Old August 26th, 2017, 04:30 PM   #1
corksil
Motorcycle(s): A lot.
How can I clean a yellowed (white) gas tank?
I've got new plastics on the bike, all are white. The original tank is white, but being as it's 20+ years old, the tank has become quite yellow and does not match the other new white plastics.
I've tried one or two different solvents, I'm not keen on re-painting it either.
Any ideas?
I can take a picture if it helps..
It's a plastic tank and I want it to be brilliant bright white again.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old August 26th, 2017, 06:47 PM   #2
Pretty sure the yellowing is not going to "buff out". The plastic itself, or the clear coat if it has one, has yellowed over time from exposure to UV or the elements.
I don't think it's possible to get it back to white with chemicals or abrasives.
Old August 26th, 2017, 07:18 PM   #3
Just curious... what bike has the plastic tank?
Old August 27th, 2017, 11:24 PM   #4
corksil
Yeah, I more or less came to the same conclusion. Which led me here to ask for advice. I can't afford a new tank, and have to figure out how to make this one white again.
A 95' yamaha 80 that isn't an 80 anymore. It's a hell of a lot bigger in terms of piston size and engine work. Set up for street riding with the proper wheels/tires and lights/turn-signals to match. Street legal yz80 with a plastic tank.
Old August 27th, 2017, 11:44 PM   #5
MrAtom
MOTM - July '15
I love your posts, corksil.
Old August 28th, 2017, 10:29 AM   #6
Flying
Motorcycle(s): 2010 Ninja 250
Try submerging in an acid such as vinegar, then try using hydrogen peroxide.
Old August 29th, 2017, 01:44 PM   #7
corksil
^^ That's an interesting suggestion. I'm going to try vinegar and will report back with results. Submerging the tank would mean that I'd have to take it off the bike, but a couple gallons of vinegar, and find a suitable container to soak it in. Sounds difficult but if it were to work out... it would be worth it.
Old August 29th, 2017, 02:29 PM   #8
Before you bother soaking the whole tank, soak a folded paper towel in whatever magic solution you want to try and lay it on the tank. Cover it with plastic wrap and seal it with tape. Come back the next day and see if it did anything helpful.
Old August 30th, 2017, 07:18 PM   #9
corksil
^^^^ Seeing as I have white cider vinegar in the garage for washing window glass, and an abundance of rags and tape... I'm going to go do that right now.
The reason I made this thread is to figure out if there is indeed a magic solution or chemical.
I hate to say it.. but I don't think such a chemical exists.
Time to do more research..
Old August 30th, 2017, 07:24 PM   #10
corksil
Stock fuel capacity is 1.3gal......
I'm seeing oversize tanks that hold 2.2gal...
There is no way of documenting the "range" of this bike until the trailtech goes on, and it realllllly varies depending on riding style. Puttering about doesn't use anywhere near as much fuel as screaming through the gears.
Dangit I wish everything weren't so damn expensive.
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
Wtb: White se gas tank greatwhiteninja Items Wanted 0 October 9th, 2011 03:05 PM
