Old August 2nd, 2011, 05:53 PM   #1
86ninjarider
Motorcycle(s): 1986 kawasaki ninja ex250r
bike wont idle right :(
maybe someone can help me out..i have an 86 ex250r and right now it is idling around 3000-3500rpm and the manual says it should idle around 1300rpm...anyone know how i can fix this! any advice will be greatly appreciated!!!
86ninjarider is offline   Reply With Quote
Old August 2nd, 2011, 06:38 PM   #2
bungie4
IBA # 44620
bungie4's Avatar
Motorcycle(s): 94 Ninja EX250F, 2004 Yamaha FJR 1300
First things first. Can you adjust the idle speed with the black adjuster knob on the clutch side of the carbs?
bungie4 is offline   Reply With Quote
Old August 2nd, 2011, 06:59 PM   #3
86ninjarider
yea when i try that it just shuts off...i cleaned the carbs but it still will only idle there or it just shuts off
Old August 2nd, 2011, 08:36 PM   #4
bungie4
IBA # 44620
bungie4's Avatar
But otherwise the bike runs fine?
You say you cleaned the carbs, did you remove the idle mixture screws, clean them? Clean the ports leading to the throttle body?
Old August 2nd, 2011, 08:49 PM   #5
86ninjarider
yea fully took apart the carbs and used 2 cans of carb cleaner. and other than the idle the bike runs fine...there is smoke coming off the exhaust (off of the outside not from inside them) i suspect its just old oil residue (25 year old bike) but yea those are the only real problems i can tell is the idle rpms are running 3000 and the smoke off the exhaust
Old August 2nd, 2011, 09:17 PM   #6
mrlmd
mrlmd's Avatar
Is the choke (enricher) off, does the choke work, cable's not stuck or kinked?
Old August 2nd, 2011, 09:21 PM   #7
86ninjarider
nope the cable is in good condition just checked that today when i put the carbs back in
Old August 3rd, 2011, 07:24 AM   #8
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
Are the butterflies reasonably in synch, i.e. do they more or less close at the same time?
GeorgeRYoung is offline   Reply With Quote
Old August 3rd, 2011, 07:56 AM   #9
Did you use compressed air to blow out the pilot jets and idle circuits as well as using the carb cleaner on them? or just the carb cleaner? The canned carb cleaner doesnt always get all of it. Try to run some seafoam or other carb cleaner thru with the gas and that should loosen up anything the aerosol carb cleaner missed
Old August 3rd, 2011, 08:23 AM   #10
86ninjarider
yea the butterflies are perfectly in sync and what is seafoam?? and how is it used ive never heard of it
Old August 3rd, 2011, 08:59 AM   #11
FBNTH
Motorcycle(s): None yet
http://www.seafoamsales.com/
Rick
FBNTH is offline   Reply With Quote
Old August 3rd, 2011, 09:09 AM   #12
86ninjarider
thanks alot, i just ran it for about 10 mins and the best i could get it to idle in is 2500rpms... but the good news is that the smoke is gone...
09 Ninja 250r wont stay idle without choke TqAmsNy 2008 - 2012 Ninja 250R Tech Talk 11 March 20th, 2013 01:38 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
FI model problem - wont idle well and throttle surges Christofeser 2008 - 2012 Ninja 250R Tech Talk 4 January 16th, 2012 05:07 AM
Erratic idle, wont start cold, etc. d16soda 1986 - 2007 Ninja 250R Tech Talk 9 August 24th, 2011 02:12 PM
bike wont idle james250ninja 1986 - 2007 Ninja 250R Tech Talk 7 April 1st, 2010 12:05 PM
