April 12th, 2010, 02:20 PM | #1 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
250R Air Filter Cleaner???
I read the owners manual about cleaning the Air Filter element, but i know using gasoline or such is a No-No. Is Soaking it, using a 30W Oil really necessary after cleaning it?
What about using this? http://www.magicracing.com/Maxima-Ai...oz_p_8465.html Would this be worth the price, or No? Im also thinking of buying and trying this stuff out! http://www.magicracing.com/Maxima-Cl...oz_p_8463.html Im curious to know if anyone out there has Used either of these products! What kinda results did you get? Im gonna Ride up to Magic racing later today or Wed, as they have the Best Price for http://www.magicracing.com/Maxima-Ch...z41_p_504.html also while im there im gonna pick up a Cable Lube Tool! Ok ill check back here in 1 hour for your guys' 2 cents! Im gonna pop out the Air filter element and have a look. (i never looked at mine yet, just flipped 6,610 miles today after work) |
April 12th, 2010, 02:33 PM | #2 |
Foam filter should be cleaned and then reoiled. It's the oil that traps the dust in the air that is being sucked through the filter.
I use gasoline to clean my foam filters, but only recommend it if you are fully aware of the dangers of doing so. Otherwise, use a low flash point solvent. After I clean with the gas, I wash the filter using a strong detergent (simple green, full strength) and warm water to get all of the dirt out. Air dry completely overnight, then oil the filter by putting in a plastic baggie and adding oil. Squish it around remove from bag and use a dry rag to get out as much of the oil from the filter. The idea is to coat the foam cells as lightly as possible, throughout the filter. Reinstall and ride away happy. The process takes a couple of days, so plan for it or have another preoiled filter handy so you can just switch it out. |
April 12th, 2010, 03:39 PM | #3 | |
My car dont need taht done to its air filter. Years ago i had a Monte Carlo SS, and i bought a K&N air filter for it. I had to clean then oil it. Yea, i figured thats the reason for the oil, to trap fine dust/dirt, but wasnt sure if that was really neccessary for our 250s! Gasoline, hmmm what about Diesel Fuel instead, to clean the element? I got that in hand atm... lol |
April 12th, 2010, 03:43 PM | #4 |
use anything that will cut/dissolve the greasy oil/dust mixture. just be sure to wash it with warm soapy water later to insure the foam filter is clean.
April 14th, 2010, 09:49 PM | #5 | |
1 - regular car (and some bikes) paper filter which you throw away and replace 2 - foam filter as on 250 which you wash and oil 3 - k&n which is like a guaze material and has its own chemical to put on it |
New Air Filter from Hurricane Racing for the Ninja 300 & 250R | DaBlue1 | 2013 - 2017 Ninja 300 Farkles | 8 | March 25th, 2013 04:46 AM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Anyone know an air filter I can replace the OEM filter with? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 22nd, 2012 09:34 AM |
Maxima Air Filter Cleaner | tlhamon | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 18th, 2009 10:22 PM |
