March 9th, 2012, 05:08 PM | #1 |
Join Date: Aug 2011 Motorcycle(s): 2012 Ninja 250, 2008 Daytona 675 Posts: 212
Just installed Corbin seat
The usual adjustment problem for the bracket was solved by loosening up the bolts on the seat and slightly moving the bracket, it has a few mm of play (back and forth as well as in/out). If you find your bracket isn't lined up due to height problem then you did not install the seat completely, it takes a few minutes to make sure it's seated properly.
Due to rain I can't tell whether the slide forward problem is solved but the seat IS more cushy, just by sitting on it in the garage. By looking at it I think it will be more convenient, the nose of the seat is definitely longer and slightly higher. Pix for comparing the stock vs Corbin. |
March 9th, 2012, 07:12 PM | #2 |
Blind 250 Loving Whore
Looks good. I like how it's a little higher, the stock seat is a little low for me. Where'd you get it?
March 9th, 2012, 07:56 PM | #3 |
March 9th, 2012, 08:25 PM | #4 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
I'd love a review once you get a chance to ride. I've been interested for a while, but haven't been able to pull the trigger on one.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
March 9th, 2012, 08:26 PM | #5 |
Join Date: Sep 2011 Motorcycle(s): 2008 Kawasaki Ninja 250 *Nikkita* - 2003 Buell XB9R Posts: 274
looks good. i plan on buying one mid summer so i can break it in before our '12 ninja rally
March 9th, 2012, 09:37 PM | #6 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
Your's is a very different shape to the corbin seat I got back in October of 2011.
March 10th, 2012, 06:00 AM | #7 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
i had a corbin on my SV best product ever but so expensive brand new, lookin for a used one now.
March 10th, 2012, 02:09 PM | #8 |
MOTM - Feb '12
Just found a used one on Craigslist -- asking only $10 less than new.
March 10th, 2012, 02:36 PM | #9 |
March 10th, 2012, 10:33 PM | #11 |
Join Date: Aug 2009 Motorcycle(s): '08 250R (sold), 2013 300SE Posts: 276
Thinking of pulling the trigger on one myself.
March 11th, 2012, 01:04 PM | #12 |
Quick 30 mile test
With weather cooperating I set out on a nice leisurely ride to local CG store.
1. It could be me but I've noticed that the seat is transferring a little more vibration to the rider. I definitely felt it in one spot on the freeway where I've not felt it before. This is somewhat counterintuitive since the seat is softer. 2. The seat is softer! Very cushy. 3. The "hang one buttcheek" has to be readjusted now. The seat is not wider at the widest point (which is right by the rear cowl) but it is less curvy which means it is wider at the point where you sit, by about .5" 4. But because the seat has well-defined edges you can definitely tell when you've shifted over enough. 5. Typically after a week long break my first ride results in some lower back pain. Not this time around. 6. Not sliding into the tank. I didn't really need to make a conscious effort to stay away from the tank before, but with this seat I tend to not worry about shifting back...or at least I do it a lot less, and that's in my mesh pants which are a little slidy. All I have to say is "My ass finally has the support it deserves". Corbin, you can contact me for the address where to send the check for this awesome marketing slogan. |
March 11th, 2012, 04:51 PM | #13 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
I've heard many good reviews on Corbin seats... I probably should have bought one a long time ago... I just don't want to buy another Luimoto seat cover to make it match (the one I have I over did it on the staples and it wouldn't be easy to use it over on another seat)
On a side note... what tank and side panel grips are those? I really like them, especially the tank grips as thats where I would need them to be... any and all info would be appreciated!!!
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
March 11th, 2012, 05:12 PM | #14 | |
March 11th, 2012, 05:16 PM | #15 |
ninjaholic
Thanks for the clarification... after I saw your picture I started google searching and found them and figured that was the right kind... then I looked at your picture again and sure enough it says STOMPGRIP right on your bike
I definitely want to get some now... thanks again
March 16th, 2012, 12:19 AM | #16 | |
This was one of my last upgrades (ebay), but it should have been the first.
March 16th, 2012, 05:25 AM | #17 |
oh....I didn't know they changed their design.
Solo seat cowl installed and passenger seat modification. | LittleRedNinjette | 2013 - 2017 Ninja 300 Farkles | 18 | March 3rd, 2017 03:58 PM |
Corbin Seat Installed | Mazakawi | 2008 - 2012 Ninja 250R Farkles | 19 | August 19th, 2013 12:55 PM |
Corbin seat installed | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 7 | February 25th, 2013 06:19 AM |
Corbin seat FS | RedOctober | Motorcycle-related | 4 | June 18th, 2012 10:50 AM |
Fender Eliminator, Corbin Seat, Rear Seat Cowl Installed | k-os | Pictures | 9 | February 10th, 2009 08:56 AM |
