Old November 26th, 2012, 10:02 AM   #1
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
Question valve emulators
http://www.amazon.com/Caddies-Cartri.../dp/B000GV0RWO
Been considering these with my Amazon gift card, due to the reviews I've read on the ninja250.org site. Does anyone have experience with these? Worth it?
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old November 26th, 2012, 01:23 PM   #2
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
Make sure you get springs too. Worth every penny.
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
Old November 26th, 2012, 01:33 PM   #3
lolibater
lolibater's Avatar
The main reason I'm looking to get the valve emulators is to soak up a little more road vibration, as well as provide better dampening. What type of springs should I look into?
Also, I assume the fork oil will need to be changed for this. Which oil should I replace it with?
Old November 26th, 2012, 02:08 PM   #4
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
http://www.sonicsprings.com/catalog/...pring_rate.php
sonic springs r cheaper than race-tech
THE GOOD LIFE
cuz is offline   Reply With Quote
Old November 26th, 2012, 02:47 PM   #5
lolibater
lolibater's Avatar
Awesome! Thanks for the info, I'll check those ones out too.
What should I be looking at for installation labor?
Old November 26th, 2012, 02:54 PM   #6
cuz
cuz
cuz's Avatar
fork and oil seals
http://www.ninjette.org/forums/showthread.php?t=23200
THE GOOD LIFE
Old November 26th, 2012, 02:58 PM   #7
lolibater
lolibater's Avatar
So about 2 or 3 hours. Sounds about right. Should only run me about $150 to a friend to install.
$350 all together for the springs, emulators, oil, and labor.
Any word on what fork oil to use?
Also, I found a set of "stiffer than stock" front springs, that the previous owner had given me. Is there any way to tell what the stiffness is on them?
Old November 26th, 2012, 05:27 PM   #8
Lychee
sail away
Lychee's Avatar
I just refreshed my forks this weekend. It is really easy. Gear puller is not necessary to compress the cap. Make sure you install this:
Highly recommend you do the suspension upgrade in stages. Refresh fork oil first (easiest and probably needs to be done anyway). Ride for awhile. Then add springs (sonic springs are cheap). Ride for awhile. Then have valve emulators installed (expensive). This way you can feel what happens for each thing you change and log it in your memory somewhere.
According to the ninja 250 FAQ the stock spring rate is 0.44 kg/mm. Spring rate can be measured if you have a measuring caliper. Find a calculator on the net and input the measurements. Usually you measure things like outer diameter, thickness of spring, unloaded length, number of coils, etc.
How much do you weigh? Use your weight in the spring calculator on race tech or sonic springs' websites. This will tell you what weight fork oil to use. I don't think the brand matters unless you are racing.
Old November 26th, 2012, 05:31 PM   #9
lolibater
lolibater's Avatar
I weigh 135 on a heavy day, so not heavy at all.
I'll take a look at their site to determine the stiffness and report back on what I think they are. Sonic Spring's name sounds vaguely familiar.
Old November 26th, 2012, 05:47 PM   #10
Lychee
sail away
Lychee's Avatar
You may be too light for their lightest spring (0.7 kg/mm). The Race Tech calculator suggests 0.626 kg/mm for you. Sonic Springs says 0.7 kg/mm, but I think that is wrong since I weigh 170 and it lists 0.7 for me. Sonic springs does do custom spring rates for feather weights.
Old November 26th, 2012, 07:35 PM   #11
lolibater
lolibater's Avatar
The ones I have are .8
Too stiff?
Old November 27th, 2012, 05:50 AM   #12
Jim Moore
Jim Moore's Avatar
Too stiff?
I weigh 160. I have 0.70s. They're a little soft. The 0.80s may be a little stiff for you, but they will be a huge improvement over the current springs. You can make your own spacers from 3/4" id pvc pipe. That's what Race Tech sends you when you order springs. You can try different spacer lengths to see how much sag it gives you. Try different spacer lengths until you end up with 25-35 mm of sag.
Speaking of that, I would buy the emulators from RaceTech if I were you. Once you buy the stuff they're available to answer questions. They're really helpful. I don't think Amazon has any suspension experts on staff.
Jim Moore
Jax, FL
Old November 27th, 2012, 07:13 AM   #13
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
emulators / springs
The Concours has emulators and they work pretty well to reduce sharp bump harshness.
One frugal idea, you can make your stock springs stiffer by cutting them shorter. For example, if you cut them 25% shorter they become 25% stiffer, so 0.44 / 0.75 = 0.587 Kg/mm. You replace the cut off bit with a piece of pipe and a couple of washers.
It is possible to go overboard on this and then the spring binds and that is probably undesirable.
GeorgeRYoung is offline   Reply With Quote
Old November 27th, 2012, 08:30 AM   #14
Lychee
sail away
Lychee's Avatar
Really? What kind of riding do you do? Pace in turns? Maybe their calculator is wrong. Are you a bad ass on the wee ninjette?
Old November 27th, 2012, 08:36 AM   #15
Jim Moore
Jim Moore's Avatar
Originally Posted by Lychee View Post
Really? What kind of riding do you do? Pace in turns? Maybe their calculator is wrong?
I'm a speeder, lol. The 0.70s with the recommended spacer gave me over 40 mm of sag. I put in a longer spacer and brought it down to about 35 mm. I was planning to try a little longer spacer, but I decided to sell the bike instead.
Jim Moore
Jax, FL
Old November 27th, 2012, 08:39 AM   #16
Lychee
sail away
Lychee's Avatar
Hmmm... maybe I should go with 0.75.
Old November 27th, 2012, 08:56 AM   #17
lolibater
lolibater's Avatar
So....... is the general consensus that .80 is too stiff for me?
Old November 27th, 2012, 09:01 AM   #18
lolibater
lolibater's Avatar
From the sonic springs site. I estimated my gear at ~ 15-20 lbs. Hopefully that's not too much. 90% of the time I have a tail bag, and 100% of the time I have a tank bag.
Old November 27th, 2012, 09:02 AM   #19
Lychee
sail away
Lychee's Avatar
way too stiff. I got a couple of forks over here you can throw those extra springs into.....
Old November 27th, 2012, 09:05 AM   #20
Jim Moore
Jim Moore's Avatar
Throw 'em in there. See if you like it. Swapping springs is simple once you see it done.
Jim Moore
Jax, FL
Old November 27th, 2012, 09:06 AM   #21
lolibater
lolibater's Avatar
What rate would you suggest for me?
What is our stock spring rate anyways?
I'm also wondering if the emulators will help to "mitigate" the "overly stiff" spring? I'll pick up another set of springs if need be and sell these.
Old November 27th, 2012, 09:09 AM   #22
Lychee
sail away
Lychee's Avatar
That's a good estimate of weight.
I feel like the sonic springs calculator has an oddity. Varying your body weight 10 or 20 pounds doesn't seem to change the recommended spring rate when it seems like it should. Try the race tech calculator for a second opinion.
Old November 27th, 2012, 09:13 AM   #23
Lychee
sail away
Lychee's Avatar
0.6 per race tech
0.44 stock per faq
no, I am pretty sure they do different things.
I'm with Jim on this one. Throw em in and see how it reacts. Changing them is really easy.
Old November 27th, 2012, 09:14 AM   #24
Jim Moore
Jim Moore's Avatar
The stock springs are 0.44 according to RaceTech. That's way too soft. I'm not sure who they were building the bike for, but that's ridiculous. The 0.8 may be a little stiff for you, but it's within well the reasonable range. You can compensate with a shorter spacer. All you're trying to do is get approximately 30 mm of sag. As long as your springs are close (which you are with the 0.8s) it doesn't really matter if you do it with a stiffer spring and less preload (shorter spacer) or a softer spring and more preload (longer spacer).
Jim Moore
Jax, FL
Old November 27th, 2012, 09:23 AM   #25
Lychee
sail away
Lychee's Avatar
Hmmm. begs the question: What length of spacer would put the stock spring at 30 mm sag? Although the travel would probably be too short to be usable.
Old November 27th, 2012, 09:32 AM   #26
lolibater
lolibater's Avatar
racetech recommended .70
Old November 27th, 2012, 09:42 AM   #27
lolibater
lolibater's Avatar
If I installed emulators, new oil (still need to know what weight; i believe stock is 15?), and the .8 springs at the same time, and find the springs too stiff, will I have to remove the emulators and oil to change to a softer spring?
Old November 27th, 2012, 09:43 AM   #28
psych0hans
psych0hans's Avatar
I believe you will just have to remove the springs... Not sure about the oil, but there will be no need to remove the emulators...
Old November 27th, 2012, 09:50 AM   #29
lolibater
lolibater's Avatar
Thanks for the info Hans.
"Fork oil" is just normal oil right?
Old November 27th, 2012, 09:55 AM   #30
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Are the 2008+ springs stiffer then the pregens?
Old November 27th, 2012, 09:55 AM   #31
psych0hans
psych0hans's Avatar
You get special fork oil to put in your forks... If you have it available, I'd recommend that. It's not TOO expensive. Just look on amazon/eBay.
Old November 27th, 2012, 09:57 AM   #32
psych0hans
psych0hans's Avatar
I believe they are... .63 as opposed to .44... I've bought .70 for my newgen and I weigh about 155lbs without gear.
Old November 27th, 2012, 10:13 AM   #33
lolibater
lolibater's Avatar
Based on your numbers here, it would seem .8 might be a little stiff. Is it really as simple as compensating with a shorter spacer?
Old November 27th, 2012, 10:19 AM   #34
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
No there is an optimal range for the amount of preload you want to apply to a spring, to much or to little will not work as it was intended. You can also mix spring rates if you have a second set like a .80 on the left and a .70 in the right to make a .75 setup. The same can be done with different wieght fork oils.
Old November 27th, 2012, 10:22 AM   #35
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
When I talk to race tech about a custom spring for my NSR they told me if I didn't like what they recommended then they would trade me out for a different set. They quite nice so you may want to talk to them direct and ask someone like Dave moss just tell him Jason Perez sent you.
Old November 27th, 2012, 10:26 AM   #36
lolibater
lolibater's Avatar
Are you sure about that? That doesn't seem correct to me. Any time you'd hit a bump, the bike would pull towards the side with the stiffer spring.
Old November 27th, 2012, 10:31 AM   #37
psych0hans
psych0hans's Avatar
Yes, I definitely appreciate their customer service. Hey mailed me the ideal setup for my front and back despite not having bought from them directly. They also recommended the perfect spring for the gsxr rear shock (yet to be)installed in my ninjette accordin to our combined weights... Good people... I might consider picking up their gold valve kit for my rear shock too, once I get it installed and give it some decent seat time...
Old November 27th, 2012, 10:34 AM   #38
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I've only got like 7 years of professional racing experience at the national and world levels so I may not know what I'm talking about
But really some Superbike have only compression valves in the left and rebound valves in the right. That is why we have upper AND lower triple clamps, they keep everything inline. Given a 250 doesn't have the same level of bracing as a 1000ss it is still stiff enough to handle a difference in springs of at least .15
Old November 27th, 2012, 10:34 AM   #39
Nope. The axle needs to be stiff enough, and held tight enough, that that fork legs travel up and down together. If it weren't, our bikes would have terrible handling problems from the get go.
It's how Yamaha and other manufacturers have the compression adjustment in one fork leg, and the rebound in the other. The different forks are actually controlling completely different things. This isn't a cost-saving measure, they do the exact same thing in their $M+ GP bikes.
EDIT: What Jason said.
Old November 27th, 2012, 10:54 AM   #40
lolibater
lolibater's Avatar
That's freakin cool. Sorry for doubting you lol, I'm sure you can see where I might have had reservations about that.
Would it be unwise to have a stock .44 on the right and a .8 on the left? Not sure if they need to be closer values.
'94+ EX500 fork tubes and valve emulators in an EX250J? CZroe 2008 - 2012 Ninja 250R Tech Talk 1 February 7th, 2013 10:12 PM
Just picked up some gold valve emulators psych0hans 2008 - 2012 Ninja 250R Tech Talk 2 July 17th, 2012 11:34 AM
Gold Valve Emulators KChatham 2008 - 2012 Ninja 250R Tech Talk 4 January 4th, 2012 11:03 PM
Front fork Valve Emulators? empire00 2008 - 2012 Ninja 250R Tech Talk 5 July 21st, 2009 01:30 PM
