
IC2(SW)
HKr1's Avatar
Originally Posted by ARc View Post
So the first bike shop that I went to swapped my CDI box with a box that wasn't even for the right bike, and took parts of my carbs. I just found out that they swiped my turn signal relay too,?
You go ask them WTF?
Old September 8th, 2011, 02:14 PM   #6
ARc
Revolver Wario
ARc's Avatar
Logo Dude
Owner of the shop facing mad litigation, bailed to France, prolly isn't coming back soon.
Old September 8th, 2011, 05:50 PM   #7
I used the basic one with the same connector as the stock one from superbrightleds.com since I went with LED's. I'm willing to ship you my stock relay as long as you pay shipping, but I won't be home for a few weeks until fall break
Old September 8th, 2011, 05:55 PM   #8
ARc
Revolver Wario
ARc's Avatar
Logo Dude
Thanks man, really appreciate the gesture. I already ordered one from eBay, hopefully it'll be in by next week.
Old September 8th, 2011, 06:03 PM   #9
glad you got something that works. In the mean time, get good at hand signals to make turns
Old January 18th, 2012, 09:28 AM   #10
muzkur
muzkur's Avatar
Motorcycle(s): 10' Ninja 250R
Hi. I'm using a led taillight and led turn signals. All installed with 25w resistors.
But when the turn signal are blinking, the reds in tail light blinks off.
Anyone know how can I fix it? Maybe a relay could fix?
muzkur is offline   Reply With Quote
Old January 18th, 2012, 10:32 AM   #11
Trailerboy531
you need a diode for more than one set of LEDs to function properly. modmy250.com has a no-cut diode kit. Ask Tri on this site CThunder-blue, he's the owner of the site/creator of the kit. He can verify a diode is what you need and help you out.
Old January 18th, 2012, 10:37 AM   #12
muzkur
muzkur's Avatar
Thanks! I'll ask to him.
Old January 18th, 2012, 12:35 PM   #13
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
No need to ask, it's right on his site:
http://modmy250.com/LP.html
Ninja 250R 2008-2011 No-Cut Diode kit $15.00
Old January 18th, 2012, 01:25 PM   #14
Skippii
Milkshake Drinker
Skippii's Avatar
If you're running LEDs, you could just run a 40-Cent 555 and a transistor instead of a relay
Posted via Mobile Device
Old January 18th, 2012, 09:00 PM   #15
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Most folks don't know how to wire a 555, and probably lack the desire to learn how. Plus, to fully implement a 555 solution some PCB work as well as weather-proofing and filtering would be considered necessary. It would be easier to just get an automotive-type electronic flasher and make an adapter terminal set, or better yet just buy a purpose-made electronic flasher such as this:
http://www.cyclegear.com/eng/product...lay/web1006869
It's plug and play.
Old January 18th, 2012, 10:05 PM   #16
Skippii
Milkshake Drinker
Skippii's Avatar
It's plug and play.
True, but if I'd said "I can make a flasher unit from one of the 555s I have in my desk faster than you can go out and buy one from a store", it wouldn't be a very helpful post. Plus, I'd come across like a jackass.
"What a sweetheart."- ninja_sleeper to me
How to install LED front turn signals & relay CThunder-blue 2008 - 2012 Ninja 250R Farkles 56 August 17th, 2014 02:31 PM
turn signal relay flasher install contact148 2008 - 2012 Ninja 250R Tech Talk 11 October 8th, 2013 02:05 PM
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
'08 Turn Signal Relay Countersteer Motorcycle-related 0 June 10th, 2012 01:54 PM
