Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old October 4th, 2012, 12:21 AM   #121
psych0hans
psych0hans's Avatar
Originally Posted by rusninja View Post
Got my bike back instead of 57 miles i have 25 now 5 that they were testing >.> seems like its functioning good hopefully the problems are over. Now i have to train so if you ever set up a group ride alex. x]
That's a beautiful bike glad you got it sorted out!!!
Old October 8th, 2012, 01:29 PM   #122
Sapper
MSF Instructor
Motorcycle(s): 2013 Ninja 300, 2010 Yamaha WR250R, 2008 CBR600RR
100% agree with your thoughts/observations., except the dash doesn't bother me at all; just comparing it to the old 250s, not a supersport or anything though.
Brake feel sucks, everything else is great
Sapper is offline   Reply With Quote
Old October 8th, 2012, 03:29 PM   #123
lgk
whats wrong with the brakes?
Old October 8th, 2012, 04:32 PM   #124
Sapper
MSF Instructor
They just don't bite like good brakes, you have to really get on the (front) brakes but when you do they are adequate
Old October 8th, 2012, 04:42 PM   #125
lgk
could it be an issue of break in?
or the pads just not that good?
Old October 8th, 2012, 06:52 PM   #126
2013 kawi girl
Motorcycle(s): 2013 ninja 300
Glad to hear that you got your bike, Alex. I have a question for you. I saw that you are using Pitbull stand. I have those same stand but what mm adapter are you using for the steering stem neck? It will be super helpful when I change my oil at 300 miles.
2013 kawi girl is offline   Reply With Quote
Old October 8th, 2012, 06:55 PM   #127
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
You lift the front and the back to do an oil change?
AFM #676
Supersports are for n00bs
Old October 8th, 2012, 07:21 PM   #128
Sapper
MSF Instructor
You don't have to lift either but it is easier to see the oil level and if you lift one end you should lift the other to properly see the oil level
Old October 8th, 2012, 07:24 PM   #129
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Ah that's a good point, I usually just lift the back for all the clearance I need.
AFM #676
Old October 8th, 2012, 07:26 PM   #130
They've gotten a little better, now approaching 500 miles. But they still aren't great. They aren't sintered pads like on the new-gens. They are resin/organic on the non-abs bikes, but are supposed to be sintered on the abs bikes. I went looking to see if EBC had a fitment yet for the 300's, and it doesn't look like it. The shape appears to be different than the new-gen brake pads.
I'm using the #2 pin. It's the same one I use for the 10R, and I'm too lazy to swap the pin out each time. It fits more than well enough to hold the bike securely.
Old October 8th, 2012, 07:26 PM   #131
Sapper
MSF Instructor
I just did my first oil change at 600, super easy on this bike but the filter was screwed on by Hercules so I needed a filter wrench.
I prefer the Pitbull stand that uses the front forks..
Old October 8th, 2012, 07:31 PM   #132
Jiggles
Jiggles's Avatar
MOTM - Apr '13
When I was reading about oil changes for the n1k I heard about people getting some air pocket or something with the oil filters. When you'd start the bike it wouldn't pump oil and the oil light would be on, no clue if its just n1k's or if it can happen to any kawi with these cartridge oil filters. Anyway, the solution was to fill the oil filter with oil before installing it, did you do this?
@Alex How do you do the oil change on the zx10? If you don't fill the oil filter beforehand have you ever had the oil not flow directly after doing an oil change?
AFM #676
Old October 8th, 2012, 07:34 PM   #133
Old October 8th, 2012, 07:37 PM   #134
Jiggles
Jiggles's Avatar
MOTM - Apr '13
AFM #676
Old October 8th, 2012, 07:45 PM   #135
Couple more thoughts on the bike after a fun ride on Saturday (info and video in the Ride Reports section):
  • Brake feel is a little better than it was, but probably as good as it's going to get. Still want new pads.
  • Rear suspension is much better balanced after I bumped the preload up a few notches
  • Seat isn't as uncomfortable as I had thought; no issues after two 200 mile days.
  • OEM tires can be used right to the edge, but the feel isn't the best at full lean.
  • Yes, you can step the rear out under power when it is leaned over. It helps if the road is a little dusty/dirty.
  • The bike feels like it has much less engine braking than I remember on prior ninjettes. It might be due to running the revs slightly lower in normal use.
  • Zero wobble in the front end when decelerating with no hands on the bars. Will see if this remains a-ok as the tires wear.
  • Fuel mileage remains better than the 250 for me, but not nearly to the extent that has been shared in some early reviews. Check out the fuel mileage poll for details.
  • Clutch pull is super-easy, but the feel of the clutch engagement is a bit soft. If you are accelerating hard, and clutch in and out quickly, it seems as if it takes a moment for the clutch to fully bite and start driving in the next gear. It doesn't slip, it just seems like it takes longer than expected to hook up.
  • Hit 102 on the GPS on a flat road, tucked moderately. Felt like it had 4 or 5 more mph in it. It is gearing limited at 115 mph at redline in 6th, I'm not sure if a stock bike could pull that; probably not with someone my-sized on top of it.
Old October 8th, 2012, 08:06 PM   #136
Boom King
So, where's the reverse?
Boom King's Avatar
Do you find the improved low and mid-range torque makes the 300 pull better around the city. How's the protection from the windscreen and is it still all elbows in the side mirrors?
Old October 8th, 2012, 08:06 PM   #137
But some of the work you need the front end up for requires a head/triple-tree stand (fork job, triple swap, etc. Triple-tree stand FTW.
Old October 8th, 2012, 08:11 PM   #138
Yes, the increased torque is easily noticeable. Wind protection seems similar as any sportbike; if you're tucked in it's fine; if you're sitting straight up you're in the wind. Mirrors seem like they are a fractionally wider, but it seems like it's harder for me to get my elbows out of the way of them. YMMV.
The triple-tree stand is bulletproof, allowing you to turn the bars all the way in either direction when you're working on things around the handlebars, and it's impossible for the bike to fall off.
Old October 8th, 2012, 11:23 PM   #139
Saw a picture of my bike when it was still in the crate:
These appear to be coming almost completely assembled; even the wheels are already in place.
Old October 8th, 2012, 11:27 PM   #140
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Assembly - $500
What is this fee? What am I paying for?
We put the mirrors on.
Oh...
Yep.
AFM #676
Old October 9th, 2012, 12:50 AM   #141
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Mike, you must be right, cos that's the same the motorcycle-tester in Germany talk about.
Old October 10th, 2012, 07:22 AM   #142
ally99
Ninja chick
ally99's Avatar
MOTM - Dec '13, Feb '15
Gorgeous bike, Alex. I'm REALLY tempted to sell my 250 and buy one, but have to save money for now since I just bought a track bike. lol! I'm jealous though and LOVE YOUR BIKE!
Postwhores are COOL! ~Allyson
Old October 10th, 2012, 06:07 PM   #143
Apex
Livin' the Minimoto Life
Apex's Avatar
Hey, you can't sell your "slip 'n slide"!
Old October 11th, 2012, 12:04 AM   #144
KELPHYN
KELPHYN's Avatar
Smile
Attachment 21296
That's pretty much how my '08 came, took it out of the crate myself. Just had to install windscreen, handle bars, battery, seat and side panels (had dealer charge the battery day before); a little gas and vroom. Saved myself a couple hundred bucks doing the PDI myself.
Was kind of expecting it to be in more pieces. When I used to stop by one of the bike shops back in the '80's, he would let us help put together the new bikes and quads. there was a LOT more assembly back then. Could take you all day to put a bike together, Now... I was done and out the door in like a hour.
Old October 11th, 2012, 03:20 AM   #145
ally99
Ninja chick
ally99's Avatar
Ha! Slip n slide. Awesome!
Old October 11th, 2012, 10:14 PM   #146
msebastian
msebastian's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Is the Ninja decal on the tank under the clear coat or is it removable. I have to wait for awhile to get my bike. I put a $1,000 down payment down and was told they only got 2 of the 17 pre orders and I was number 18. Thats cool though since I wont be able to ride until late Feb. or early Mar. I asked for them to call me when some more come in so I can at least look at the bike and sit on it.
msebastian is offline   Reply With Quote
Old October 11th, 2012, 10:25 PM   #147
Byakkotai
Byakkotai's Avatar
Motorcycle(s): 2013 White Ninja 300
600 mile service yet?
Byakkotai is offline   Reply With Quote
Old October 12th, 2012, 12:14 AM   #148
Nope - but soon.
Old October 12th, 2012, 12:15 AM   #149
Magicride
Magicride's Avatar
Motorcycle(s): White Ninja 300
It's under the clear coat
Magicride is offline   Reply With Quote
Old October 13th, 2012, 06:26 PM   #150
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Due to my height i lowered my 250, do you know if the same kit from roaring toyzs can be used to lower the 300? Is the suspension the same?
Old October 13th, 2012, 07:48 PM   #151
Not sure. I know the wheelbase is slightly different, and the ground clearance is supposed to be a little higher. That implies that the suspension was changed in some ways, but hard to tell exactly how until people can compare them more carefully back to back.
Old October 13th, 2012, 09:28 PM   #152
Raise the tail!!! moar handling
Old October 14th, 2012, 02:32 AM   #153
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Motorcycle(s): 08 Kurosaki 250, 09 Honda 600RawrRawr
If I felt I had a small bike need in the future, I'd definitely put one of these on my wishlist. At the moment though, my 250's days in my garage may be numbered. We'll see.
The seat probably feels harder because its new. I noticed that compared to my old 250 with 13k miles, my new used one with 3k on it was much harder. It just needs a couple hundred hours of butt time break in
"Faster than Kurosaki's ninjette"
ah hell nawwww
Kurosaki is offline   Reply With Quote
Old October 14th, 2012, 02:39 AM   #154
ah hell nawwww
Kurosaki's back!
And falling for the [you.] function like a n00b.
Last futzed with by CZroe; October 14th, 2012 at 01:24 PM.
Old October 14th, 2012, 11:00 AM   #155
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
I lurk
and stuff
Old October 14th, 2012, 02:52 PM   #156
Jiggles
Jiggles's Avatar
MOTM - Apr '13
ah hell nawwww
It's not hard since your bike is so slow
AFM #676
Old October 14th, 2012, 08:33 PM   #157
Just nudged over 600 miles today, after another trip up Mt. Hamilton. Planned to head to Marin this morning, but slept just a bit later than expected. Pics up:
Another trip up Mt. Hamilton on the 300
Old October 16th, 2012, 04:41 PM   #158
600 mile service scheduled for saturday after next. They may have been able to fit me in this weekend, but it would have been first-come first-served, and they only have one tech on the books this weekend. Means I won't be putting too many miles on it this weekend, but the other bikes have been sitting for a little while anyway, and are probably due for a ride. Thanks to the 300, of course.
picked up ninja 250 james250ninja 2008 - 2012 Ninja 250R Tech Talk 13 March 4th, 2015 07:41 PM
Picked up Ninja 250 Last wednesday AdhesiveTransfers Pictures 6 May 27th, 2013 12:24 PM
Just picked up a couple motors for the ninja Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 4 April 22nd, 2013 06:44 PM
Picked up my first ninja, some parts questions: Taskarnin 1986 - 2007 Ninja 250R Tech Talk 4 November 27th, 2012 08:32 PM
Just picked up a White Ninja JELY1990 General Motorcycling Discussion 22 July 13th, 2012 11:00 PM
