Old June 22nd, 2018, 04:33 AM   #1
pb3
Motorcycle(s): 09 n250, 14 n300, 22 n400
service fuel level inspection
hi gang, con't from https://www.ninjette.org/forums/showthread.php?t=316226
so i've got the carbs off and trying to verify the service fuel level inspection outlined in the manual.
the behavior i find is exactly as seen in this video
https://www.youtube.com/watch?v=PHuB1lyagKM
i'm ~10mm off.
when i measure the float height i'm good at 17-18mm. but i wanted to prove out with the level inspection. has anyone else experience with this?
tia,
parker
pb3 is offline   Reply With Quote
Old June 25th, 2018, 12:04 AM   #2
Did you turn on fuel-flow from petcock with vacuum? New-gens don't have fuel-flow when turned to PRI position without vacuum.
Old June 25th, 2018, 06:15 AM   #3
What would the point of PRI be if it needs vacuum?
Old June 25th, 2018, 09:34 AM   #4
I know, it's stupid.
Old June 25th, 2018, 12:46 PM   #5
Ralgha
Ralgha's Avatar
Pretty sure PRI doesn't depend on vacuum, it just flows gas all the time.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old June 25th, 2018, 12:58 PM   #6
It's certainly supposed to be that way.
Old June 25th, 2018, 05:40 PM   #7
pb3
sorry guys, i implied when i said carbs off bike that i was following the manual's instructions and using a aux fuel tank.
i ended up trial and error on the tangs to see different levels and in doing so realized why the manual states "several turns" of the drain bolt. that actions appears to help evacuate the air bubble that forms.
Old June 25th, 2018, 07:00 PM   #8
Several turns allows for full pressure of fuel in bowl to fill column externally and achieve equilibrium not restricted by flow-rate of bleed screw.
Old June 25th, 2018, 10:05 PM   #9
Yeah, this is one of those cases where the manual is clearly wrong.
How to properly check oil level. Best fuel octane for stock bike TheCoolNinja 2008 - 2012 Ninja 250R Tech Talk 26 November 5th, 2016 06:23 PM
Fuel level ? Mohawk 1986 - 2007 Ninja 250R Tech Talk 13 November 5th, 2016 06:44 AM
[motorcycle.com] - Honda CBR500R and CB500F Recalled for Faulty Fuel Level Sensor Ninjette Newsbot Motorcycling News 0 August 10th, 2015 10:40 AM
