November 27th, 2020, 05:40 PM | #1 |
[motorcycle.com] - Chinese Aprilia Flat Tracker Revealed in Design Filings
Piaggio‘s joint venture with Chinese manufacturer Zongshen has filed a design for a motorcycle that may be the closest thing we’ll see to a new Aprilia flat tracker.
Zongshen-Piaggio Foshan registered the design in July with the China National Intellectual Property Administration, which published the filing today. The design is simply labeled as “???(Flat)”, or “motorcycle (Flat)”, so for lack of a better name, we’ll call it the Zongshen-Aprilia Flat 150. The engine and frame appear similar to an existing model called the Zongshen-Aprilia Cafe 150, pictured below. The engine is also used on an adventure bike called the Terra 150 and an RSV4-inspired sportbike called the GPR150, though they both use an aluminum twin-spar frame. The Cafe 150’s liquid-cooled DOHC Single with electronic fuel injection claims an output of 17.8 hp at 9750 rpm and 10.3 lb-ft. at 7500 rpm. These existing bikes are equipped with a single exhaust while the Flat 150 stands out with two silencers mounted below the tail and covered by panels styled to resemble number boards. Up front, the Flat 150 sports another panel that resembles a number board. Below that is a small opening between the turn signals. Our guess is the opening is for a rather slim LED headlight, which may suggest the design is more a concept than a finished production model. Above the number board is a digital display. This too would be a departure from the existing Zongshen-Aprilia 150 models which all use an analog tachometer with a small inset LCD screen. The Flat 150 runs on 19-inch wire spoke wheels, front and rear, like a real competition flat tracker, but the presence of lighting, mirrors, front fender and tire-hugging plate holder reminds us this is still intended to be a streetbike. The design filing offers no clue as to when Zongshen-Piaggio may reveal a physical bike, whether a concept or production model. As with the rest of Zongshen-Aprilia’s line-up, it’s unlikely we’ll see the Flat 150 outside of Asian markets. Become a Motorcycle.com insider. Get the latest motorcycle news first by subscribing to our newsletter here. The post Chinese Aprilia Flat Tracker Revealed in Design Filings appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - Honda Rebel 1100 Revealed in Patent Filings | Ninjette Newsbot | Motorcycling News | 0 | October 21st, 2020 08:51 PM |
[motorcycle.com] - Design Filings Offer Better Look at Harley-Davidson Pan America, C | Ninjette Newsbot | Motorcycling News | 0 | February 12th, 2019 09:11 PM |
[motorcycle.com] - New Can-Am Spyder Design Revealed in Patent Filings | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2018 08:00 PM |
[motorcycle.com] - Turbocharged Suzuki Revealed in Patent Filings | Ninjette Newsbot | Motorcycling News | 0 | April 27th, 2017 06:30 PM |
[RideApart] - Indian Scout FTR750 Flat Tracker Revealed | Ninjette Newsbot | Motorcycling News | 0 | August 9th, 2016 11:20 AM |
