Old May 20th, 2012, 12:46 PM   #1
StaylorT
Motorcycle(s): Cbr 125, Ninja 250
High Beam wont work!
So, I usually ride with my high beams on all the time, im not sure if that has anything to do with this. But my highbeams suddenly turned off, and wouldnt turn back on. The low beams are still working. The highbeam indicator still comes on. The bulb looks like its still intact. The only thing I can think of is either a blown fuse? or connection problem. Anyone have any insight or words of wisdom for a new 250 rider?
StaylorT is offline   Reply With Quote
Old May 20th, 2012, 01:02 PM   #2
you can reach up from under the bottom and pull it out... theres only 1 fuse for the headlights on the new ninjas so its not the fuse. it's not possible that the brights switch is to blame since you have the brights indicator on. i would think the bulb would have to be busted. maybe a wire going to the bulb.
Old May 20th, 2012, 01:06 PM   #3
xSean13
xSean13's Avatar
If you hadn't already checked, reach in and make sure it's plugged in. I had the same issue, but after further investigation I found that it wasn't even plugged in (could have gotten jarred loose..no idea how though)
Old May 20th, 2012, 01:07 PM   #4
StaylorT
I already unplugged it and plugged it back in. Is there any way to tell if the bulb is just blown... just by looking at it?
Old May 20th, 2012, 01:34 PM   #5
sometimes its hard to tell... usually, not putting any light out is the indicator that it doesn't work
try putting the low beam light in the high beam side or something
Old May 20th, 2012, 02:52 PM   #6
headshrink
headshrink's Avatar
Yeah, I was thinking switching the bulbs too. if it still won't work, and the other does, it isn't your bulb, but if it is the bulb, that will become obvious too. You can also use a multimeter to check continuity on the bulb.
low beam or high beam brighter? only choose one passive101 General Motorcycling Discussion 3 July 26th, 2013 06:27 AM
Low Beam Good, High Beam dead FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 4 February 21st, 2013 03:44 PM
make high beam into low beam? DaMan22 2008 - 2012 Ninja 250R Farkles 2 July 12th, 2012 06:34 PM
HID Low and High Beam Pudge Ate Me 2008 - 2012 Ninja 250R Farkles 7 November 29th, 2011 09:52 AM
Has anyone tried to put a high beam bulb in divingtigger 2008 - 2012 Ninja 250R Tech Talk 16 April 7th, 2010 12:03 PM
