Go Back   ninjette.org > General > Ride Reports
Old November 19th, 2013, 12:12 AM   #1
SabreValkyrn
Motorcycle(s): 2017 Motus MSTR (Kara), 1990 Ninja 600R (ZX600C3) (Scrappy)
Puddles are scary
I park in a parking garage, and the exit has a cement encased exit ramp up to ground level. Today, there was a large puddle, had no choice but to go through it. So I swung wide to limit angle inside the puddle; unfortunately this put me deeper into it. The garage is well maintained, so I wasn't worried about junk in the puddle.
Ivy had been running for about 10 seconds when I went through the puddle.
Part way home, she didn't sound right. Her exhaust sounded odd and power wasn't there.
Upon further inspection, the header-to-S bend clamp was broken. I think the heat change from engine to puddle cracked it.
Got two hose clamps that should work relatively well.
But, that was exciting and unusual.
SabreValkyrn is offline   Reply With Quote
Old November 19th, 2013, 05:50 AM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
You officially have the weakest 250 ever made, a freaking puddle?
Old November 19th, 2013, 10:29 AM   #3
SabreValkyrn
Looks like the bolt and clamp was damaged from when I bottomed out a while ago. Perhaps the temperature change was the last straw for the weakened clamp
Old November 19th, 2013, 05:59 PM   #4
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Hate it for your luck... I used to think puddles were scary, haven't felt that way for a while.
Old November 19th, 2013, 06:25 PM   #5
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
What's scary is riding in a rain so hard that you can barely see the lanes and cars are pulling to the side of the road cause they can't see. Your visor is fogging up when it's down, but when it's up the rain feels like a barrage of needles to the face, so you crack it open just enough to see.
That's scary
this probably isn't good(puddles never are) EvilPooMonkey 2008 - 2012 Ninja 250R Tech Talk 13 July 7th, 2012 11:42 AM
It's windy and scary Top Tomato General Motorcycling Discussion 27 October 1st, 2010 07:35 PM
A scary thought BlueRaven General Motorcycling Discussion 46 November 21st, 2009 06:31 PM
this is scary istreefitty Off-Topic 22 October 17th, 2009 12:55 AM
Scary (Twilight) istreefitty Off-Topic 15 August 19th, 2009 04:59 PM
