Old January 31st, 2010, 10:35 AM   #1
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Does my engine sound normal?
Hi guys, just wanted a sanity check here. After reading all the posts about hard ticking and such, I figured, I'd have you guys evaluate whether or not my engine is ok. I have about 450 or so miles on the bike right now. Here are the videos:
(Videos are of the bike idling with choke on at about 2,500 RPMs)
Rear brake side:
http://www.youtube.com/watch?v=bhBwll7UHn0
Chain side:
http://www.youtube.com/watch?v=HKVVkoJc_9Y
EDIT: Here is the video with the bike properly warmed up and no choke (idling at 1350 RPMs)
http://www.youtube.com/watch?v=QovxVbPOyxw
Thanks all!
P.S. the engine oil looks low since it's on the side-stand.
Last futzed with by Betlog; January 31st, 2010 at 02:42 PM.
Betlog is offline   Reply With Quote
Old January 31st, 2010, 11:10 AM   #2
littledog
littledog's Avatar
Motorcycle(s): 2009 Special Edition Ninja 250 a good memory, 2011 Suzuki DL 650 the new ride
It sounds like mine does
littledog is offline   Reply With Quote
Old January 31st, 2010, 11:23 AM   #3
Momaru
Momaru's Avatar
Sounds about right to me. Our engines have a little bit of clatter just due to the way they're constructed.
That said, 2,500 is a bit high for idle. Manual spec says 1350, most people run @ ~1500 for ease of checking it. Might consider changing it once the bike's warmed up via the idle adjustment knob on the left side.
Proud member of the Blue Army
Old January 31st, 2010, 11:27 AM   #4
Betlog
Betlog's Avatar
I see. By the way, regarding the idle, the engine is not fully warmed up and I was going by the manual to say to moderate the choke to keep it constant at 2,500 RPM before riding. Mine does idle around ~1,500 RPM.
Old January 31st, 2010, 12:32 PM   #5
Momaru
Momaru's Avatar
Ah, that makes sense then.
Old January 31st, 2010, 02:42 PM   #6
Betlog
Betlog's Avatar
Old January 31st, 2010, 03:22 PM   #7
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Sounds good
Nice steady idle.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old January 31st, 2010, 07:44 PM   #8
Betlog
Betlog's Avatar
Originally Posted by ninja250 View Post
Sounds good
Nice steady idle.
Old February 4th, 2010, 03:50 PM   #9
Avaholic88
Avaholic88's Avatar
I don't mean to hijack the thread, but it seems like yours is good. My 2009 ninjette with about 5300 miles has definitely developed a fluttering rattle or "ticking" recently, one that wasn't there before. It follows the engine speed, becoming more pronounced when the throttle is applied, and it is still noticeable when in neutral, so I can't imagine it's the drive chain.
The only suggestions I've received is cam chain slap due to a tensioner gone bad, and that makes sense to me, but I'm trying to get some confirmation and some direction. I found the DIY maintenance in the older generation tech section, but when I look up the parts on our new models, the assembly looks different.
This being my first attempt at doing anything on my bike, I'd like to be certain I know what I'm doing. Can anyone point me in the right direction for something similar to this page -- http://faq.ninja250.org/wiki/Cam_cha...er_maintenance -- but one geared towards a 2009?
Thanks.
Avaholic88 is offline   Reply With Quote
Old February 4th, 2010, 04:56 PM   #10
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I have seen this about the cam chain tensioner here I think?
Talks about how to install it near the end.
http://www.ninjette.org/forums/showthread.php?t=9924
If you need more info I can check the service manual.
LMFAO!
Weaksauce
Old February 4th, 2010, 05:07 PM   #11
Avaholic88
Avaholic88's Avatar
That looks right... Now maybe I have the courage to take on my first job, even one as simple as this. Thanks
Old February 5th, 2010, 01:53 PM   #12
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
As requested via PM here's the Cam Chain Tensioner torque specs. (I'll post them here for others too)
CCT mounting bolts torque 87in-lbs, 1.0kgf-m, 9.8N-m
CCT cap bolt (under holder plate?) 44in-lb, 0.5kgf-m, 5.0N-m
LMFAO!
Weaksauce
Old February 5th, 2010, 10:53 PM   #13
Momaru
Momaru's Avatar
Also a little more in-depth CCT install at the YeagerGroup website near the end of their valve clearance adjustment:
http://www.theyeagergroup.com/2008_n..._clearance.htm
A new CCT seems to have fixed my clatter (coulda been the valve adjustment, but I doubt it)
Is This Engine Noise Normal for 250? Ninjettepgh 1986 - 2007 Ninja 250R Tech Talk 14 April 9th, 2023 07:12 AM
Engine dies during cold starts, normal? caineroad 2008 - 2012 Ninja 250R Tech Talk 9 October 24th, 2013 04:10 AM
Engine ticking sound Nosajong 2008 - 2012 Ninja 250R Tech Talk 4 May 21st, 2013 07:57 PM
engine tapping sound bandit_fosky 2008 - 2012 Ninja 250R Tech Talk 16 March 17th, 2013 07:59 AM
What is the normal operating engine temperature? arnoldc6 2008 - 2012 Ninja 250R Tech Talk 16 February 21st, 2013 01:30 AM
