Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old October 31st, 2012, 01:22 PM   #41
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
3 Hone. Yeah. That's the ticket.
250rr is offline   Reply With Quote
Old November 1st, 2012, 07:31 PM   #42
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Originally Posted by Jiggles View Post
Wow, it can't backfire and run like ****??
Damn....
Yes, and run like ****?? no.
Damn....
Old November 1st, 2012, 09:36 PM   #43
Old Guy on a '08
Chris
Old Guy on a '08's Avatar
Motorcycle(s): BLACK!!! '08 250R
Damn....
I hope they fix what happens at 80MPH
Some roads are too good to waste on four wheels!
Riding in a car is like watching a movie...
Riding on a motorcycle is like being in one....
Old Guy on a '08 is offline   Reply With Quote
Old November 1st, 2012, 09:57 PM   #44
I've seen fuel injected bikes with full systems blow flames on youtube. I'm pretty sure that if a 250 can do it, a 300 can do it as well.
Exhibit A, a fuel injected bike with better flames than that 250:
Old November 2nd, 2012, 03:22 PM   #45
Asspire
Asspire's Avatar
if the 300 can do that I'll will get one asap
Old November 21st, 2012, 04:00 PM   #46
drbyatch
drbyatch's Avatar
Motorcycle(s): Ninja 300
Wink
Originally Posted by Sapper View Post
The 300 sucks because the ABS model is only available in special edition green/black.
I would prefer my white one to have ABS and would gladly have paid another $500.
White ABS models here - Australia
Jelly ?
edit : :P
Last futzed with by drbyatch; November 21st, 2012 at 07:28 PM. Reason: just being cheeky
drbyatch is offline   Reply With Quote
Old January 9th, 2013, 07:19 AM   #47
rersme
Motorcycle(s): ninja 250 FI
Guys, so how exactly if I want to make my ninja 300 do this kind of back fire??
it will look like a freakin Gp bike...
rersme is offline   Reply With Quote
Old January 9th, 2013, 07:54 AM   #48
lgk
get an aftermarket exhaust, tune fuel rich, leave kleen air system= back fire.
Old January 9th, 2013, 08:15 AM   #49
rersme
okay I have the aftermarket exhaust.
tune the fuel rich means I have use Power comander?
does applying an aftermarket open air filter leave the kleen air system? if not how to do so?
cheers
Old January 9th, 2013, 08:19 AM   #50
lgk
cheers
power commander will work
usually you remove the kleen air system when you use pod filters.
not sure if works right without the airbox.
Old January 9th, 2013, 09:02 AM   #51
rersme
I see. Does this kind of setting mess up the engine or performance mate?
Old January 9th, 2013, 09:07 AM   #52
lgk
i would block off the kleen air system with a plate.
then get the afr tuned to 12.5,
it'll be just fine, and you have a little more power.
Old January 9th, 2013, 09:52 AM   #53
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
my 14 throws several foot flames out of each side.
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old January 9th, 2013, 10:07 AM   #54
rersme
Whats afr? Is that one of the variable in the Ecu?
You have been very helpful sorry to ask so much. Newbie right here.
Old January 9th, 2013, 10:38 AM   #55
lgk
air fuel ratio, the power commander will help you tune it.
not sure if the new factory ecu is tunable, have not gotten a hold of one yet.
Old January 9th, 2013, 10:47 AM   #56
lgk
post video or it didn't happen
Old January 9th, 2013, 10:54 AM   #57
kbryant
Area P
kbryant's Avatar
Unfortunetly some Dyno operators do this to distort the numbers, as well as not wanting to take the time (or knowing how) to hook up the tach leads to the ECU, The runs were probably done in 3rd gear, when they are normally done in 5th (on the Dyno, 5th is approximately 92 mph on a 250, 97 mph on a 300). They also use the "STD" correction factor which reads approximately 4% higher than the industry accepted standard of SAE.
Old January 10th, 2013, 12:19 PM   #58
caps
Sexy Beast
caps's Avatar
I'll see if someone has one of my bike.
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old May 6th, 2013, 10:11 AM   #59
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Know why this bike really sucks? Everytime you pull in the ****ing clutch it does. Piece of ****
AFM #676
Supersports are for n00bs
Old May 6th, 2013, 10:13 AM   #60
I'll tell you what; I'll take the stupid pos off your hands. All you have to do is ride it to Ohio. I'll even do it for free because I'm a nice guy. How's that sound?
Old May 6th, 2013, 10:18 AM   #61
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I can't get it to Ohio chode or you'd have a deal. It gets to the end of the block
AFM #676
Old May 6th, 2013, 11:40 AM   #62
Does it idle smoothly? What do you have your idle set at after the bike is warmed up?
Old May 6th, 2013, 12:21 PM   #63
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
im lookin for a track bike... ill take it off your hands Mr. member of the month sir
Hope you can get it figured out
Old May 6th, 2013, 12:22 PM   #64
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yea it idles fine, I've got the idle set at 1500, I've put it as high as 2500 trying to get the issue to stop but it still happens
AFM #676
Old May 6th, 2013, 12:33 PM   #65
c-dog
c-dog's Avatar
Motorcycle(s): -
Yikes! How many miles do you have on it? Did you do the first oil change yet? I'm scared...
When I start mine up in the morning or when cold it will be idling at 2000 then after 2-3 mins it drops down to 1500.
I haven't had any trouble yet. But at only 170 miles so far. First oil change done at 150 miles for me.
c-dog is offline   Reply With Quote
Old May 6th, 2013, 12:35 PM   #66
Word on the street is that a fuel controller fixes that. No idea why it has to do that in the first place.
Old May 6th, 2013, 01:28 PM   #67
Weird. Certainly shouldn't be necessary to add a fuel controller to fix the issue, but interesting that it fixes it for some. For what it's worth, my bike doesn't do this.
Old May 6th, 2013, 01:35 PM   #68
KawiKid860
KawiKid860's Avatar
You must have got the Ninjette.org special edition!
Old May 6th, 2013, 03:03 PM   #69
on the 250 (carbed) there is a little spindle on the side of the carbs that insures it doesn't die when revved and then cut to idle. maybe there is an electronic version on the 300 that is not doing its job correctly? maybe jiggles doesn't know how to pull in a clutch? the kill switch is not a proper clutch, sean.
Old May 6th, 2013, 03:40 PM   #70
allanoue
allanoue's Avatar
MOTM - Sep '14
I have logged 2300 miles, 55 mpg overall and 53 mpg on last tank, no hint of a problem.
I feel bad for you all having stall issues.
edit: fat fingered my last tank fill
Old May 6th, 2013, 04:43 PM   #71
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Well it didn't do it that much before but lately it's almost everytime the clutch is pulled which is incredibly annoying trying to teach my Gf how to ride and dies everytime she tries to shift.
I might take it to the dealer
AFM #676
Old May 6th, 2013, 09:12 PM   #72
Byakkotai
Byakkotai's Avatar
Motorcycle(s): 2013 White Ninja 300
Booo, thus far this problem has been going unsolved No problems on mine either though
Byakkotai is offline   Reply With Quote
Well that just sucks... sLick415 Videos 7 May 23rd, 2013 11:15 AM
Rear Brake Bleeding Problem (2011 Ninja 250) - Caliper Valve Sucks Back Fluid/Air MovingUp7 2008 - 2012 Ninja 250R Tech Talk 3 January 28th, 2013 08:46 AM
Why the 2013 Ninja 250 sucks Jiggles 2013 - 2017 Ninja 300 General Discussion 197 October 9th, 2012 10:13 AM
It really sucks that..... Stingray1000 General Motorcycling Discussion 7 June 10th, 2012 04:45 PM
